20 Most Recent Visual Land Prestige 7L Android 4.1 Jelly Bean Internet Tablet 7" Questions & Answers
Is there any particular reason to format the tablet?
Visual Land... | Answered on Jan 06, 2020
try this out.
To do a factory data reset, follow these steps:
  1. If your phone is on, turn it off.
  2. Press and hold the Volume up button and the Power button at the same time until the device turns on.
  3. Press the Volume down button to select "Recovery mode."
More items...
Reset your Android One to factory settings - Android One Help
https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=factory+reset.+android+
Visual Land... | Answered on Dec 21, 2016
I tried the same thing I had to go under settings and manually reset it. It is settings, About device and Factory Reset and back up section. I hope this was helpful for you.
Visual Land... | Answered on Apr 09, 2016
go to you tube type your question in and you will get the help you need in the form of a video which you can pause and follow it step by step . hope this helps you .
Visual Land... | Answered on Dec 26, 2015
Check for driver error on wifi.
Visual Land... | Answered on Jul 11, 2015
You can try a factory reset on the tablet. Hold the volume down button and press the power button. This should bring up a system menu that should have an option to perform a factory reset on the tablet.
Visual Land... | Answered on Apr 17, 2015
If it just stopped charging and you have tried other chrgers, then the probable cause would be the battery for the tablet has failed. This is fairly common and would require disassembly of the tablet and replacement of the battery to fix.
Visual Land... | Answered on Feb 15, 2015
I suspect that it needs a thorough charging.
Visual Land... | Answered on Aug 01, 2014
It would not be easy to explain by this message; however, you need to go into your settings and add your tablet ("PAIR" it with your computer)
http://visual-land.com/downloads/prestige7ljb_manual.pdf . Go to page 21 in the manual. Make sure you download the manual so you have it for future use
Visual Land... | Answered on Jul 17, 2014
Did you try to charge it? and after that did you reset it?
Visual Land... | Answered on Jun 03, 2014
Start with tablet off. Hold power and volume up. You should boot into safe/repair mode. Try some of the options in there to get your tablet going again.
Visual Land Prestige 7L Android 4.1 Jelly Bean Internet Tablet 7" Logo
87 questions posted
Top Visual Land Tablets & eReaders Experts
Steve Mason
 Mike M
Mike M
alex metro
alex metro
Are you a Visual Land Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Visual Land Tablets & eReaders
Most Popular Question
visual land android tablet wont charge
  • Tablets & eReaders
