20 Most Recent Friedrich PDE15K3SB Portable Air Conditioner Questions & Answers
I have two Friedrich PDE15KSB-C units. When
Keep +10 degree from your room temp and also thermostat in "heat" . And then check. But in your case, I think RV not energized. If no proper voltage in RV in heat mode, check the wiring to RV. If voltage in means RV not working properly. You have to change RV. Thanks.
12/14/2010 4:51:00 PM • Friedrich... • Answered on Dec 14, 2010
2answers
Friedrich Model MR36TQY3JMA mini split. The Inside units have white LEDs. The Heating LED blinks 4 times. The Cooling LED blinks 3 times. Repeat. Nothing else happens. Any thoughts?
A Power Reset will fix most things. Turn off the power at the breaker for a couple of hours. It resets the main board and all the relays. Service Manuals in the link https://www.google.com/search?q=Friedrich+Model+MR36TQY3JMA+mini+split+blinking+codes ..
3/15/2023 4:28:50 AM • Friedrich... • Answered on Mar 15, 2023
How do i turn off check filter light on friedrich model KCM14A10A throughn the wall unit
Press fan and speed together for 3 seconds
8/24/2021 5:07:48 PM • Friedrich... • Answered on Aug 24, 2021
Friedrich through wall unit pdh12k35G-A has error code on display A2. Chart says heater malfunction protection. Wtf am i looking for?
heating switch over or unit failure --circuit or conrtol failure
3/31/2020 11:33:10 AM • Friedrich... • Answered on Mar 31, 2020
I have a friedrich cp15f10 unit and it was tripping the breaker on and off for about 3 weeks. Yesterday It tripped, I reset the breaker but no power on the unit. It produced very cold air and I always had it on low. Does anybody know what it could be?
That's what happens with loose electric connections. Need to go from the breaker to the AC unit power run inspecting each wire splice, all electric connections need to be clean and tight.
A loose connection becomes electrical resistance and electrical resistance consumes power, power consumed is dissipated as heat. Overheated, charred, discolored connections can be cut off and reconnected when found.
Start by tightening the circuit breaker wires, and neutral if any.
7/23/2019 11:05:17 PM • Friedrich... • Answered on Jul 23, 2019
The Friedrich #Ep12G33B-A was turned off over the weekend and now it will not heat. It is 0 degrees. It clicks.
Did you use the Reset button? Did you call (800) 541-6645 and ask Customer Service? Is the Air Conditioner plugged into a power strip? Is the reset on the power unit ON or OFF? If the unit is plugged into a wall AC outlet is the circuit breaker to that AC outlet in need of reset? Is there a foul odor?
1/21/2019 11:40:49 PM • Friedrich... • Answered on Jan 21, 2019
What could be causing my friedrich model number EM24L34 a.c./heater 23,500 btu window unit to stop blowing hot air
Here's some things that could be causing your issue. A clogged air filter could be one possible cause. However I suspect the units high limit switch is the culprit. This is an image of a high limit switch for visual reference only. d0255817-d0ac-4034-8b25-c25b02279f8a-xwhsspmto4xidys1rlhm2glb-1-0.png
1/21/2019 3:07:47 PM • Friedrich... • Answered on Jan 21, 2019
Friedrich model Mr24Y3J error inside unitch38 outdoor unit 8 green 3 red blinking lights
Here is a link to the manual but probably need to get a service tech out. The error codes are on page 36 http://friedrich.gear.host/documents/dss/MM18YJ-MM24YJ.pdf
9/20/2018 5:27:05 PM • Friedrich... • Answered on Sep 20, 2018
Friedrich PDE15K3SB Portable Air Conditioner Logo
1 questions posted
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Jay Finke
Jay Finke
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Friedrich Heating & Cooling
Most Popular Question
two friedrich pde15ksb c units when
  • Heating & Cooling
