20 Most Recent Nintendo Dsi Pink Console Questions & Answers
That Is A Wifi Code.
Nintendo Dsi... | Answered on May 18, 2017
I would make sure to keep track off all the parts when disassembling. If you have nothing to lose I say go for it. At least to see what's going on inside. Good luck!
Nintendo Dsi... | Answered on Apr 10, 2014
forgot my gmail passwork
Nintendo Dsi... | Answered on Feb 08, 2014
Refer to the trouble shooting at Nintendo. Your screen may not be working due to the game your playing if any. If that's not the case you may need to recalibrate your touch screen.
http://www.nintendo.com/consumer/systems/dsi/en_na/trouble_screen.jsp#respond
Nintendo Dsi... | Answered on Aug 17, 2013
tengo el mismo problema estaba haciendo fotoshop. se enciendo el flash. y luego apagamos el d.s y al volverlo a predender. sale error 0000fefe si tienen otra solucion se lo agradezco este aparato es de mi nieto.
Nintendo Dsi... | Answered on Jul 28, 2013
test the fuse, and replace with the same capacity and try again. See the power cord is o.k
God bless you
Nintendo Dsi... | Answered on Jul 11, 2013
If you get this message, it means that you upgrade your 3ds before upgrade r4 card. So, now you need to find a ds lite or the consolve version is below your console to upgrade r4 card.
Nintendo Dsi... | Answered on Jun 02, 2013
GEUST YOUR PIN
Nintendo Dsi... | Answered on Apr 30, 2013
Check the DS slot (Slot 1) and see if there is a missing or bent pin.
If not, try lightly cleaning your game cartridge pins with Denatured alcohol and a tooth brush to remove and possible build up that could be preventing a solid connection. Worse case scenario, the could be a spot on the board where one or more pins have come loose from the connection point.
Nintendo Dsi... | Answered on Apr 06, 2013
NOT A RESET BUTTON BUT THERE IS A RESET CODE
HOLD DOWN AT THE SAME TIME THESE BUTTONS IN THIS ORDER
LEFT,RIGHT,START,SELECT..........THIS WILL FACTORY RESET YOUR DSI
Nintendo Dsi... | Answered on Jan 01, 2013
Nintendo Dsi/DS/Ds XL connects to the internet using wireless connection. You need to know the settings of your router. I've listed below the steps on how you will access the router and to obtain the information needed for you to be connected.
How to access the Router:
1. You need to know the ipaddress of your router. You can refer to the manual or check the Default Gateway of your computer (Make sure that you connect the computer to the router using an ethernet cable for you to get the Default Gateway). Click on START then RUN. Type CMD on the small box on the lower left of the screen. Type IPCONFIG on the black window and get the value of your DEFAULT GATEWAY (it starts with 192.168.x.x)
2. Open a Browser, Type the DEFAULT GATEWAY on the address bar of your Browser. It will ask you for a username and password. (Refer to the manual of your router or post a reply so that i can provide you the username and password of your router)
3. Go to the Wireless Settings Page of your router. Look for the SSID or the Network Name and theNetwork Key or Passphrase. You can personalize it so that you can easily remeber the details.
4. Make sure you connect to your SSID and enter the Network Key to make it secure.
Now that we already know the setting of the router then its now time to connect the Dsi to the network.
1. Go to Nintendo Wi-Fi Connection Settings of the Game
2. Search for an Access Point (SSID)
3. Select your Network (SSID), If you have an open network, just click "OK" and it should work just fine! If it's a Red Padlock, it'll prompt you for a Password or Network Key. This is the reson why we access the router.
4. Test the Connection.
Nintendo Dsi... | Answered on Dec 23, 2012
Direct from the guys at nintendo: Nintendo DSi & Nintendo DSi XL - Settings - Language
You will be asked which language (English, French, Spanish) to use during the first time setup of the system, but the language setting can also be done through the system settings.
How to change the language:
  1. On the Nintendo DSi Menu, use the stylus to select the Settings ("wrench") icon.
  2. Select the right arrow thee times to go to page 4, then select "Language."
  3. Select from the options options on the screen:
    • English
    • Fran?ais (French)
    • Espa?ol (Spanish)
  4. Select OK (the bottom-right button) to confirm and return to the System Settings.
If you need further help, reach me via phone at https://www.6ya.com/expert/eric_5b00a5ceab1c0cd2
Nintendo Dsi... | Answered on Nov 23, 2012
First of all, do not save any new file to camera's memory card.
Take out memory card, and connect it to computer using a card reader. You should see memory card shown as a drive letter (like H:) in Windows Explorer.
Download this photo recovery software
http://www.asoftech.com/apr/
Install and open the photo recovery software, select the memory card, and click 'Start' button.
Nintendo Dsi... | Answered on Nov 07, 2012
try it agian and agian
Nintendo Dsi... | Answered on Oct 20, 2012
Nintendo Dsi Pink Console Logo
291 questions posted
Popular Products
Top Nintendo Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Anon
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
View Most Popular
  • Nintendo Video Game Consoles & Games
Most Popular Question
deleted inportent photos dsi
  • Video Game Consoles & Games
