20 Most Recent Grundig Lenaro 26 in. LCD TV Questions & Answers
How to manually turn the subtitles off on a grundig lenaro tv
Turn subtitles language to... turk... o another language ...Solved problem!
9/13/2014 6:01:55 PM • Grundig Lenaro... • Answered on Sep 13, 2014
My grunig lenaro 32inch screen
Hello
It is due to its mother board fault. Digital signal processing section hangs up. There is no repair other than replacing the main motherboard. OK.
5/4/2014 6:54:28 PM • Grundig Lenaro... • Answered on May 04, 2014
Picture blurred
Check and replace its backlight inverter board, or damaged backlight CCFL lamps. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window. google.com/+GopakumarGopalan
11/2/2013 12:46:24 PM • Grundig Lenaro... • Answered on Nov 02, 2013
Picture break up
There is some loose contacts to the connection wires inside the TV. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electric shock. Instead, contact any experienced service technician, or the nearest service center.
4/27/2013 2:17:01 PM • Grundig Lenaro... • Answered on Apr 27, 2013
I was watching ch5 yesterday about 3pm when I
it might need a firmware upgrade, but you would have to contact grundig to see if there is one available
4/27/2011 8:36:46 AM • Grundig Lenaro... • Answered on Apr 27, 2011
Grundig lenaro 37inch digital hd
If you use a clean soft cloth and washing up water. Wring the cloth out to almost dry and wipe the screen.
Hope that helps.
3/12/2011 10:02:49 AM • Grundig Lenaro... • Answered on Mar 12, 2011
No power going to unit
This is very technical problem. It is the power supply. A very sensitive circuit board, in fact i just fixed one today. The way these power supply works is they convert the ac directly to DC. Then switch on and off at high frequency of typically over a hundred thousand times per second to drive a special transformer to deliver power to the unit. On larger unit the screen is driven by several high voltage transformers and probably that wnet out first thats why it lost picture. Finally the main power supply went out as well. When I fixed the one I did today I had to find a technical data on the chips that like a freakin engineer analyzing a circuit. In dept understanding of electronic theory is a must. Now you may find a power supply on e bay or something thats about the best advice i can give you.
6/26/2010 5:47:58 AM • Grundig Lenaro... • Answered on Jun 26, 2010
Need software upgrade
Contact Grundig directly for available updates. Check their website & download directly if available.
11/7/2009 8:52:05 PM • Grundig Lenaro... • Answered on Nov 07, 2009
My Grundig 46" VLE7239BR television has problem. When powering on, message "Grundig" shows for one second and the display then goes black. Is this a problem to repair?
Question edited for clarity, typos, spelling. In general, all televisions can be repaired if boards are available. but depending on age, a failure like this is often a good chance to upgrade to more modern alternatives for both picture quality and features. Having said that, your Grundig is a full HD set and worthy of repair. https://www.fixya.com/support/r29790007-repairing_own_television https://www.google.com/search?q=Grundig+46%22+VLE7239BR ..
6/14/2022 3:54:59 PM • Grundig... • Answered on Jun 14, 2022
Cant get my function button to work on my Grundig TK144 , it is stuck on fast forward
Could be a broken spring, or literally any mechanical part that's bad
1/9/2022 11:42:43 PM • Grundig... • Answered on Jan 09, 2022
GRUNDIG 50 vle 932 bh won't boot
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. https://homenol.blogspot.com/ https://elektrotricks.blogspot.com/ http://electronicshelponline.blogspot.com/ Blinking codes details to many popular brand TVs are given. If blinks continue without any pause, the main board is faulty. Search the sites by type in the brand name of your set, in its search box at the right column. View it on a desktop or in web View by mobile. Mobile view has no search box. Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location...
9/15/2021 10:57:26 AM • Grundig... • Answered on Sep 15, 2021
I have universal Remote YA9-000146 and need code for grundig tv
Remote Control Codes For Grundig TVsGrundig 3 Digit TV Remote Codes113110128Grundig 4 Digit TV Remote Codes019501600161017103100320114411241131Grundig multi-brand remote codes instructions for TV's.1 - Turn on TV.2 - Press and hold the TV key and enter the codes for your brand.3 - If your TV turned off then you entered the right code and setup is complete. repeat with next code if needed.
4/30/2021 7:59:46 PM • Grundig... • Answered on Apr 30, 2021
I have Grundig 4k TV that, goes black and flickers randomly with sound.It happens when I play PS4, when I try changing settings on TV or when i change settings on the PS4
when a person uses their TV for playing games I feel they deserve all the bad luck they get NOT SORRY
4/14/2021 1:49:14 PM • Grundig... • Answered on Apr 14, 2021
Forgot pin code for grundig gud300hd freeview hd box
Ok this info does not seem to be anywhere so here goes..... Grundig gud300hd and others of same build alba ect...... set top box pin reset UNLOCK CODE1. Press MENU and go to Settings and press OK. 2. Go to Parental Control and press OK. The 'Enter the PIN Code' menu will be displayed. 3. Press i (information) button once then enter 4000. 4. Go to Change PIN Code and press OK. 5. Press i (information) button once then enter 4000. 6. When it prompts for New PIN enter the desired PIN number using 0~9 keys. Enter it again to confirm. hope it helps
3/16/2021 9:17:21 AM • Grundig... • Answered on Mar 16, 2021
How to unlock Grundig P37-060
https://tv.brain-start.net/how-to-unlock-your-grundig-tv-55vlx7730bp/
5/22/2020 5:40:01 PM • Grundig... • Answered on May 22, 2020
Grundig Lenaro 26 in. LCD TV Logo
23 questions posted
Top Grundig Televison & Video Experts
ray gallant
ADMIN Andrew
ADMIN Andrew
Are you a Grundig Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Grundig Televison & Video
Most Popular Question
picture break up
  • Televison & Video
