20 Most Recent GE 24 in. Profile PDW9200J Built-in Dishwasher Questions & Answers
You have a washer control board problem or a burnt connector or both.
GE 24 in.... | Answered on Mar 17, 2017
Hello daniedag,
Unfortunately, your dishwasher may have experienced a power surge when the power went off and dmaged some internal components or the control logic. There is no way of knowing the extent of your problem without a thorough diagnostics to it. It could be something as simple as a circuit borad component, stuck relay but this kind of repair is probably not something you would want to tackle yourself unless properly trained and with the proper test equipment. If you have homeowners insurance, it may cover the damage.. If not, then a service call is most likely required. Here is a link to the GE website for yopur dishwasher but your model is not PWD9200 and IS PDW9200 http://genet.geappliances.com/DocSearch/Dispatcher
Hope this helps..
Regards,
Rick
GE 24 in.... | Answered on Aug 28, 2012
The filter is probably blocked.
It is inside the base of the machine.
Take out the filter and clean it and also clean out the filter well as that can also hold quite a bit of debris.
Please dont forget to vote this answer was helpful
Many thanks
GE 24 in.... | Answered on Feb 13, 2011
Mine was doing the same thing. It was eligible for a recall.
Free repair or rebate toward new purchase. 1-877-275-6840 or go to website geappliances.com
GE 24 in.... | Answered on Jan 30, 2011
The Start/ reset button is part of the integrated keypad on your model and you will have to replace the whole strip.
See item 719 in this diagram.
Hope this helps. If this is different to your model then please post a comment so that I can find the correct part for your dishwasher.
GE 24 in.... | Answered on Oct 21, 2010
Hi
Please confirm if you want to install ribbon cable that connects the keypad membrane or the cable which is hooked in the MIDDLE hole of the door. The door panel covers the main control board, detergent cup, wire harness, Smart Dispense bottle, Smart Dispense detergent sensor, and Smart Dispense pump.
The outer door panel is held in place by 12 screws (5 Phillips head screws per side and two 1/4-in. hex head screws at the bottom). The esutcheon keypad is held on by 4 screws.
Note: When removing the outer door panel, be careful not to remove the 4 screws (2 per side) holding the escutcheon to the door assembly. Remove these only to gain access to the control module, active vent, fl apper, and door interlock switch.
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
GE 24 in.... | Answered on Oct 17, 2010
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
GE 24 in.... | Answered on Aug 03, 2010
add either vegetable oil or fabric softener, then run it and see how bad the suds are. continue until sudsing is minimal.
GE 24 in.... | Answered on Sep 05, 2009
I,m not familiar with this make or model but all spray arms should be removable bottom normally pulls off top quarter turn and pull and the back water feeding tube can also be removed usually by clips.rinse through thoroughly and hook out food stuffs with needle from the eyelets.the cause is general build up but mainly pips seeds rice etc.solution is to rinse plates before going in machine also checking filter is firmly in place before wash cycle.remove and check filters regulary. hope this helps
GE 24 in.... | Answered on Jun 20, 2009
no first load factory defaults settings. then check.
GE 24 in.... | Answered on Jan 09, 2009
Sounds like you have an excessive build up of hard water (mainly calcium) in it. Clean it like this: Close the detergent cup cover. Run hot water at the sink to clear cold out of the pipes. Start the machine on pots and pans/added heat. Wait about 10 minutes and open the door. If the detergent cup cover flops open, it is in the main wash. If it is still closed, let it run a few more minutes, check cup cover again, keep dong this until the cover is open. Once it is open it will be in the main wash (the longest cycle) and at that time put in about 2 cupfulls of Tang orange drink in the bottom of the tub. Tang is very high in citric acid and will clean the calcium and other hard water deposits from the tub, pump, spray arms, ect... Make sure your hot water is HOT (130 is great) and use Cascade Complete powdered detergent from now on. Should take care of it... Repeat every 6 months to keep it clean.
GE 24 in.... | Answered on Jan 06, 2009
Open the dishwasher
Remove door panel
Remove 2 screws that holds a plastic cover by the detergent release arm
Look for a switch with 2 spade lugs attached
Make sure the 2 wires are not broken or corroded
Use a tester to verify switch opens and closes.
Replace switch and your problem should be solved
GE 24 in.... | Answered on Dec 21, 2008
you mean dish sink soap lol just keep running it till its gone with out dishes may take three cycles not the first time ive seen this leave the door closed and get a mop sorry my mother in law did the same thing
GE 24 in.... | Answered on Jan 15, 2008
GE 24 in. Profile PDW9200J Built-in Dishwasher Logo
34 questions posted
Top GE Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Bill Johnson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
GE Dishwashers
  • GE Dishwashers
Most Popular Question
dishwashing liquid in dishwasher
  • Dishwashers
