20 Most Recent Bionaire BCH-4138 Ceramic Compact Heater Questions & Answers
Difficult to guess what the problem might be due to the amount of electronics the unit has that could cause inconsistent or illogical functioning.
I noted one product review that said "if the room is too large the auto shutdown will engage".
I suggest you revisit the instruction manual and specifications before deciding whether to call a service engineer....
Bionaire... | Answered on Sep 24, 2017
I take it once the temp is set to 71, and the ambient temp reaches 68 or so, it shuts off, never to come on again?
If that is true the thermostat in the unit is damaged, worn out or in need or replacement, but try a couple tricks.
First, if there are access panels to clean, clean it per the manual, it could be that a dirty filter or air inlet is confusing the thermostat.
Next, unplug the unit for at least 5 minutes, try it again.
Next set the unit on it's highest temp and blower setting, let it rip for 20 minutes, shut it down, unplug and remain unplugged for 5 minutes.
Next set the unit at 71 HIGH MODE.
see if we have a mode switch problem or thermostat if it works on high mode, it is not the thermostat, but I imagine it is, but I am curious as to if it once goes off, it never again comes back on?
Will
Bionaire... | Answered on Dec 02, 2008
It is here
BIONAIRE BCH3620 OWNER'S MANUAL Pdf Download ...
www.manualslib.com > ... > Bionaire Manuals > Heater
View and Download Bionaire BCH3620 owner's manual online. Bionaire digital TOWER CERAMIC heater with remote control Owner's Guide BCH3620. BCH3620 heater pdf manual ... If after having read this leaflet, you have any. questions or ...
Bionaire Heating... | Answered on Dec 24, 2020
The capacitor winding in the motor presets rotation direction. Without the capacitor, the motor will not know which direction to rotate. With a bad capacitor,or with no capacitor connected to a capacitor motor, turning the motor shaft by hand will cause the motor to rotate at operating speed in the direction manualy spun, so, the motor can rotate either way once started by hand. This proves a bad capacitor. If the motor just sits dead while energyzed, then the motor is open electricaly, usualy a thermofuse embeded into a winding goes out.
Bionaire Heating... | Answered on Oct 09, 2020
Bionaire website shown below did not list that model, but you may be able to contact them for assistance.
https://www.bionaire.com/service-and-support/product-support/instruction-manuals/instruction-manuals.html
Bionaire Heating... | Answered on Dec 01, 2019
I agree with Tom, no parts seem to be available.
The contact ULR for Bionaire is:
https://www.bionaire.com/customerservicecontact?cid=contactus
Bionaire Heating... | Answered on Jul 12, 2019
I have the same problem. This is what I found when I look inside.
I think this could be a quality issue with significant safety risks.
I hope this isn't typical of their products.
Bionaire Heating... | Answered on Jan 01, 2018
Thermal switch is ng and needs to be replaced. That switch is designed to shut down device when it overheats.
Bionaire Heating... | Answered on Sep 05, 2017
Cindy, Try replacing batteries.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Bionaire Heating... | Answered on Mar 05, 2016
Amazon.com - Bionaire Heater with Rotating Grill ...
www.amazon.com > ... > Space Heaters
Amazon.com, Inc.Amazon.com - Bionaire Heater with Rotating Grill, BFH2242M-SM - Space ... The ultraquiet Bionaire® Heat Circulator with Rotating Grill circulates warm air ... High-intensity, sun-like warmth, Gentle heat, Medium intensity, whole room .... When temperature reaches what you have set it to, the heater turns off and sometimes.
Bionaire Office Heater with Worry Free Motion Sensor
www.amazon.com > ... > Heaters & Accessories
Amazon.com, Inc.
Rating: 4.4 - ‎71 reviews
Amazon.com - Bionaire Office Heater with Worry Free Motion Sensor - Space Heaters. ... Heat turns off after 30 minutes of no motion detected. ... If you place it under the desk, your feet will be very warm, but not so much the rest ... CONS: The High setting gets too hot sometimes, while the Low setting doesn't get hot enough.
Bionaire® Electric Fireplace Heater BEF6500-UM - Bionaire
www.bionaire.com/bionaire-site.../bionaire...heater/BEF6500-UM.html
The Bionaire® Electric Fireplace Heater provides the ambiance and warmth of a ...Flame Intensity; 12 Hour OFF Timer; Free Standing or Wall Mountable; 2 Heat .
Bionaire Heating... | Answered on Jan 30, 2016
I like to know how to change , up or down the thermostat ( degrees ).
Bionaire Heating... | Answered on Jan 21, 2016
Bionaire BCH-4138 Ceramic Compact Heater Logo
8 questions posted
Top Bionaire Heating & Cooling Experts
Dennis
Vernon Taylor
Moderator Canada
Moderator Canada
Are you a Bionaire Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Bionaire Heating & Cooling
Most Popular Question
heater shuts off as soon as room warm
  • Heating & Cooling
