20 Most Recent Lenovo ThinkPad R400 Notebook Questions & Answers
Stuck key error means that one or more keys on the keyboard are stuck. It's possible that a liquid spill can also cause one or more keys to electrically "short" causing the error. Inspect the keyboard and check if any keys are mechanically stuck.
If you're mechanically handy you can remove the keyboard, inspect any chances of damage or corrosion. Plug it back and see if error is still occurring.
Reset BIOS to default settings. Perform Flee Power - remove the battery and any other peripheral device connected to the computer. Hold the power button for 10-15 seconds and then connect only the AC Adapter and turn ON the computer.
Lenovo ThinkPad... | Answered on Aug 19, 2016
depending on the format of the document you might need a separate program to read. .file extension "txt", ".doc" should work on a standard windows PC. "docx" (newer office format might need a different program (google for "word viewe"), for ".pdf" google for acrobat reader
for a comprehensive list o file extensions and the programmes which created them check the link:
Lenovo ThinkPad... | Answered on Jul 04, 2016
Hello Scott,
Make sure that there are no objects placed on the keyboard, or
if you have one, the external keyboard. Turn off the computer,
and turn off all attached devices. Turn on the computer first;
then turn on the attached devices.
If an external keyboard is connected, do the following:
v Turn off the computer and disconnect the external keyboard;
then turn on the computer. Make sure that the built-in
keyboard operates correctly. If it does, have the external
keyboard serviced.
Make sure that the external keyboard is connected to the
correct connector.
Please feel free to ask me if you any further questions or concerns.
Also please rate me if you like my answer, that helps me alot.
Thanks.
Lenovo ThinkPad... | Answered on Jul 10, 2014
Sounds like you have a faulty ribbon cable or the ribbon cable it needs re-attaching to the motherboard.
Lenovo ThinkPad... | Answered on May 08, 2013
Lenovo ThinkPad... | Answered on Nov 27, 2012
hi mmi300, try to press Fn + F5 and check if it works. Pls determine if there is a toggle switch (if it is a laptop) somewhere. Disregard that step if it is a desktop...
Hope this help...
Lenovo ThinkPad... | Answered on Nov 26, 2012
The WEBcam driver needs to be installed first before you can access the WEBcam.
The same model ThinkPadcan have different types of network, video and audio drivers and unless youknow exactly which one is installed in your ThinkPad, you need to download allthe drivers and install each driver until you find the right driver. When you download thedrivers, write down the device driver and it's file name so you have a recordof which driver you are installing and which directory the unzipped files arelocated on your hard drive. Go to the IBM/Lenovo WEBsite - support/download page and download the latest Windows device drivers foryour model computer, Use this link: - http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true
Lenovo ThinkPad... | Answered on Jun 23, 2011
when you first power on the laptop you need to press f1, del or f2 to enter the bios
Lenovo ThinkPad... | Answered on Apr 09, 2011
my computer devive manager hardware check if there is a driver for pc camera...if you successfully see it go to program files find pc camera folder clik it if you found amcap looks like a video cam... send it to the desktop as a shortcut to view your webcam easily..
Lenovo ThinkPad... | Answered on Feb 02, 2011
We ran a typical Thinkpad T400 battery of tests, including games, applications, and a couple other areas. Time constraints limited the amount of testing we could get done before the NDA lift (and it's already a few hours late), but we will be providing a follow-up article with further testing and information. That said, if there are any specific areas that you'd like to see tested, feel free to e-mail me or leave a comment.
Lenovo ThinkPad... | Answered on Nov 17, 2010
Computers always boot from the hard drive.
The Bios on the mother board have a routine that tell it to boot from the Hard Drive, or USB in the BIOs setup.
to look at the BIOS setup, when you turn it on keep pressing the <ctrl><alt><del> keys on your key board, this should let you go into BIOs setup. there you can check which device it the first boot, second boot and third boot.
If your hard disk the boot, it is probably crashed, you will have to take it in to be repaired, and you might need a new hard disk.
in which case the repair shop will have to put in a new hard disk, format it as bootable, then reload the operating system, and any software you might have been using, so take into the shop all cd software disks with the computer to the shop so they can reload all your stuff. If there were any files you had on the disk, they may or maynot be recovered.
Good Luck...
Lenovo ThinkPad... | Answered on Nov 11, 2010
for that you have to open ur laptop its a coin type of 3volts which is easy to open??But if you can open ur Laptop??otherwise it will be worst experience for you
Lenovo ThinkPad... | Answered on Sep 19, 2010
The best way to know what you need is to search for it on the web type in "Thenameofyourcomuter""specs"
if your comptuer is the Lenovo ThinkPad R400 notebook
then your specs are
RAM Configuration Features 1 x 2 GB Memory Specification Compliance PC3-8500 Technology DDR3 SDRAM - 1066 MHz Installed Size 2 GB / 4 GB (max) Form Factor SO DIMM 204-pin
Witch means its only upgradable to 2 gigs.
to see what is in thier now start your computer up, Go to my computer, right click on it and go to properties. Under that it will show information about your comptuer.
Lenovo ThinkPad... | Answered on Dec 20, 2009
If your webcam is working, just not in Messenger...
  1. Click on the Show Menu button within Messenger (Top right side of the window).
  2. Got down to Tools\Audio and Video Setup.
  3. Click Next on the Audio page after confirming settings.
  4. This is the webcam page, ensure your webcam is listed here (it may say disabled).
  5. Click Finish.
Lenovo ThinkPad... | Answered on Aug 31, 2009
Error 0250 means that the BIOS battery is dead and has to be changed, they are usually located hidden in the memory panel underneath the laptop and can be covered in red, blue or yellow plastic.
To boot into windows hit the F1 key when you see the IBM logo, go into the BIOS utility and set the time and date, save the changes and exit the BIOS, make sure you have AC power plugged in when you do this as it will not remember the time and date and you will have to do it again.
Good luck.
Lenovo ThinkPad... | Answered on Jul 01, 2009
Yes you can download Whatsapp on your Laptop by follow simple steps.it is very easy to download it on your PC by using some emulator WhatsApp FOR PC WINDOWS AND MAC .Download Whatsapp from this link..
Also download fresh Android App on your PC Such as Asphalt 9 from this link.. Asphalt 9 FOR PC WINDOWS AND MAC
Lenovo ThinkPad... | Answered on Jul 31, 2020
Lenovo ThinkPad R400 Notebook Logo
Popular Tags
25 questions posted
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Toby Lee
Toby Lee
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ThinkPad Lenovo
  • ThinkPad Lenovo
Most Popular Question
am unable read attached documents please
  • Computers & Internet
