20 Most Recent Ativa MDM8000 8-Sheet Micro-Cut Shredder Questions & Answers
0answers
2answers
Ativia 391c
Is sounds like you have a paper jam. Most jams are pretty much the same. First, try running the blades in REVERSE, that is done by using the on/off, selector switch. If that does not solve the problem, Unplug the unit from the electrical, remove the top part from the basket. Pull out as much of the paper from the top and bottom that you can. Replace the unit on the basket (make sure it is facing in the correct direction) and squirt, or lightly pour mineral oil (or machine oil, or something like WD-40) directly on the rollers and let it absorb into the remaining paper for a few minutes then try running the unit. If the motor does not come on, there is a fuse inside the machine that may need to be replaced. Once you have solved the problem, you should oil the blades after every hour of use, it really makes it easier on the blades. Also, there is an internal "heat switch" in the machine that will shut it down for about 90 minutes if the motor gets to hot. It is a safety factor in case you get something stuck, like a person wearing a tie, etc. After the machine has cooled down, turn the on/off switch to off and then back to on. . If that does not work, try their Customer Service at: http://www.ativaproducts.com/contact.html
11/2/2021 12:11:47 AM • Ativa Office... • Answered on Nov 02, 2021
0answers
0answers
How do these points equate to money?
No money ever! There is no payment made for answers on Fixya, points don't mean prizes, they are just for fun. ADMIN Andrew
  • Answers: 65,820 and not a penny per Answer.
Head over to www.justanswer.com they pay lots of money because they charge for people to ask a question. ..
4/19/2024 9:45:02 PM • Office Equipment... • Answered on Apr 19, 2024
Error code e000350-0002
'Make model (what it is)' is needed in questions like this, and in fact ALL questions!! But we can just guess.
Error Code Ir 3300 e350-3000 and e350-00002
Copytechnet https://www.copytechnet.com > ... > Canon May 1, 2018 - Put ALL the original boards back in the machine. Go to service mode level 2 & perform E355 clear. If this fails your machine is scrap. CANON iR2200 Error code E000350-001 Jan 22, 2007 error code :E0003-0002 canon IR 2880i Feb 5, 2018 Canon IRA C5540I Code E000354-0002 Sep 23, 2021 E000350-3000 on IRC4580 Sep 25, 2017 More results from www.copytechnet.com
Canon iR Advance 4245 - E350-0002
PrintCopy .info https://printcopy.info > code=E350-0002 Canon iR Advance 4245 ; Code: E350-0002 ; Description: System error ; Remedy: Contact to the sales companies. ..
4/19/2024 5:37:38 PM • Office Equipment... • Answered on Apr 19, 2024
E6 on my ISMART 500 trojan. How do i fix it please
This link is the best I can come up with: How to fix E6 & E7 on Trojan treadmill solved!! (youtube.com)
4/19/2024 12:27:09 AM • Office Equipment... • Answered on Apr 19, 2024
2answers
Error code Z08-1090
I need help I have an error on my ComColor 7050 Z08-1090
4/18/2024 11:40:08 AM • Office Equipment... • Answered on Apr 18, 2024
2answers
How do I fix this error SEr on conlog prepaid meter
Call your supply company.
4/17/2024 1:47:07 PM • Office Equipment... • Answered on Apr 17, 2024
Setting tax rate on Ativa KC-421
How to set up tax rate on Ativan 12 digit calculator
4/16/2024 1:16:37 AM • Office Equipment... • Answered on Apr 16, 2024
2answers
Tech solutions mod# TS8000 lost power while shedding
You posted to the Category 'Cars and Trucks'? shedding? Help in the link https://www.google.com/search?q=Tech+solutions+mod%23+TS8000 All questions need 'make model (what is is)' as first 3 words. Thinking that this might be a 'shredder' gives better results, we also have a Shredder Category, so I moved it. Shredders have an overheat thermal cut out and also a thermal fuse. It may reset itself. https://www.google.com/search?q=Tech+Solutions+TS8000+shredding+no+power ..
4/14/2024 7:19:19 PM • Office Equipment... • Answered on Apr 14, 2024
2answers
Tech Solutions TS8000 Shredder. Suddenly no power on mod TS8000
Edited for clarity. Full 'make model (what is is )' please first 3 words. Thermal cut out, thermal fuse, or burned out motor. They all have a suggested time limit for running them and is generally 20 minutes unless it is a commercial model and cost $1,200 to $4,000. https://www.google.com/search?q=Tech+Solutions+TS8000+shredding+no+power It looks to be a capable machine, but no parts from 'Shredder Parts dot com'. https://www.google.com/search?q=Tech+Solutions+TS8000 ..
4/14/2024 7:17:27 PM • Office Equipment... • Answered on Apr 14, 2024
Can you help me with code for mega power tv
Try "supervisor" as the username (no password).
4/14/2024 7:07:36 PM • Office Equipment... • Answered on Apr 14, 2024
3answers
I'm looking for a permanent job what can I do?
You should write good resume and then to search vacancies on job boards.
4/10/2024 2:36:35 AM • Office Equipment... • Answered on Apr 10, 2024
Canon imageCLASS MF3010 Black & White Multifunction Printer. How do I fix Error E2 please?
Question edited for clarity.
Canon imageCLASS MF3010 - Error Codes
PrintCopy .info https://printcopy.info > model=imageCLASS+MF3010 Error Codes List page 1 · Code: E000 · Description: Startup failure · Remedy: (1) Check the connectors of the Fixing Assembly. (J101, J1011, J552 and J702) (2) ... ..
4/6/2024 1:10:35 AM • Office Equipment... • Answered on Apr 06, 2024
Ativa MDM8000 8-Sheet Micro-Cut Shredder Logo
1 questions posted
Top Ativa Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Ativa Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Ativa Office Equipment & Supplies
Most Popular Question
ativa shredder model md 1250 became
  • Office Equipment & Supplies
