20 Most Recent Broan-NuTone N-LS100SE Exhaust Fan Exhaust Fan Questions & Answers
This is a hassle. I have had to replace several of these and it seems they come up with a new motor/model every few days. Seriously, call them and ask if there is a replacement motor for that unit. There may be. They may also give you a recommended replacement. this is usually a different size by a bit. You just have to trim some of the sheetrock to get it to fit. unless you can only find one that is smaller. I use caulk around the edges to get a good seal and cover up. You can also try cleaning the "fan" part of the unit. this often gets dusty and becomes off balance. A good cleaning and one or two -small- drops of oil may buy you some time.
Broan-NuTone... | Answered on Jun 14, 2018
Try Home-Depot replacement fan kit or www.electricmotorwarehouse.com/aosmith/nutone/nutone.htm
The additional wires are for a starting capacitor, not included with the motor. The easiest way to hook-up is to order the Outlet Assembly p/n 88617000 (available at Coastal Tech Supply.) The assembly includes the capacitor, connector, and shroud; and will replace the existing outlet assembly in the housing. Minor electrical work is required to remove the old assembly and install the new one.
Hello :
You should sniff the motor first . If there's a bad smell , then the motor is burned . You
If you can fix it by yourself , then dissemble the unit, remove the motor. Loosen the bolts running from end to end of the motor and with emery cloth, clean the small metal plates on the ehd of the armature. They should be bright copper color. If the armature is burnt, they will be dull brown. The other thing is to replace the brushes in the motor . Or take it to a repair shop if you are not sure that you can fix it by yourself .
good luck .
please rate !
Packard Electric Motor Company model # 65345 is a direct replacement motor for the nutone LS100SE. It can be ordered from Conrey Electric Inc in Portland OR.
Broan-NuTone... | Answered on Apr 26, 2015
The motor is a common item to need replacement in bathroom vents. Replacements can be found just about anywhere that deals with electric motors. You might even be able to get a replacement where you originally purchased the unit. There are dozens of web sites that you can locate a replacement. http://www.electricmotorwarehouse.com is just one. Simply do a web search on replacement bathroom vent motors. Also if the are able to purchase items from wholesale vendors you can get one from Grainger's. It should cost around $20 to $25
Part # 62345-000 (replacement motor part #).
However there is an alternative to replacement. This depends entirely on how handy you are with these kinds of things and how bad off the motor is. If your not comfortable with repairing this kind of thing don't bother with the rest of this.
I hate to replace anything that may be repairable. Unfortunately my friends know this and recently one asked me to look at his NuTone bathroom vent motor before he replaced it.
For the cost in time of an hour I was able to refurbished it.
A good way to check if it's a candidate for repair is to check how much play is in between the shaft and bushings. If you can feel movement then it's best to go ahead and replace it. If the problem is that the shaft is tight and just hard to turn then it may just need some cleaning and fresh lubrication.
The steps are simple. Once you have the motor removed from the vent cage you will see a pair of nuts and bolts holding two brackets in place. These brackets(one on either side of the coil) are what hold the shaft centered and house the bushings. Remove the bolts and the brackets. Be careful not to lose any of the washers on the shaft. These are spacers and need to be replace the same way they went on if they come off. All you need to do is clean both ends of the shaft put a little oil on the shaft and in the bushing and put it back together. If the motor has a plug and not just bare wires for reconnecting to the power supply then it's safe to just plug it in to any outlet for testing after you remount it in the vent cage. You will know right away if you were successful.
Hope this helps.
Broan-NuTone... | Answered on Feb 12, 2015
Exact replacement can be purchased at:
CONREY ELEC. MTR REPAIR 1903 S.E. 7TH AVE.
PORTLAND
OR
97214
Phone: 503-232-9392
Fax: 5032322421
The fan/motor part of the Broan fan is replaceable. They are actually very simple to take out and install a new part.
The part can be easily purchase here...
http://parts.broan-nutone.com/broan/Shop
Heatman101
Sounds like you need motor replacement assemblies. take a look on amazon for it. Amazon com nutone qt 110n motor. Hope this was helpful. cheers
Broan-NuTone... | Answered on Nov 25, 2014
Is the LS 100 you purchased complete or motor only? i would buy it from you if it is the complete unit. 907-232-2142, thanks
Broan-NuTone... | Answered on Sep 24, 2011
Broan-NuTone N-LS100SE Exhaust Fan Exhaust Fan Logo
53 questions posted
Top Broan-NuTone Dryers Experts
jws1013
john h
k24674
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
View Most Popular
Broan-NuTone Dryers
  • Broan-NuTone Dryers
Most Popular Question
replace motor in broan 683c 2 0 sones
  • Dryers
