20 Most Recent Panasonic PT-AE3000U LCD Projector Questions & Answers
I'm am new at this forum. Please help. I've
Check first if/that all connections are connected as the should be. That in order go to the menu on your tv. Go to picture and adjust the brightness. K
12/23/2017 12:48:22 AM • Panasonic... • Answered on Dec 23, 2017
Projector turn off into two minutes and do not turn on
If the Panasonic Logo comes and then the projectors turns off, the main board of the projector requires replacement!
12/13/2017 12:40:48 AM • Panasonic... • Answered on Dec 13, 2017
Hi there, I'm having a strange problem that has
if you can select the hdmi inputs ok and swap them around without a good result if no image etc you would expect there to be a default no signal message or error something on the viewing screen if a total blank could be possible the Projector unit has a internal board failure
Panasonic PT-AE3000U Operating Instructions Manual - ManualsLib
https://www.manualslib.com/manual/246284/Panasonic-Pt-Ae3000u.htm
4/1/2017 1:45:53 PM • Panasonic... • Answered on Apr 01, 2017
Panasonic pt- ae3000e HDMI Inputs won't work
interface of the inputs is defective Have a good day! We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel, motherboard, powersupply ... with high quality and competitive price. Jerry China Lampdeng Limited Tel: +86 131788 67858 E-mail: [email protected] Skype: lampdeng.com YM: [email protected] http://facebook.com/lampdeng http://www.lampdeng.com
2/22/2014 7:38:48 AM • Panasonic... • Answered on Feb 22, 2014
Panasonic 3000u projector overheating
it depends after how long the temperature indication comesif it comes immediately as soon as the projector comes on[say in 1 min] then the ballast circuit has to be replaced.if the temperature comes after say 5 mins , it could be that one of the exhaust fans is not moving freely and needs to be replaced!
1/18/2013 12:49:45 PM • Panasonic... • Answered on Jan 18, 2013
Panasonic logo comes on for 7-8 seconds then shus
This is most likely a fan issue. Remove both covers (there are 2), so that the PCB is exposed. Using compressed air (ideally from a compressor, not from a can), blow all of the dust out of the unit, especially near the fans (there are 4 of them). If this doesn't work, you may have a dead fan. PacParts sells replacements.
7/26/2012 9:56:43 PM • Panasonic... • Answered on Jul 26, 2012
2answers
When we turn on our
if it abruptly turns off the thermal sensor could be worn out and triggering to shutdown, other than this it may be software related.
be sure that the projector is receiving a signal in the correct input form a DVD player or something to ensure that its not just on the standby screen.
7/26/2012 9:43:36 PM • Panasonic... • Answered on Jul 26, 2012
I have been noticing blue bands on the projection
This normally caused by the computer or laptop resolution not being completely compatible with the projector resolution, you will need to adjust you computer or laptop resolution to match your projector resolution.
3/25/2011 4:16:56 AM • Panasonic... • Answered on Mar 25, 2011
Need step by step instructions to set-up memory
LENS MEMORY means that
You can save and name the adjusted ZOOM/FOCUS,
H-AREA POSITION and V-AREA POSITION there is just 4 adjustment settings in
memory excluding ASPECT RATIO the aspect ratio depend on signal but you can change manually when needed.
possible ASPECT RATIO and SIGNALS
If VIDEO or S-VIDEO then
ASPECT RATIO
4:3 \ 16:9 \ 14:9 \ ZOOM1 \
ZOOM2 \ JUST
AUTO
\ 4:3 \ 16:9 \ JUST \ ZOOM
you can switch in between
If COMPUTER then
4:3 \ 16:9
4:3 \ 16:9
VGA or SVGA signals
Not switchable with
WIDE480/600/720/768/768-2/800/900 signals
If HDMI then
4:3 \ 16:9
16:9 \ H - FIT \ V - FIT \ ZOOM
1 125 (1 080)/50i, 1 125 (1 080)/60i,
1 125 (1 080)/50p, 1 125 (1 080)/60p,
1 125 (1 080)/24p, 750 (720)/50p and
750 (720)/60p signals
525p (480p) and 625p (576p) signals
If COMPONENT(YPBPR) then
4:3 \ 16:9 \ 14:9 \ JUST \ ZOOM1
\ ZOOM2
625i (576i), 625p (576p)
AUTO \ 4:3 \ 16:9 \ JUST \ ZOOM
525i (480i), 525p (480p)
1 125 (1 080)/24p, 750 (720)/50p,
these are all type of signals and there possible aspect ratios
2/10/2011 12:33:35 PM • Panasonic... • Answered on Feb 10, 2011
My panasonic projector pt-ae3000u is not seeing my ps3
Should work right away, are selecting the correct HDMI input? (1,2 or 3?)
Do you have a way of checking the cable?
8/15/2010 6:36:15 PM • Panasonic... • Answered on Aug 15, 2010
Replace lamp icon cam up. replaced lamp now unit
Did you reset the lamp timer?
8/15/2010 6:31:37 PM • Panasonic... • Answered on Aug 15, 2010
My panasonic 3000 projector runs
Have you reset the lamp timer?
What are the Power, Lamp and Temp LEDs on the projector indicating?
8/15/2010 6:30:39 PM • Panasonic... • Answered on Aug 15, 2010
When it is turned on
its a blub/lamp problem.the filament in the blub and the bulb hours are near to end.and the red light error led coming up is for the need of new lamp.replacing the lamp will solve the problem. as per the problem which you mentioned its confoirmed the lamp fault.but it has been seen in many cases that after replacing the lamp if the problem remains the same then light engine also needs replacement.because lamp gets power from light engine.you can get required parts from
www.partstore.com
This will help. Thanks please keep updated. please do rate the solution positively .thank you for using fixya.
11/27/2009 8:53:48 PM • Panasonic... • Answered on Nov 27, 2009
1. short lamp live
First, make sure you've cleaned any dust filters on the unit!! That in itself will usually stop overheating (think of someone closing off your nose and mouth) that's what happens when the dust filter gets clogged--the unit strangles for cool air and rapidly overheats--this not only shortens lamp life dramatically, but also shortens the life of ALL components in the unit, especially delicate LCD panels or the display chip in a DLP projector!
9/8/2009 12:07:41 AM • Panasonic... • Answered on Sep 08, 2009
I want to reset my machine Panasonic 4530. How can i do it
You have not identified an error code. If the problem is the fuser, the following procedure should reset it. If the related error code reappears, you need a new fuser. The error code for that is E04-1.
  • Press the "function + Orig.size + 3" buttons at the same time once.
  • Then press F9 ram initialize.
  • Then press LBP FUSER RESET.
9/22/2022 3:38:17 AM • Panasonic Office... • Answered on Sep 22, 2022
I have a old Panasonic KX-F750 fax machine, it's still working fine except the buttons are not responding all the times, any way to fix it?
Clean them with electrical contact spray cleaner. Switch off, use the spray, work the buttons, spray again and leave a couple of hours to dry. If that doesn't work, you have to get underneath the buttons and clean the contact surface. Don't use Water Displacement 40 and it has a wax residue after the kerosene evaporates. https://www.google.com/search?q=electrical+contact+spray+cleaner ..
8/25/2022 4:09:32 PM • Panasonic Office... • Answered on Aug 25, 2022
How to reset a panasonic dp-2330 to factory default settings?
why not RTM read the manual, ALL it does is there. https://panasonic.net/cns/pcc/support/mfp/dp-3030/gdi/download.html page 12 step 5, https://www.psn-web.net/cs/support/mfp/dp-c405/pcl/Manual/ENG/Printer%20Driver%20OI.pdf read PAGE 12, restore all defaults button google found this is 3 seconds flat , amazing no?
8/10/2022 4:39:45 PM • Panasonic Office... • Answered on Aug 10, 2022
Panasonic PT-AE3000U LCD Projector Logo
19 questions posted
Top Panasonic Office Equipment & Supplies Experts
Mehandi Husain ...
Marvin
Marvin
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Office Equipment & Supplies
Most Popular Question
am new forum please help ve
  • Office Equipment & Supplies
