20 Most Recent
ASUS G71G-Q2 Notebook Questions & Answers
Can I replace my usb ports
Yes, they can be replaced but if you don't have technical knowledge to dismount a laptop beter don't try to do it. You might end with a shoebox full of parts you don't know how to mount again but it should not be an expensive work for an experimented technician,
ASUS G71G - my LCD
Check out www.insidemylaptop.com for pictures but if you remove the four rubber bungs in the corners of the display bezel and then remove the screws, the front bezel will come away from the screen allowing access to the wires. I suspect there is a plug hanging out.
Hope that helps.
I lost my latop's webcam (ASUS Life
Webcam can be used from the IM application by configuring the options of the IM app.
Should you want to use the webcam to make a video then you can find the name of the app in the Control Panel - Scanners and Cameras.
I have brought Asus G72 for almost a month and now
This is a link to the driver you need to download in order to get your printer working.
Click on the download tab and select the driver which is for your operating system e.g. Windows XP, Windows Vista. After it is downloaded plug in your printer and install the driver which you downloaded. Printer should be up and running after theat.
I have windows Vista. I get a black screen when I
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
How can i bring asus G71G back to factory after i
Hello and thank you for using Fixya!
You will need to order the restore disks from the manufacturer. They usualy charge around $30.00 (US) plus shipping.
These are always great to have "just in case" you need them in the future. You can call the Asus support or visit them on the web.
Jennifer
My mouse won't work
ned to go to device drivers and and on usb root hum right click and deselect all the power management option under power management tab and restart the system
Pc doesnt recognize cd burner but drive works fine
have you tried going to windows update and do the custom usually they go thru your comp and tell what drivers you need , there good about that usually it should recognize the letter designation my comp gives it right click that drive and check properties and see it there is any conflicts and check if you can get any updates on drivers for that burner can also try the website of the comp for updates could be an issue prob
ASUS G73jh Start-up Power BUTTON Problem
Hello ,I can take remote access of your system and fix issue for you, one time charges USD 30; pay only if issue is resolved.
Call me at
OneEighthundred,ThreeThreeNine,NineSixThreeFour (Free number).
My Name is Harry.
Msata asus g55vw
if you're asking "can it be done" then the answer is yes but it is not easy. if your asus is still under warranty, adding an msata drive or RAM on the otherside of the motherboard will void your warranty, if that is not your question, please elaborate.
