20 Most Recent Goodmans GTVL32W27HDF 32 in. LCD TV Questions & Answers
4answers
Goodmans HDMI. After power cut (which it is used
I just left the TV off and it must have reset itself. It did it twice. First time it was OK after half an hour. Second time it was nearer an hour.
Thanks
6/5/2021 6:51:41 AM • Goodmans... • Answered on Jun 05, 2021
2answers
GOODMANS GTVL26W26HDF - no Remote control/child lock is locked!!
hi just got a goodmans x pro witout the remote any chance you could let me no how to turn it on as its just on stand by now thanks
9/19/2020 3:23:23 PM • Goodmans... • Answered on Sep 19, 2020
Instruction manual for ld3201
Type in details google search or other, should come up with manual
8/10/2014 10:00:18 AM • Goodmans... • Answered on Aug 10, 2014
I have Goodmans LCD GTVL32W17HDF. when i put to TV its works Better but when i put to DTV only the sound i hear no pictures,how can i get this fix
The yellow wire is plugged in wrong in the back. Or the red/green/blue cable is plugged in wrong.
7/29/2014 12:32:36 AM • Goodmans... • Answered on Jul 29, 2014
Can anyone tell me why all of my BBC digital channels have no signal at night or the early morning, but work again during the day!? thanks
Check the signal strength. If the signal strength is weak, this can happen to digital channels. For analogue channels, the fault due to weak signal will be a grainy picture. http://electronicshelponline.blogspot.com/
7/26/2014 4:12:05 PM • Goodmans... • Answered on Jul 26, 2014
0answers
0answers
Fuse keeps blowing
There should be a short circuited component/s at its main power regulator board. Check and replace it. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window. google.com/+GopakumarGopalan
11/2/2013 8:55:32 AM • Goodmans... • Answered on Nov 02, 2013
My goodmans ld2271d tv has no control. When I set
check the sound setting on the sky box go to setting, then sound. audio out stereodigital audio out optical (dolby D)digital audio output hdmi (normal)digital audio output delay (0ms)this is how the settings should be digital out put hdmi only works with full HD 3D tvs.
10/2/2013 7:45:44 PM • Goodmans... • Answered on Oct 02, 2013
Sound but no picture on
The LCD backlight is faulty. it may be due to bad capacitors or a faulty inverter controller. Bad capacitors can be easily replaced. A faulty inverter controller is a bit more tricky but it can also be replaced.
2/10/2013 2:18:18 PM • Goodmans... • Answered on Feb 10, 2013
Fuse keeps blowing on power board. It is the 3.15 amp fuse on the goodmans xpro tv
Most likely you have a short on the front side of your power supply. You will either need to have it repaired or replaced!
10/23/2012 2:40:14 AM • Goodmans... • Answered on Oct 23, 2012
3answers
My goodmans tv LD3265D1 when
im having same problem, did u find a solution
10/15/2012 9:37:36 PM • Goodmans... • Answered on Oct 15, 2012
0answers
2answers
I was watching my Goodmans LCD TV when my picture
you have no back light , the invertor pcb may be faulty or worse still the screen may have failed.
This needs a service engineer to diagnose properly
8/1/2012 7:27:51 PM • Goodmans... • Answered on Aug 01, 2012
Goodmans GTVL32W27HDF 32 in. LCD TV Logo
124 questions posted
Top Goodmans Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
ADMIN Andrew
ADMIN Andrew
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Goodmans Televison & Video
Most Popular Question
39 t get rid coloured horizontol
  • Televison & Video
