20 Most Recent
Broan-NuTone QT100L Fan Questions & Answers
Why the fan doesn't work but the light works?
possible resons... the fan motor is bad...the fan plug in the housing has vibrated out....the wire to the fan outlet came loose from the wire nut connection inside the electical box...
try plugging a light or other small electrical device into the fan plug and see if it works (be sure the wall switch is on) it will help you determine the remaining possibilities. try plugging the fan into an extension cord to see if it works, if it runs then the fan is ok and the problem is in the wiring connection. if it doesn't work, the fan motor is bad.
hope this helps....jay
Our bathroom Nu Tone Model
The replacement motor is available from several sources online. The best way is to purchase the new motor assembly. All you need to do is remove the blower housing from the ceiling, there are three screws that hold the motor assembly in place. The whole job takes about five minutes.
Here are a few sites with the motor.
http://www.centralvacuumstores.com/Bath-Vent-Fan/NuTone/Motor-Assembly/0696B000-Motor-Assembly.php
http://parts.broan-nutone.com/nutone/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=qt100l&Search.x=0&Search.y=0
http://www.cshincorporated.com/product_info.php/manufacturers_id/33/products_id/11272
Need to replace glass in
Here is the link to a replacement lens:http://www.centralvacuumstores.com/Bath-Vent-Fan/NuTone/Parts/84999000-Lens.php
Our exhaust fan is really noisy. Nutone QT 100N-B
This model has been discontinued but replacement motor assemblies are available. There is no off the shelf model that will fit in the existing housing. If you do not want to replace the housing then the motor assembly is the way to go.
You ca purchase the replacement from either site below:
How do you get the
I have done this before and it is hard. (big time)One time I just got annoyed and bent the washer and got a replacement one at the hardware store. Sometimes the nut will come off if you pull it gently while "unscrewing" it
Try a little WD40 on the shaft to help the squirrel cage off. also prying up gently helps.
Good luck.
Fan motor does not work.
The replacement motor is available for that fan model. The NuTone part number is the 0696B00. It can be purchase from these sites:
http://www.ventingdirect.com/nutone-0696b000-power-unit-assy-packaged/p431404?y=16&term=0696b000&x=41
