20 Most Recent Acer Aspire 6930-6941 Notebook Questions & Answers
Completely wrong! I am trying to reset the superviser password which enables you to reset boot sequence etc at the moment most everything is greyed out and one most have the supervisers password; not! the user password; hard drive password or windows log in pass word ! Pressing f8 several times does not work and the cmos battery is nowhere to be seen ;not under wireless card or memory chips so how about someone who knows what is what coming up with real info! Using third party programes to reset windows password ineffectual as the computer must boot up from a usb stick with appropriate software to interrogate the password but I cannot alter boot sequence as of now! we are now talking about the candy windows password not the bios passwords that originally gave me this problem as I sent the computer back in time to an earlier config but the password went into the ether! ok. I tried all the old passwords all to no avail!. All this to see if the wireless card was working as it seem to be away without leave! or my modem /router is kaput in the wireless department! There is a hint of an advanced Bios setup but can't access it!
Acer Aspire... • Answered on Dec 04, 2015
just unplug the charger turn off your laptop then after 5 to 10 mins turn it on. the color of the power light will be blue again
Acer Aspire... • Answered on Dec 09, 2014
Try removing the main battery and unplug the power, then hold the power on button down for 30 seconds, if this does not work, remove the cmos battery for 30 seconds to reset the bios
Acer Aspire... • Answered on Apr 28, 2014
Go here and use the vista drivers.http://support.acer.com/product/default.aspx?modelId=571Or this.http://www.innovative-sol.com/drivermax/
Acer Aspire... • Answered on Feb 17, 2013
first put the cd that comes with your printer and install all the drivers and software then after this is done plug in a usb cord. take a usb printer cord plug in the one end that fits your printer and the other end is for your laptop plug it into your usb port and thats it
Acer Aspire... • Answered on Sep 28, 2012
Located beside the keyboard are application buttons. These buttons are called easy-launch buttons. They are: WLAN, Internet, email, Bluetooth, Arcade and Acer Empowering Technology.Looks a bit like a magnifying glass outline above a small eliptical spot.If its the right model I am thinking of, hope it helps
Acer Aspire... • Answered on Aug 15, 2012
What steps have you taken so far?
1) Battery correctly inserted/charged?
2) Adapter correctly connected and switched on at wall socket?
I'm just hoping that these straight-forward tips will fix it... otherwise you may need to return it for someone else to physically inspect it.
Cheers!
-BuzzPuppy
Acer Aspire... • Answered on May 01, 2011
possibly your power supply is defective or it can be the actual component you plug into
Acer Aspire... • Answered on Mar 01, 2011
It could be that you may of missed a step which when you are installing all programs except the install should be closed. Try that and you should be fine.
Acer Aspire... • Answered on Feb 24, 2010
Well most only have 1 adaptor.
Look in ctrl panel system DEVICE MANAGER and see if there is more than 1. Also check that it is working properly and that some other item is not using the same port.
Update the driver from the internet and see if that helps.
Please rate my help in this matter++++Thanks for using FIXYA
Acer Aspire... • Answered on Feb 07, 2010
I am assuming that you mean the CD-Rom Drive. You need to replace this. Take it to your local repair shop, describing your problem.
Acer Aspire... • Answered on Dec 31, 2009
i was JUST having this prblm!! okay, go to START and then ALL PROGRAMS. after u click that, find ACESSORIES but dont click it! look a little bit below it and u should find something like "Acer Crystal View Webcam" or something similar to that (i have an acer so urs might say something different depending on wat ur computer/laptop's maker is). i hope this helped!!
Acer Aspire... • Answered on Nov 02, 2009
There has to be another bluetooth device within range and turned on before it can find a device or of course you will get that message
hello
Try using external USB HUB (POWERED) Adapter. It might fix this issue.
Use an other USB cable and see.
If the problem still exist do not plug in the printer again, you may damage your USB port or even burn your laptop motherboard.
hope this helped
TekSpotDotCoDotUK
Acer Aspire... • Answered on Aug 31, 2009
Sir,
The Keypad is jammed or congested. Better call the Local Laptop service engineer to serice the keypad and get it corrected. If the machine is under warranty, the keypad alone will get replaced with new one by the Dealer. Otherise, small amount can be paid for the new keypad to be installed in the machine
Acer Aspire... • Answered on Jul 15, 2009
Acer Aspire 6930-6941 Notebook Logo
Popular Tags
27 questions posted
Steve Sweetleaf
Steve Sweetleaf
Michael Thomas
Michael Thomas
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
connect hp officejet 5610 printer acer
  • Computers & Internet
