20 Most Recent SanDisk Sansa Fuse MP3 Player Questions & Answers
It will play for about three days then it says DRM
If you don't have DRM license for your music, it's because you haven't synced your player with the program on your computer in a while.
DRM is on your music because you most likely use a subscription service such as Napster or Rhapsody for your music.
Just plug your player into your computer and sync your device for the DRM license to refresh.
3/12/2020 8:41:28 AM • SanDisk Sansa... • Answered on Mar 12, 2020
My Sansa Fuze MP-3 player has "locked up" even though I don't have the device in the locked position. Can you help me to unlock my device?
Hi! Seems that there is a problem with the Hold Button of the mp3 player. Please check the manual of the similar device. Hope it will help! https://manualsbrain.com/en/manuals/120191/?page=6
9/15/2017 11:22:54 AM • SanDisk Sansa... • Answered on Sep 15, 2017
0answers
3answers
I can't hear music in my sansa
Plug the headphones in.
1/11/2017 3:04:07 AM • SanDisk Sansa... • Answered on Jan 11, 2017
My 2004 Honda vtx neutral light wont come on
Check the wire to the switch is OK, then check the bulb. It may be that simple?
10/9/2014 11:23:24 AM • SanDisk Sansa... • Answered on Oct 09, 2014
1990 Cadillac Eldorado whole dash board lights are
If all the lights are out more and likely a fuse is brunt out
11/1/2013 3:00:07 AM • SanDisk Sansa... • Answered on Nov 01, 2013
Won't charge when plugged in to USB
Often the problem is the USB cable or the plug.Make sure the USB cable is plugged in firmly, all the way on both ends. If it still does not charge, try using a different USB port on the computer or laptop. If that fails to solve the problem then get a new USB cable.If none of the above solves your problem then your device is defective.
1/21/2013 10:33:11 PM • SanDisk Sansa... • Answered on Jan 21, 2013
I Need to know which fuse in the fuse box belongs the windshield wipers for 1998 Ford Explorer xlt...
Usually the fuse box lid has labels identifying the various fuses for each electrical item/circuit.
12/18/2012 8:15:51 AM • SanDisk Sansa... • Answered on Dec 18, 2012
2answers
When i remove micro chip do tracks remain in player
Only if they are saved onto the memory of the MP3.
10/19/2012 6:16:30 PM • SanDisk Sansa... • Answered on Oct 19, 2012
I put a picture on it and when i try to view it it
You need to use the supplied Sansa Media Converter to convert pictures (and videos) to a format the Sansa can handle.
4/25/2012 2:00:07 AM • SanDisk Sansa... • Answered on Apr 25, 2012
My sansa SanDisk 4gb player locked up and won't do anything
Slide the power switch up all the way and hold it there for fifteen seconds or so. This will reset the player.If this doesn't, please reply to this post and we can go from there.
12/28/2011 6:15:49 PM • SanDisk Sansa... • Answered on Dec 28, 2011
0answers
What's your problem?just baught a sansa fuze+
Please download the drivers to the PC, then convert the media to be loaded to the sansa and it will play on the sansa.Please remove all the files from the sansa players and reload them and this must solve the issue.
10/22/2011 4:40:14 AM • SanDisk Sansa... • Answered on Oct 22, 2011
HOW DO YOU CHANGE THE LANGUAGE ON SANSA FUZE
I assume your current language setting is 'English,' and you want another language;1) Press the top menu button, and roll the wheel clockwise or counterclockwise to get to SETTINGS2)Click RIGHT side of wheel to get to Settings submenu.3) Roll the wheel to SYSTEM SETTINGS at the bottom of the submenu list.4) Click RIGHT side of wheel.5) Roll the wheel to the sixth menu entry, LANGUAGE.6) Roll the wheel to select from the 31 available languages; 7) Click RIGHT side of wheel to select the language.What if you clicked the wrong language and are now stuck in Chinese (which you don't read)?1) Press the top menu button. Rotate wheel to the picture of the 4-level 'Mixer'. This is SETTINGS2) Click RIGHT.3) Rotate clockwise to bottom of submenu list.4) Click RIGHT.5 Rotate clockwise to the SIXTH entry from the top.6) Click RIGHT.7) Rotate COUNTERCLOCKWISE to the top of the list.8) Click RIGHT.You should now be in the default English menu.One other suggestion;Download the PDF Manual for the SANSA FUZE, here:kb.sandisk.com/app/answers/detail/a_id/142Note; It's in English :-)
10/12/2011 10:29:45 PM • SanDisk Sansa... • Answered on Oct 12, 2011
How do I get my Itunes to recognize my brand new
Hi luminata53...
Go to Device Manager
To get to Device Manager you will:
Right click on My Computer>Properties>click the Hardware Tab>Device Manager.
After you are in Device Manager look for your MP3 player or Unit.
Here you should see no "Yellow" exclamation points.
If you do they they are telling you that you have a device conflict.
If you currnetly have your unit plugged in, you may notice the "unknown device" which would be your Player or Unit.
If you unit has an exclamation point by it, then you will need to click on it and delete it.
After you remove all devices with conflicts then click on refresh and search again for your MP3 player/Device.
The computer should install your device this time and solve your problem with connection of the MP3 player/Device.
Please take time to rate me thumbs up.
9/17/2011 8:25:41 PM • SanDisk Sansa... • Answered on Sep 17, 2011
Ican't download a copy of the sansa fuse+ users
You can download the manual from the manufacturer's web site at
http://www.sandisk.com/media/911811/Sansa%20Fuze+%20UM_112210.pdf
9/10/2011 7:55:53 PM • SanDisk Sansa... • Answered on Sep 10, 2011
I need step by step
Imesh songs are in a different format and you would have to convert the music to mp3 format first then put them on your SanDisk. You can do a Google search about 'converting Imesh to mp3', there are allot diferant ways and free programs that will convert the songs for you.
Thanks for using FixYa
6/19/2011 2:00:07 AM • SanDisk Sansa... • Answered on Jun 19, 2011
When i turn on my
have u tried putting it on jenny craig?
5/15/2011 1:08:28 AM • SanDisk Sansa... • Answered on May 15, 2011
SanDisk Sansa Fuse  MP3 Player Logo
Popular Tags
123 questions posted
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Mohammad Abumuailek
Mohammad Abumuailek
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
Sansa SanDisk
  • Sansa SanDisk
Most Popular Question
will play about three days says drm
  • Audio Players & Recorders
