20 Most Recent
Toshiba Satellite A205-S5804 PC Notebook Questions & Answers
It come on but no video
Either a bad connection from laptop to screen but most likely a fried video card. You can try lifting the cover off to check the connection to the screen. Small flat head screwdriver is needed. Pry off the cover above the keyboard. Should pop out with very little effort.
6/10/2014 3:39:59 AM •
Toshiba...
Answered
on Jun 10, 2014
I have a toshiba A205-S5804
You have a Windows installation disk, put that in the DVD drive and see if it reads that. The computer won't boot because Windows is not loaded on to your computer it sounds like.
12/19/2012 6:57:48 PM •
Toshiba...
Answered
on Dec 19, 2012
Toshiba a205 wont enter into recovery mode
with the computer off. start by having it plugged in. now press and hold down the 0 (zero) key. while holding it down press and release the power button.. as soon as you see it power up release the 0 (zero) key. this will restore to out of box state. it will take aprox and hour. You wont have to do anything just let it run the restore..
12/19/2012 6:53:23 PM •
Toshiba...
Answered
on Dec 19, 2012
How do you reset a toshiba satellite A205-S5804
If you have a restore CD then you can reinstall Windows.
If you have a Windows installation CD then you can use this to reinstall Windows.
Reinstalling Windows will wipe your data from the hard disk.
9/20/2012 7:15:16 AM •
Toshiba...
Answered
on Sep 20, 2012
Code641
Difficult to fix. Please consider re-installing Windows using the DVD
6/24/2012 3:29:13 AM •
Toshiba...
Answered
on Jun 24, 2012
Bootmgr is missing windows vistahow do i fix this?
Hi, Follow these steps:- Get your Vista installation DVD and pop it into your drive.- Then restart your computer.- Press a key when you are prompted.- Select a language, a time, a currency, and a keyboard or another input method, and then click Next-Select Repair. After which Vista's System Recovery Tools will start.-Select Start Up Repair and let Vista do its thing!
11/29/2011 3:00:27 AM •
Toshiba...
Answered
on Nov 29, 2011
How can i change the motherboard, my laptop
Here is a link for a replacement mother board
http://www.zkarlo.com/selected-zkarlo-part/motherboard-p899.php
here is a link on how to disassemble the laptop
http://www.laptoprepair101.com/laptop/2006/02/04/toshiba-laptop-disassembly-manuals/
9/21/2011 1:34:17 PM •
Toshiba...
Answered
on Sep 21, 2011
I need ethernet drivers for
I think you can try this link to download the driver for your ethernet. Hope it helps.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=1909174&rpn=PSAF3U&modelFilter=A205-S5804&selCategory=2756709&selFamily=1073768663
AnEspera
4/26/2011 10:43:15 AM •
Toshiba...
Answered
on Apr 26, 2011
I am using My Toshiba Satellite A205 laptop then
1. It's possible the AC adapter died while you were working on the laptop. The laptop was running until you had charge in the battery and after that it turned off. Can you test the AC adapter? Make sure it outputs correct voltage.
2. It's possible that you have bad RAM module. Do you know if you have two RAM modules installed in your laptop? Try removing them one by one. If one of the modules is bad, the laptop should start when your remove it.
12/15/2010 5:40:05 AM •
Toshiba...
Answered
on Dec 15, 2010
Want to wipe everything out back to factory
If
Reinstalling
12/10/2010 10:35:29 PM •
Toshiba...
Answered
on Dec 10, 2010
