20 Most Recent Toshiba Satellite Pro U400-S1001V Notebook Questions & Answers
Is there a fan close to it?
Toshiba... | Answered on May 06, 2015
That's a bit warm for idle. Here are some things to do and check:
1. Make sure all your internal fans are running.
2. Are you using it on a soft surface like a bed or pillow where the
exhaust vents are being partially covered up?
3. Go into Bios and tweek your fan speed settings. Raise the speed of
the fans if you need to. Some manufacturers set the speeds low to
keep noise down.
4. Get a laptop cooler (I Highly Recommend this).
If you do decide to get a laptop cooler you can always get a good deal at www.newegg.com. Newegg is one of the best and most popular computer/tech stores on the web.
Here is a link to their laptop coolers:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007639%20600028834&IsNodeId=1&bop=And&Order=RATING&PageSize=100
Toshiba... | Answered on May 30, 2012
It is probably a driver issue. First check the device manager, from the Control Panel. A red triangle with an X or a yellow triangle with an exclamation point indicate that the issue is with the driver.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Download will let you search for your model and download the XP sound driver.
The specific driver may be: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2043975&rpn=PSU41U&modelFilter=&selCategory=3&selFamily=1073768667# (using the Satellite Pro U400-S1001V above)
I hope this helps.
Toshiba... | Answered on Jul 16, 2010
Yes it is, seems there is some problem with the power state detection and changing of the load mode. Might by a physical problem, so I am not sure you can fix it.
At least check your power plan details and see if there is any error with the ACPI devices in the device manager.
In general, if you use the laptop when plugged, you should take out the battery to maximize the battery life (prevents useless load cycles).
Also configure Windows to optimize battery usage.
Toshiba... | Answered on Jun 04, 2010
Start system and when you See Windows Welcome screen / Login screen, press ctrl+alt+del keys Twice and it?ll show Classic Login box. Now type ?Administrator? (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from ?Control Panel -> User Accounts?.
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
if you are locked out of your computer,then a password recovery utility is available for you
check this out:see how to recover lost password?
Toshiba... | Answered on May 31, 2010
You need to refer it to a qualified servicemen in your area. The problem can't be solve online. You have to replace your main board.
Thanks. Cheers!
Toshiba... | Answered on Apr 21, 2010
try to clean boot your computer.
  • on safe mode, click start > run > type msconfig
  • you have several tabs there, go on Startup tab, click on Disable All button
  • go to Service tab, it's on the right of Startup tab, put a check mark on "Hide all Microsoft services". make sure you have a check mark there. then click on Disable all button.
  • click on Ok
  • the computer will ask you if you want to restart or exit without restart, restart the computer
  • when you see your desktop after restarting, put a check mark on "Don't show this message again"
  • observe the computer if it will still freeze.
Toshiba... | Answered on Mar 14, 2010
Well this may be caused by the inverter board found behind the LCD panel. You'll find a coil on the inverter board. Solder it on the two sides.
The existing solder may be loosening due to heat. Use solder to re-solder the two sides.
Please send us your feedback & vote to help us help you as it should be.
Toshiba... | Answered on Feb 11, 2010
To Fix the (Resolution) problem. Part (1) First; (right) click on an empty area of your Desktop Screen, next click Personalize; click Display Settings from here you can adjust the resolution of your screen. You can also correct the Flickering problem. You can repeat these steps until you are satisfied with the results. Part (2) Right click on screen, at the (top) of the Desktop Menu; check if the Graphic ™ Control Center is visibly present? If, so? Click to open. You adjust the Graphic Settings accordingly. I hope this Fix it.
Toshiba... | Answered on Jan 21, 2010
it can be a static problem, where covers are not correctly ground.
Toshiba... | Answered on Jan 15, 2010
could be a loose connection or the circuit board under the chassis could have gone out.
Toshiba... | Answered on Nov 29, 2009
Make sure that you have to headset plugged in before you start the program you're using. Be sure to set te headset as the defult audio device for the program as well.
If this doesn't resole the issue, checking for driver updates, and/or uninstalling and re-installing the drivers usually works.
Toshiba... | Answered on Jul 11, 2009
If you want to play DVDs from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece of software (Passkey for DVD) that allows you to play DVDs from any region and Passkey for Blu-ray that allows you to play Blu-rays from any region.
There are several available on the Internet but my favourite is DVD-Region Free
www.dvdfab.com/products,free.htm
Toshiba... | Answered on Dec 05, 2019
Do you have a wifi card in the computer? It is a hardware part that you need so that the computer can connect to the wifi. If you have that but can't find it in the operating system. I suggest that you either install or update the driver for it.
You can use RadarSync to scan your computer for the available updates of your wifi driver. Make sure that you connect to the internet first using your ethernet so that it will detect the available driver updates somewhere in the databases of the manufacturer.
David
http://goo.gl/CxsY9u
Toshiba... | Answered on Sep 25, 2019
to get the driver for your Toshiba, follow the steps below:
go to http://support.toshiba.com/drivers
enter your laptop model ( Satellite L505) and download sound drivers and other necessary drivers needed for your laptop to operate well.
Good luck.
Toshiba... | Answered on Sep 12, 2019
uninstall the software and put it again
Toshiba... | Answered on Sep 06, 2019
All drivers are available free of charge from Toshiba's web site.
Toshiba... | Answered on Jul 23, 2019
toshiba satellite error 0xc000021a
Blue screen
Toshiba... | Answered on Jun 21, 2019
Toshiba Satellite Pro U400-S1001V Notebook Logo
15 questions posted
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
sons friend put pass word his lap top
  • Computers & Internet
