20 Most Recent Gateway M-7315U Notebook Questions & Answers
I like to take my laptop apart and clean it and learn how is put together I use a small blower mini screw drivers a magnet to keep screws together I learn where the hard drive is and memory card is. my advice is if you decide to clean yours if you have the tools I would give it a try.
Gateway M-7315U... | Answered on Feb 04, 2018
If you get sound coming in and out or crackling when wiggling the wires, there is probably a poor connection at either the plug end or the buds themselves.
Gateway M-7315U... | Answered on Nov 03, 2017
Hi. What Operating system are you using. I have an article for you if you are using windows XP. Please click here.
Gateway M-7315U... | Answered on Jul 08, 2014
The fan could be clogged or have open circuit windings. I would order a replacement fan if it is faulty
Gateway M-7315U... | Answered on Nov 11, 2013
Will probably need to be replaced. Sorry.
con un disco de instalasion
Gateway M-7315U... | Answered on Mar 09, 2013
Has there been a spill? May be a hardware failure? Try re-installing driver at: http://support.gateway.com/us/en/product/default.aspx?partNumber=M-7315u Are ALL the Windows and Gateway Updates installed? May be a "fix" in the Gateway drivers list.
Gateway M-7315U... | Answered on Feb 05, 2013
Check out this WEB site - Hinges for Gateway laptops on the 'net,
http://www.laptoprepairco.com/Search/hinges/hinges.asp
Gateway M-7315U... | Answered on Nov 07, 2012
Sounds like the screen back light/lights are out or burned out. they can be replaced. ck You-Tube for vid on model and procedure for this.
Gateway M-7315U... | Answered on Oct 18, 2012
What are you trying to do? Connect to a tv? If so make sure you take the remote to the tv and press Select Input, then select HDMI as the input source (or it might be PC, but most likely HDMI). Then reboot the laptop and the display should be on the tv.
The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
Gateway M-7315U... | Answered on May 31, 2012
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Gateway M-7315U... | Answered on Apr 28, 2012
I had the same problem. Could be that the motherboard is retaining a charge. #1. unplug ac/dc adapter and also remove battery.#2. Press the power button and hold it down for 15-50 seconds. This will drain the board of any residual charge that may interfere with it powering up.#3. Leave the battery out and plug in the ac/dc adapter (to eliminate the battery being the problem) now press the power button. It should start up.
Gateway M-7315U... | Answered on Apr 05, 2012
There's one on Ebay here: Top Panel.
It's in Florida but ships world wide.
Gateway M-7315U... | Answered on Feb 20, 2012
Gateway M-7315U Notebook Logo
50 questions posted
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
M Gateway
  • M Gateway
Most Popular Question
gateway laptop
  • Computers & Internet
