20 Most Recent Nextar X3-08 Car GPS Receiver Questions & Answers
visit Nextar.com to order your desired maps update and Check the overview description to see which SD card lists your GPS model number and serial number. Order the matching card.
Remove the existing SD card. This is usually found in a thin, rectangular slot on the side of the Nextar GPS.
Insert the SD card with the maps update into the empty SD card slot. Press until it clicks into place.
Reset the unit by pressing the "Reset" or pushing a pin into the "Reset" hole.
Click the "Navigation" button to have the maps automatically update on the GPS.
Nextar X3-08 Car... | Answered on Jun 06, 2015
Your device runs Windows ce. So the only way to continue using your device is to switch software. There is a software that is compatible with almost every GPS in the world today. It is called IGO. Maps are available every 4 months for free. Search google for IGO and there are plenty of GPS sites that offer it for download. All you have to do is rename the IGO.exe file you your devices navigation.exe name. If you need further assistance I'll be glad to help.
Nextar X3-08 Car... | Answered on Aug 18, 2014
You should be able to do a master reset such as with the garmins you push bottom right corner when turning on. Check mfg website to do a master reset
Nextar X3-08 Car... | Answered on Aug 12, 2014
update available here:
http://www.nextar.com/frontend/proddetail.asp?pn=PART-GPS-MAP09SDC2
Nextar X3-08 Car... | Answered on May 26, 2014
you can run a different navigation program on it entirely
It runs Windows CE 5.0, which can be hacked to run Garmin, TomTom, etc
Plug the new SD card in and reset the unit.
Unscrew the 4 screws on the back and gently pry open the casing with a guitar pick or an old giftcard. You will have access to the battery. Good luck...
Nextar X3-08 Car... | Answered on Oct 16, 2013
push the reset button on the back of the unit
Nextar X3-08 Car... | Answered on Dec 12, 2012
Once again, it's a software issue or a corrupted SD card. You can purchase a new card but the same old mapping on Nextar.com or Navteq.com. To ensure that your software stays working properly, backup the SD card onto your computer so if the SD card gets corrupted you can restore the software and files back onto your card or a new SD card that can be purchased for around 20 bucks.
Nextar X3-08 Car... | Answered on Mar 01, 2012
There could be few reasons for this problem.
1. The built-in rechargeable battery is almost dead. Please recharge the battery. If the battery is almost dead then it will not turn on even in in the initial hours of charging. Charge it longer than useal.
2. The battery has reached end of life. Replace the battery.
2. The unit may be obstructed by a material such as heat insulation, please remove the obstruction.
3. The unit may be titled too far; please hold the unit upright.
4. If the system software fails to function by chance, please restart the unit again.
My strong believe is that the problem is in the battery. Please make sure your AC adaptor or car adaptor is properly connected to the main unit and that the adaptor is receiving AC power. If problem persists, there may be a hardware problem with charging circuit.
Nextar X3-08 Car... | Answered on Sep 06, 2011
Welcome to Fixya. If you need an instruction manual for Nextar X3-08 just click on the link below
Nextar X3-08 Manual
Thanks for using Fixya
Nextar X3-08 Car... | Answered on Jul 03, 2011
did you ever resolve this issue ?
Nextar X3-08 Car... | Answered on Jan 27, 2011
Hi - I have the same issue with my X3-08...short of buying new GPS ...what did you do ?
Nextar X3-08 Car GPS Receiver Logo
56 questions posted
Top Nextar GPS Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Nextar GPS Expert? Answer questions, earn points and help others
View Most Popular
Nextar GPS
  • Nextar GPS
Most Popular Question
nextar x3 08 gps will not go beyond
  • GPS
