20 Most Recent
MSI VR601 Notebook Questions & Answers
My laptop is standing o a laptop cooler and still
Hi Zelda, its not un-common. You will probably find that it is a build up of dust inside the laptop. So if you know someone with an air compressor, you can take out the battery keep the screen open and blow through the cooling vents underneath and on the sides. If not you could go to a service station where you would inflate your tyres on your car and take your laptop with you and a friend to hold it for you.Hope that helpsSteve
10/12/2013 2:12:42 PM •
MSI VR601...
Answered
on Oct 12, 2013
How to change a noisy fan in a MSI VR601?
On the bottom side of the laptop, there's a large separate plastic plate, when you unscrew all the screws holding that plate, you should see something like on that picture, I assume. Then you need to unscrew the screw holding cpu's heatsink (X shape thing) in place. Unplug the cable and you are halfway finished. When replacing the fan and the heatsink, be sure to apply thermal paste between cpu and heatsink.
10/18/2012 6:19:00 PM •
MSI VR601...
Answered
on Oct 18, 2012
How do i connect to wireless internet
depending on what type of computer you have you should be able to go to the bottom right of the computer and click on the bars that look like the picture, then find the network you want and follow the directions
9/19/2012 6:35:34 PM •
MSI VR601...
Answered
on Sep 19, 2012
My dvd rom is not
If you were to log on to the
manufacturer's web site, I think you will be pleasantly surprised as
usually one is able to download, by model number, Customer
Instruction Manuals, list
of Dealers,
for spare parts and service, Driver
downloads
and
Installation Instructions
as required.
Just Google the manufacturer's name and
follow the links. Make certain you are directed to the manufacturer's
web site as some search engines direct you to other sites and they
charge for the information that is normally free of charge.
I hope this helps.
12/16/2010 1:47:46 PM •
MSI VR601...
Answered
on Dec 16, 2010
Msi vr610 fan very noisy.how do i cure, get new part
Its a typical failure of MSI fans from those times. Unfortunately the exchange part will not solve your problem. (I read it in comments lots of times.) I own a VR610 and fixed the problem with grease. I disassembled the fan and took out the paddle wheel. I cleaned the pin and the hole both and filled the hole with grease. I used small portion of (lithium based) grease like on bicycle. The fan is noiseless since 1,5 years. :)
11/9/2010 5:36:44 PM •
MSI VR601...
Answered
on Nov 09, 2010
Maybe I pressed the wrong key or something but out
You have activated most likelly with "Fn" <capslock> those tiny small ciphers on the keys nobody normally tazkes notice of and not all keyboards have them. Unlock by pressing Fn <capslock> again. Some laptops have exrtra keys for locking the keyboards. in case you have - try those.
7/26/2010 8:53:32 PM •
MSI VR601...
Answered
on Jul 26, 2010
Where to buy VR601 fan?
try this hopefully it will fit
http://cgi.ebay.com/MSI-WIND-U100-U120-CPU-Fan-E32-0800110-S69-6010L05F-/170475993015?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item27b12937b7
or try
http://shop.ebay.com/i.html?_kw=MSI&_kw=Megabook
4/28/2010 3:59:57 AM •
MSI VR601...
Answered
on Apr 28, 2010
How to remove partitions on hdd, msi notebook?
-- Back up any data on the partition that you wish to remove, as this process will erase any data in the removed partition.
-- Close all programs once you have backed up all your data. Right click on "My Computer" in your Start Menu and select "Manage." If using Vista, select "Continue" when prompted for permission.--
Select Disk Management from the left-hand menu. This will open the disk manager interface.
-- Select your desired partition by left clicking on it once. Then right click on it and select "Delete Volume (labeled "Delete Partition" in XP). You will be prompted as to whether or not you want to continue and warned that all data will be lost.
-- Select "Yes" at the prompt, and your partition will now be deleted.
4/2/2010 11:36:02 AM •
MSI VR601...
Answered
on Apr 02, 2010
Have msi lap top vr601x model when try turn on by
the half moon indicate an sleep mode when you open your laptop the sleep mode is already activated thats why it goes to shutdown reason is your sleep mode key is grounded try to consult it to your your dealer
9/17/2009 7:02:16 AM •
MSI VR601...
Answered
on Sep 17, 2009
Need a driver
what is the model ?and try to google it.with model number or model name.
5/20/2009 5:08:41 PM •
MSI VR601...
Answered
on May 20, 2009
