20 Most Recent Toshiba Satellite L305-S5911 Notebook PC Questions & Answers
YOUR HARD DRIVE IS BAD AND MUST BE REPLACED THEN WINDOWS NEEDS TO BE RELOADED
Toshiba... | Answered on Dec 27, 2017
If you were using the computer at the time, it may be a cable/plug/socket failure. Try a different cable.
If you were watching a movie, you may want to check your screen saver settings. Try doing what you were doing and see if it disconnects after a specific time (so if your screensaver is set to 10 minutes, does your TV lose signal after 10 minutes?).
Toshiba... | Answered on Apr 30, 2012
You can try this solutions from this page
http://www.tech-faq.com/reset-bios-password.html
I hope this information will be helpful. Thank you for using FixYa!
Toshiba... | Answered on Jun 07, 2011
try to remove the battery then connect the power an try to on the laptop if it works then shutdown the laptop an reconnect the battery then on,if not then if possible remove the memory from back portion by removing the screw then clean the memory an put it back if not sorted the u have to take it to a Toshiba service center ,the cost for the system board may be some ten to twelve thousand rupees
thanks for the query happy to help you fixya team
Toshiba... | Answered on Dec 21, 2010
Welcome to Fixya
This error message usually cause by a boot sector infected by virus, a device driver that the computer boot controller needs is corrupted, hardware issue if there is a resource conflict between the boot controller and another controller or between SCSI devices. If you have the XP cd you may use the cd's repair optiong to fix this problem. If it wont let you do that then the last option you have is to reinstall windows operating system to your computer.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Toshiba... | Answered on Dec 04, 2010
What I would do first is, try to install and test it with yahoo messenger and try to see if you can connect to any of your friends. Do you have the software install to run the webcam?
Toshiba... | Answered on May 21, 2010
Click here to buy toshiba global adaptor for your computer
Please let me know if you have any further questions or concerns.
Thanks.
Toshiba... | Answered on May 07, 2010
Can you check whether you Disc Drive is well connected ?
to check the device :
Right click on my Computer
Select Properties
Hardware devices
Device Manage :
Check your Dvd/cd drives.. whether everything is connected.
If not try re-installing the device or to update it.
or try this
go to start
right click on my computer
click on manage
then click on storage
then click on disk management
then right click on your device and select add letters and path
window will pop up then click on add
the select an alphabet and click on ok
Hope your problem got solved. Thanks
Toshiba... | Answered on Apr 20, 2010
If the reading is also bad, then you have a hardware problem. Try to get a lens-cleaning disk, or clean the lens yourself VERY softly. If that won't work, you'll have to replace it.
Be sure to have the "write" or closely to that option selected in your burning software. You may only simulate the write...
Toshiba... | Answered on Nov 29, 2009
the dvd that came with you computer is a recovery disc ; to recover your computer as new as you bougth it ;so to do so ; restart your com ;change the boot options to boot from the dvd first and follow what the dvd says and excuse my english
Toshiba... | Answered on Oct 08, 2009
If you want to play DVDs from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece of software (Passkey for DVD) that allows you to play DVDs from any region and Passkey for Blu-ray that allows you to play Blu-rays from any region.
There are several available on the Internet but my favourite is DVD-Region Free
www.dvdfab.com/products,free.htm
Toshiba... | Answered on Dec 05, 2019
Do you have a wifi card in the computer? It is a hardware part that you need so that the computer can connect to the wifi. If you have that but can't find it in the operating system. I suggest that you either install or update the driver for it.
You can use RadarSync to scan your computer for the available updates of your wifi driver. Make sure that you connect to the internet first using your ethernet so that it will detect the available driver updates somewhere in the databases of the manufacturer.
David
http://goo.gl/CxsY9u
Toshiba... | Answered on Sep 25, 2019
to get the driver for your Toshiba, follow the steps below:
go to http://support.toshiba.com/drivers
enter your laptop model ( Satellite L505) and download sound drivers and other necessary drivers needed for your laptop to operate well.
Good luck.
Toshiba... | Answered on Sep 12, 2019
uninstall the software and put it again
Toshiba... | Answered on Sep 06, 2019
All drivers are available free of charge from Toshiba's web site.
Toshiba... | Answered on Jul 23, 2019
toshiba satellite error 0xc000021a
Blue screen
Toshiba... | Answered on Jun 21, 2019
go to your browser proxy setting and make the proxy automatic
Toshiba... | Answered on May 21, 2019
check the power ic of the laptop with laptop technicians
Toshiba Satellite L305-S5911 Notebook PC Logo
Popular Tags
14 questions posted
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
will not work ac adaptor
  • Computers & Internet
