20 Most Recent ASUS Eee PC 1000HE Netbook Questions & Answers
2answers
Hard drive is locked, enter user password
Download a "password recover program" that will either tell you your password or reset it so you can log in. These are free ware hacker tools so do your research, follow the directions, and most of all, proceed at your own risk.
7/31/2021 8:13:22 PM • ASUS Eee PC... • Answered on Jul 31, 2021
I have a grey startup screen with "Press F2 to run
hello hyjacker this post and OPS other identical post on why F2 repeats, this is COMMON !first take out that relic and bad large battery.run on AC pack only, still dead??http://pcdied.com/dead-PC.html the PC is now 9 years old the RTC COIN CELL BATTERIES, mostly do not go past 7 years, seen 10 happen, but is not PAR, life span is 5 to 7 years.! facts. so replace that first, then reset bios next.and test on AC Pack only, until the PC runs right again do not use the useless 9 year old HUGE BATTERY, oK? then make sure boot order in BIOS shows HDD , in the list. or the HDD is dead. the coin cells dead will cause many PC to stick at BIOS screens, after all it cant find the boot order configurations with that battery dead. once that is cured, you can boot windows if the HDD still works. on some pCs you can hit F2 and it loads BIOS defaults and boots. but after powering down, all that is lost and all this above repeats. the service manual on your PC covers this.but I can not find that manual anywhere... how to replace your RTC Coin cell.? here it is, remove any hatches to reach it.RTC is on the bottom see yellow blob this is your exact mobo.this is the bottom side of moboopen hatches on bottom of PC to gain access.I see 1 huge hatch in our manual, at asus.no 2 laptops are the same unless they are exact model. so learn to find it using below photo.1000-54slybwvyvycblkfrjbfkjej-3-0.jpgtop-1glt2d3m4v3sn4mfxc1uwfzh-5-2.jpg
7/12/2020 8:31:29 PM • ASUS Eee PC... • Answered on Jul 12, 2020
My Asus eee pc he has a battery problem.
check power switch botton
3/27/2019 12:30:38 AM • ASUS Eee PC... • Answered on Mar 27, 2019
2answers
Asus eee pc 1000he shut
Did you get any warning at all, or did it just stop for no reason, please? If it shut off while on battery power, what happens when you try to run it off the mains?
11/29/2017 9:14:45 PM • ASUS Eee PC... • Answered on Nov 29, 2017
I had to reinstall driver
Hi Ali. you could try this or go to the link at the bottom and have a read up of what else you could try. Push the computer's F9 button until the Recovery System window appears. Choose the option for Windows Setup and select Recovery. You should see a message disclosing that you will lose all your files in the process as the Recovery puts the machine back to its original factory settings.
How to Restore an Asus Eee PC Netbook ' eBay
www.ebay.co.uk/gds/How-to-Restore-an-Asus-Eee-PC-Netbook-/.../g.html asus eee pc 1000he netbook restore factory settings Google Search
11/4/2017 6:14:43 PM • ASUS Eee PC... • Answered on Nov 04, 2017
How do I reboot my asus eee pc tablet / laptop? (LIKE NEW)
you will have to get his password to get in to alter anything
10/29/2017 9:23:23 AM • ASUS Eee PC... • Answered on Oct 29, 2017
Asus eee pc netbook randomly loses connection with wireless, then has to be restarted
Then the problem is with the notebook, have it repaired or replace it.
5/3/2017 6:05:11 PM • ASUS Eee PC... • Answered on May 03, 2017
0answers
0answers
3answers
How can i activate the webcam on my asus netbook?
for activating the webcam of your netbook you need to install the driver of your webcamera and you can easily use your [email protected]@.
8/16/2016 12:36:57 PM • ASUS Eee PC... • Answered on Aug 16, 2016
How to turn on wifi? Its been 2 -3 days wifi isnot being loaded?
Press and Hold the FN function key then hit F2 while holding the FN Key down.Maybe you don't have your wireless turned on. Look onboth sides and in front for the Wireless Switch and turn it on.Also once the wireless switch is turned on there are keystrokes that can togglethe wireless on or off. Normally you would Press and Hold the FN functionkey located at the lower left of the keyboard, then hit the correct F1 thru F12key that toggles the wireless. The correct F1 thru F12 key to hit willhave the wireless signal icon )))) on it. Or it might have the icon of a towerwith the wireless signal icon )))). Normally the screen will displayWireless On or Wireless Off when you toggle the wireless.
6/5/2016 4:12:35 PM • ASUS Eee PC... • Answered on Jun 05, 2016
2answers
Where do I find the serial number
Hello and welcome to FixYa;
It will come on the box the machine was purchased in;
will be on a sticker on the bottom of machine or next to the mouse pad on a sticker (usually on bottom)
but if all else fails;
The machine's s/n is the same as the battery's. Remove your battery from computer and look on there.
Let me know how this worked out for you. If my solution helped you, please rate this solution!
It doesn't cost anything and only takes a second, but it is greatly appreciated.
KittyTech If you need further help, reach me via phone at https://www.6ya.com/expert/carolyn_427ff26936286336
2/10/2015 6:52:18 PM • ASUS Eee PC... • Answered on Feb 10, 2015
Driver not installed ACPI\ASUS010\1010100 asus eeepc 904hd
Find every driver you need (including for eeepc 904HD drivers) with this tool driverupdate us. It's free too. Best of luck
11/1/2014 10:47:02 PM • ASUS Eee PC... • Answered on Nov 01, 2014
How to activate webcam on asus pc1000he
Press the Fn-key + V
10/21/2014 3:07:27 PM • ASUS Eee PC... • Answered on Oct 21, 2014
Where is the wireless switch
You can enable/disable wireless by pressing the Fn-key + F2
10/21/2014 2:36:35 PM • ASUS Eee PC... • Answered on Oct 21, 2014
2answers
Wifi wont connect
Are you certain you have the small WiFi switch turned to the ON position? You can usually find the small button on the left or right side of the body of your laptop, just below the monitor.
7/18/2014 4:42:29 AM • ASUS Eee PC... • Answered on Jul 18, 2014
8answers
Mini notebook 7'' freezes on startup and says loading OS image
You will need to download one or the other
http://zeng.h1.28823.cn/VT8500Software.rar
http://zeng.h1.28823.cn/VT8505Software.rar
Please do as follows:
1.Extract files to your hard drive and only copy the script folder to a SD card, not the (VT8505 or VT8500 folder).
2. Turn off your netbook,
3. Insert the SD card to your netbook.
4. Turn on your netbook. Then the software will setup to your netbook Automatically.
5. After completed setup. It will show a windows screen calling for your to turn off the netbook.
6. Pull the SD card out off the netbook.
7. Then turn on the netbook and all should work fine
To God Be The Glory
6/20/2014 3:41:50 PM • ASUS Eee PC... • Answered on Jun 20, 2014
Netbook gets stuck "cycling" between shutdown and restart
go to the powermanagement in the control panel. In it check the settings to turn off system when i press, or shutdown the pc after 30 min change it to never, and turn harddisk off to never. and remove the system from hibernation
4/18/2014 10:59:49 PM • ASUS Eee PC... • Answered on Apr 18, 2014
ASUS Eee PC 1000HE Netbook Logo
349 questions posted
Top ASUS Computers & Internet Experts
Marvin
Marvin
Steve
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Eee ASUS
  • Eee ASUS
Most Popular Question
driver not installed
  • Computers & Internet
