20 Most Recent HP G60t Notebook Questions & Answers
Hi, I have an HP G60t 200 laptop, and the fan
thanks for showing the 200. G60t-200. they made lots of 60s. the fan on all PC's need to be cleaned every year or they all pack up and overheat or make noise. if the the fan, free of any lint makes noise (not blow sound)but racket, sounds, the bearing inside are shot. no fan made lasts for ever, but longer that the HDD, and batteries, for sure. but way less the 20-30years or more for CHIPS. its just a dc brush motor with bearings. some are AC motors inside,(with 3 phase driver inside and no brushes, fancy) but is of no matter, noise bad is bad fan. its really that simple. keep in mind folks in text box can not hear your bad fan. so answers will be, wrong, 1/2 the time. here. due to , all work like this is hands on ears on eye on job and lots of experience. if the blades are free ,of JUNK. and it makes bad sounds, its bad. simple as that. except in the cases of its falling out , screws missing , or loose. like I said I cant see it.
12/5/2017 2:55:44 PM • HP G60t Notebook • Answered on Dec 05, 2017
Question re HP G60t PC webcam and microphone. A
rumors on the internet or infinite, endless and wrong. what can go wrong with 3billion transistors, and 17GB of windows files.... endless. (Rhetorical question) forget all that. please. what OS? you didn't say what windows it is>? any modern web cam will work (not XP) any mic for a PC works, its just a simple mic. if in a hurry, got to any PC store. BEST buy? (i tossed a coin) walk in say have DV7 laptop with windows 7 ( or what it is) then ask for headphones or one onces with boom mic. like you see vast folks do with SKYPE. if PC is XP windows, good luck finding things that work but you can. XP is dead now for 3 years. Then choices are endless on all parts. head phones mic CAM. endless to the extreme.. CHOICES
8/11/2017 11:30:05 PM • HP G60t Notebook • Answered on Aug 11, 2017
I have a HP G60t CTOnotebook pc, Mobile intel (R)
The video chip/circuit on your laptop if fine since another monitor works. You need to replace the screen since it is fubar.
4/10/2017 2:20:26 AM • HP G60t Notebook • Answered on Apr 10, 2017
Will not turn on. On light blinks for 1/2 second, then nothing
your battery is prob dead, unless it is a desk top, then you power control is prob bad
9/28/2012 5:32:18 PM • HP G60t Notebook • Answered on Sep 28, 2012
My hpg60t works but my screen is black
The most likely cause is the inverter board located just below the screen behind the bazel, go to www.ebay.com type make and model of laptop, refine search to inverter board. The second less likely problem is the backlight behind the LCD display, [built in]
6/9/2012 1:38:03 AM • HP G60t Notebook • Answered on Jun 09, 2012
How to adjust the brightness of hp laptop screen
Press Fn key and brightness + key
6/7/2012 6:29:34 PM • HP G60t Notebook • Answered on Jun 07, 2012
Hp laptop G60 verticle scroll is not working
http://www8.hp.com/in/en/support-drivers.html ...put your product number of the laptop and download the drivers and reinstall them
2/10/2012 7:37:31 PM • HP G60t Notebook • Answered on Feb 10, 2012
Hp g60t went into hibernation last friday it
This issue could be due to presence of static charges or internal hardware malfunction of the notebook. To isolate the exact cause of the issue, perform the steps provided below.
Step 1: Hard Reset
To perform a hard reset, please follow the steps listed below:
1. Unplug the AC adapter from the notebook PC and remove from any port replicator or docking station.
2. Remove the battery from the notebook battery compartment.
3. Press and hold down the power button for about 20 seconds.
4. Insert the battery and plug the AC adapter back into the notebook PC.
5. Press the power button to turn the notebook PC back on.
This will discharge the static charges from the notebook. Now turn on the notebook and check for the issue. If the issue persists, then remove and reseat the memory modules of the notebook and check for the issue.
Step 2: Remove and Reseat the Memory Modules
You can refer the service manual provided below for information to remove and reseat the memory modules of the notebook.
http://h10032.www1.hp.com/ctg/Manual/c01602064.pdf
Refer page no: 52 & 53
NOTE: PDF manuals require the Adobe Acrobat Reader for viewing and printing.
Further, if the issue persists after performing the above steps, then the issue could be due to hardware malfunction of the video card or defective LCD display screen of the notebook. Hence, I recommend you to connect an external monitor to the notebook and then check whether the display works fine on external monitor or not.
Step 3: External Monitor
You can follow the steps listed below to connect an external monitor to the notebook.
1. Turn off the notebook.
2. Connect the monitor cable from the external monitor to the monitor port on the rear of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
At this time, please follow the instructions mentioned below for switching the display to the external monitor:
The notebook's video card supports three modes. Built-in screen only; external video only; and both on simultaneously (mirrored). If you're not seeing the image on the desired device(s), the notebook's video card is probably in another mode. Press FN + F4 to cycle through the display options: Notebook display, External monitor, both.
If you press FN + F4 once, the external monitor will display & there will be no Notebook LCD display.
If you press FN + F4 twice, the external monitor will display & there will be some shading on the Notebook LCD.
If you press FN + F4 thrice, both Notebook LCD & external monitor will display.
If the issue persists on the external monitor, then this could be due to defective video card on the notebook. However, if the display on the external monitor is fine, then the issue is with the LCD display panel of the notebook. In either cases, the notebook requires a detailed onsite diagnosis by a service technician.
I believe the information provided would be helpful to isolate the issue with your notebook.
5/23/2011 5:50:11 AM • HP G60t Notebook • Answered on May 23, 2011
My computer isnt recognizing that
Sounds like one of two things. Either you have a bad cord or the motherboard connection that facilitates charging is bad. The easiest way to determine this is to pick up a new cord and test it out. I recommend grabbing a Targus Universal Charger from Staples. The reason being, that if it doesn't work they have a very nice 14 day return policy without a restocking fee. If it doesn't work, you know you have a bad connection on your motherboard and proceed from there, which means bringing it to a reputable retailer for service.
2/28/2011 2:48:33 AM • HP G60t Notebook • Answered on Feb 28, 2011
Monitor is gray and can not get anything to come
your motherboard needs replacing
1/15/2011 3:50:32 AM • HP G60t Notebook • Answered on Jan 15, 2011
2answers
Screen is showing all lines, already replaced the
try and boot into safe mode, and see if that helps,tap f8 repeatedly and boot into safe mode, if it works it's a display settings problem and can be fixed in normal mode if it doesn't then i'm not sure where to go, i would bank on it being a display setting fault or new drivers need installed If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
12/31/2010 3:37:54 PM • HP G60t Notebook • Answered on Dec 31, 2010
When I tilt the screen on my laptop or pick up the
Yes most likely, its of a usb device being removed or attached. Or well, almost any device, my computer gives me the ding dongs when I plug in a monitor.
So yes you are right there is some device that gets disconnected and reconnected - its the Hardware found sound, see if you can see what device it is installing each time?
possibly a web camera?
12/1/2010 4:18:44 PM • HP G60t Notebook • Answered on Dec 01, 2010
Computer seems to be totally dead both on battery
I guess it could be hardware issue. It may well be worth taking it to a local computer store and ask them what the problem is. You should be able to get an opinion for free and a quote for the repair.
Could be the power jack is loose and that can be fixed by any computer professional at the repair center.
* Please rate this solution with Thumbs up and comment to help us improve providing support
11/30/2010 11:37:46 PM • HP G60t Notebook • Answered on Nov 30, 2010
2answers
My laptop heats up and the internal fan doesnt
hi
do not turn the computer on anymore -- you will damage the CPU and/or mainboard
what is the exact model of the laptop ? what is the S/N (located on back of your computer)
i can help you !!
11/3/2010 4:55:22 AM • HP G60t Notebook • Answered on Nov 03, 2010
Black screen w/ cursor
Which version of Windows are you running? It sounds like you may need to reinstall your operating system. It is fairly simple to do this with windows xp without losing everything you have saved and installed.
4/17/2010 6:49:39 PM • HP G60t Notebook • Answered on Apr 17, 2010
4answers
My Hp g60 laptop battery is not working
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced.
4/1/2010 5:07:53 PM • HP G60t Notebook • Answered on Apr 01, 2010
2answers
HP G60T notebook camera no longer works with
Sorry to hear about your problems with windows 7.
You most likely have a driver problem and you will have to find the driver at HP.com or driversguide.com.
Serach HP first, looking under windows 7 drivers for your unit.
If you have continue to have problems, contact HP.com customer care via email and they may have a better solution for you.
3/22/2010 2:50:16 PM • HP G60t Notebook • Answered on Mar 22, 2010
Wat megapixel is the built in webcam in the hp
It should be a 1.3MP webcam.
2/20/2010 4:04:28 AM • HP G60t Notebook • Answered on Feb 20, 2010
HP Laptop is asking for a pharphrase to get
Sorry, clicked the wrong button.
When you are configuring the security features of your wireless router, you can choose certain encryption algorithm that requires you to enter, not a meaningless hexadecimal character string (the hex key), but a sentence or a phrase that you can easily remember. That is the pass phrase. If you are trying to configure YOUR router, you choose any meaningful, easily remembered statement (ex: the sky is blue and it is raining on Timbuktu etc.). If however you are trying to use somebody else's network, the owner of the network is the one to ask for the key.
12/30/2009 3:22:16 AM • HP G60t Notebook • Answered on Dec 30, 2009
HP G60t Notebook Logo
31 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
adjust brightness hp laptop screen
  • Computers & Internet
