20 Most Recent
Gateway M-6750 PC Notebook Questions & Answers
Wont start
Gateway user guides are available at Gateway's web site. You need your compters information to access it.
Looks like a power supply issue.
Restore factory settings
Try to get into the BIOS using either F2 , F1 , F8 , or F10 when it starts to load .Once there , check it's boot sequence to make sure the hard drive was not removed from the load list . If it was , change it to be the first boot device , save , and then restart .
I have a gateway m-6750 notebook that i recently
Hi
are y ou on your own laptop now
can you get onto the internet using a ethernet wire from your laptop into your router
if so have you tried all the windows updates
this may find and update the wireless driver for you
you could also try to un install it from your device manager
then re start the laptop
windows may on start up re install it correctly for you
have you looked on the official website for a windows 7 wireless driver
or you could look on the realtek website they may have a wireless driver for you
many thanks
Gateway Laptop(MODEL M-6750):
The power button
Does it do this when it is plugged in? Try to power it up with no battery, and see if it acts differently, it may be a battery issue unsure. Is the computer working normally except for this problem?
My Gateway M 6750 Laptop powers on goes into bios
It is possible there is what is called a "root kit" virus on this system. You may have to take it into a computer shop. Alternatively, if you are a computer guru; insert the cd for the operating system. On the 6750 ; that comes with Windows XP. Go to the "recovery console" and then issue the command "Fixbook /mbr" which will rewrite the boot record; and solve the problem. Hope that helps, and best of luck.
Start the computer and it
The user settings are corrupted. Try to boot in Safe Mode and in there disable all programs that are loaded at boot.
If you can't boot in Safe Mode then the corruption is too great to fix, you will have to reinstall. If you need to recover/backup your files then , before reinstalling, boot with a Linux Live-CD and copy them.
I can get the disk tray open.
Is the drive being recognized in windows? If not at all then it may need to be replaced as it has totally died on you.
On the drive door there will be a pin sized hole. This is the 'emergency' release. You insert a paper clip or a pin and it releases the catch and the door will pop open. Do with with the power OFF. If that won't open the door then it is probably jammed or siezed. At this point you would have to pry it open which can cause damage to the drive if done too roughly. If you have something like a sticker or say two cd's in the drive then once you get it starting to open the trick is to firmly but gently and evenly pull on the sides of the door and then the body. Usually they will fight up to a point then open. When you get it open make sure you find and clear or clean the cause. The next time you have to open it may not go as easy.
If you need to replace the drive that is covered under warrenty or can be purchased third party for about $80 and up for a new drive.
My gaetway m6750 will not turn on
The issue probably may be power supply related. You can try removing the Battery and connect the Computer to direct power outlet. Reseat the RAM modules before sending to service depot
I can not see my desktop its too dim
The backlight in your display has gone out. Usually this is due to a bad inverter, although sometimes the lamp itself goes bad.
Replacing the inverter is fairly easy. It's a small circuit board at the bottom of the display. Remove the display bezel, unplug a couple of cables, put the replacement inverter board in and reassemble. There are several sources for inverters. eBay is a good place to start;
here's a sale going on now.
Replacing the backlight itself is much more difficult (it's built into the display), and it's usually easier to replace the entire display panel. Again there are several sources with prices in the range of $110 to $150.
Hope this helps. Thanks for using Fixya!
Gateway laptop M-6750 successfully logged
You will have to run a disc that came with the wireless router,or the plug in (brand name) disc,whatever you have.If the router was purchased(you purchased it)the directions will tell you how to configure the router.If the internet provider provided the router,then they should have the configuration.Try to go to where you see in the tray at the bottom,a picture of a computer,or something similar,and click on it,right hand corner on gateway,usally,may have to rright click on it.First choice is connect to
