20 Most Recent Acer Aspire One D150-1587 Netbook Questions & Answers
Hi
Yes it can handle 4GB RAM.Thanks
Acer Aspire One... | Answered on Mar 09, 2020
All solutions point to having to contact the drive manufacturer or laptop manufacturer. There is good explanation in the Tom's Hardware thread at the end, about a 'master password' ...
4.June.2014
Hard disk security primary master lock
harddisk security primary master lock
Acer Aspire One... | Answered on Aug 15, 2015
Hi , maybe this might work for your acer,
Go to acer recovery.This can be done by hitting Alt & F10 together as soon as the computer starts.
Hit hard disc recovery.
Follow the instructions and this will format the drive and reinstall the factory settings. hope this helps
Acer Aspire One... | Answered on Jan 27, 2015
You should need nowt on startup except something like skype
Acer Aspire One... | Answered on Nov 30, 2013
Activate the Bluetooth features of your Acer Aspire to unlock your laptop's wireless function. Bluetooth technology allows your computer to control and share data with external devices without having to use a connection cable or download drivers.
In order to establish the connection with other enabled devices, you must first enable the Bluetooth antenna so other devices can locate your computer.
Press the "Bluetooth" button found just above the keyboard.
The LED above the button should illuminate.
Click "Start," "Control Panel" and "Add a Device."
Your Acer scans for other Bluetooth devices in the area.
Click the name of the device in the window that appears, and click "Next" to establish a connection with the external device.
Acer Aspire One... | Answered on Aug 04, 2013
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Acer Aspire One... | Answered on Jan 20, 2013
The options are Acer Factory disk.Usually can be had, for a price ($20.00 or so) with your SN on your computer from ACER support. If you have "totaly wiped the drive" the software is gone. It will not restore/recover with the HDD "wiped". If you have a different OS it should load. A free OS can be found here: http://www.ubuntu.com/download Or take a look at this, you have to purchase a product key : http://www.tipandtrick.net/2008/original-msdntechnet-windows-xp-with-sp3-integrated-retail-vl-cd-iso-images-leaked/ OR http://www.tipandtrick.net/2008/windows-xp-sp3-kb936929-standalone-update-package-and-iso-images-official-microsoft-download-links/
Acer Aspire One... | Answered on Dec 03, 2012
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Acer Aspire One... | Answered on Oct 15, 2012
On help and support menu, type restore system. You will get an option to what date your OS will restored. Make sure you decide the correct date ( when the OS is still working fine). Key in the date ( or choose the preset date) the enter. Wait for process done completely. Your OS should be restored now.
Acer Aspire One... | Answered on Oct 08, 2012
Try connecting with cable RJ45 from ISP modem to establish that all is ok.
Acer Aspire One... | Answered on Aug 28, 2012
the exhaust fan might not getting work.
Acer Aspire One... | Answered on Aug 11, 2012
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Remove the battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Acer Aspire One... | Answered on Jun 09, 2012
If you keyboard stuck and you are not able to do anything. Please shutdown your computer. Unplugged all the external device. Like external harddrive,pen drive, camera anything. And now plugged in back and check it is working.
Acer Aspire One... | Answered on May 22, 2012
Your only solution is to have the laptop keyboard replaced.
Acer Aspire One... | Answered on Mar 19, 2012
have you tested the microphone with another application like windows sound recorder? if not i recommend you try that and verify the microphone is functioning. if it is then go into yahoo chat and check your options and verify you have the correct sound device selected for voice input.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Acer Aspire One... | Answered on Feb 27, 2012
I can only think that you have either dropped it or given it a bash, as it sounds as though your harddrive is disconnected. Although it could be your mainboard or a failed hard drive. Take it to a computer repair technician and get it tested. Good luck.
Acer Aspire One... | Answered on Jan 22, 2012
Click here
Click on above link select os and download driver for your model .
then install there are more than 1 camera driver for your laptop so install 1 by 1 if you not know the camera chip company.
Let me know if you need further assistance.
Thanks for using FixYa.
Acer Aspire One... | Answered on Dec 31, 2011
Acer Aspire One D150-1587 Netbook Logo
100 questions posted
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
Michael Thomas
Michael Thomas
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
restore acer aspire one d150
  • Computers & Internet
