20 Most Recent
ASUS F80Q-X2AM Notebook Questions & Answers
My Laptop specifications are, ASUS
Seems like your Bluetooth and Wifi settings are disabled from BIOS.
On laptops usually there is a setting in BIOS where you can disable/Enable Wifi+Bluetooth.
Shutdown computer
Turn on computer and press "F2" to go to BIOS settings
Find settings for Wifi+Bluetooth and set it to default.
Save settings and restart computer
You will be able to see your Bluetooth and Wifi.
Hope this works
MY ASUS F80Q WONT start
Hi.
First option: For that symptoms try restart PC then before booting press F8 to see.(for windows xp professional and home edition. operating system )
safe mode
safe mode with networking
safe mode with command prompt
enable booth logging
enable VGA mode
last known good configuration (your recent settings that worked) select this option by highlight then press enter key.
if same problem? restart PC again then select safe mode wait for booting.
already use that option not yet happened same problem.
Second option:You need to reinstall fresh installation of operating system like windows xp,windows vista,windows 7 version etc.
Hope can help you.
Shutting down when playing games
HI there, this sounds like an overheating issue, look on the base of the machine for access panels, remove these and look for your fan. Chances are that it will be quite dusty. Clean this to the best of your ability and also remove the fan to clear the gap between it and the heatsink (a lot build up here) Put it back together and try again.
Hope this helps
Asus f80 can't start. when connect to power
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Hello, I can't install my os it says the BIOS is
Check the computer manufacturer's website for a flash BIOS update. ACPI is an onboard power management program that works with the OS to turn devices on the motherboard on and off as needed in order to conserve power. Modern OSs require this function to operate correctly. The update will come with instructions for installing it, and you must follow them exactly, else your computer may become unusable.
If no update is available, you'll have to revert to the original OS to use it, as there is no way around this that I've heard about. ACPI has been standard on PCs for over 10 years, and it's unlikely that any modern OS will work on a PC without it.
How do I enhance my Asus PadFone X mini speaker loudness?
Look for a program called Sound Booster or one called DFX. DFX is my favorite because it not only boosts the volume, but lets you add other effects to enhance you sound as well. There is a free version. but to get all the effects you have to upgrade to the paid. If audio is important to you, check it out.
