20 Most Recent Navman S30 Car GPS Receiver Questions & Answers
3answers
Want to update navman x11-15302
Your model is the S30. You can upload from the navman site to you pc.
Click: http://www.navman.com/in-car/europe/uk/Customer-Support/Software-Updates/
for you downloads.
Dave.
1/24/2019 2:00:32 PM • Navman S30 Car... • Answered on Jan 24, 2019
Turn on, loading the map then shows computer usb connection then do nothing
You have to use the Navdesk software on your computer to load maps into Navman gps unit. Google Navman support and go the link.
3/15/2015 11:28:58 AM • Navman S30 Car... • Answered on Mar 15, 2015
2answers
Nothing on screen except plug into computer
might need an update or could be something wrong with the software and it needs to call home. Hook it up with a computer usb port on side of unit and let it call home. Also check with Navman and see if they have an updater program for your computer first.
1/16/2015 6:48:25 PM • Navman S30 Car... • Answered on Jan 16, 2015
0answers
Nothing on screen except plug to computer
Your unit is in load mode. It is expecting an input signal from a usb port on a computer. If it is stuck in that mode, doing a master reset may help.
12/26/2013 1:35:08 PM • Navman S30 Car... • Answered on Dec 26, 2013
My Navman S30 seems to be stuck in a loop. From
Get the disk that came with it and load NavDesk on your computer delete the maps on your Navman and then reload them. This fixed the problem for me.
9/6/2013 9:39:26 AM • Navman S30 Car... • Answered on Sep 06, 2013
Navman s30 uk map update
8/11/2013 3:04:47 PM • Navman S30 Car... • Answered on Aug 11, 2013
Navmans30, could you tell me if i can use this in portugal?
yes, but you would need to download map from navman...
6/30/2012 11:44:27 PM • Navman S30 Car... • Answered on Jun 30, 2012
Charges at home on a usb port but not in the car
Hi Carl,You should check your car's fuses to see if the one that supplies power to your USB charger is still good. If you're not sure how to do this, you could try plugging a different device into it and see if it works. If it doesn't - you'll need to inspect the fuse or wiring. (you could also try the charger in a different port or different car to see if the issue is tied to the charger).If the other device does work, it is possible that the charger has a built in fuse. If the charger is the type that plugs into your cigar lighter, you may find the the tip holds the fuse. The tip may reveal the fuse if unscrewed from the body or may require a screw driver to open the body. Either way, you'll need to ascertain if there is a fuse in it and if so, check its condition.Sometimes, the charger needs to be aligned a certain way in the cigar lighter / power port (or outlet) due to the way some automakers and device manufacturers design the connections. Repeatedly remove and replace the plug in the lighter / port. Each time, turn the the plug slightly so that it takes 6 to 8 insertions to rotate all the way around in the outlet. This should provide at least one position that allows the plug to make the required contact in the lighter / power port.Lastly, make sure that there is no foreign object / debris in the outlet, that the the plug fits snugly in the outlet, the the plug's tip has a spring pushing it forward and that the plug is fully inserted into the outlet.Hopefully, one of these suggestions will get it working. Good luck!
3/22/2012 4:40:46 PM • Navman S30 Car... • Answered on Mar 22, 2012
0answers
Navman S30 Car GPS Receiver Logo
97 questions posted
Top Navman GPS Experts
Marvin
Marvin
Muzahura Frank
Are you a Navman GPS Expert? Answer questions, earn points and help others
View Most Popular
Navman GPS
  • Navman GPS
Most Popular Question
find any free map upgrades fo navman s30
  • GPS
