20 Most Recent Sabre LCT371BKA LCD TV Questions & Answers
You can use the code search (or equivalent) feature of your universal remote to find something that can manage some or all functions of your Sabre TV. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Sabre LCT371BKA... | Answered on Feb 18, 2016
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Sabre LCT371BKA... | Answered on Jan 17, 2016
Take it in to be repaired. The internal power supply is defective.
Sabre LCT371BKA... | Answered on Oct 07, 2015
TV's operate on 110 volts, not 220 volts. You need more than just an adaptor to plug in your TV. You need to use a voltage converter to bring the voltage down to 110 volts. But since you already connected your TV up to 220 volts, damage has already occurred to the sensitive electronic components and you need to get it repaired.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sabre LCT371BKA... | Answered on Aug 22, 2014
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Sabre LCT371BKA... | Answered on Aug 12, 2014
My TV just did this 2 days before Thanksgiving. I just messed with it and fixed it today. Unplug it from the power source for atleast one hour. Plug it back it. Hold the power button til constantly flashes red and green. Wait at least one minute while it continues to flash. Turn it off. Flip the big power source button on the back to off && then on. Then hit the power button on the side, and it should turn on. Worked for mine. Hope it helps.
Sabre LCT371BKA... | Answered on Jun 11, 2014
0093,0048,0027. Try these codes. If you wish to get some details, check the sites linked here. Set-up code list, and Set-up procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name of your TV / Device, in the search box at the top right of the display window.
Sabre LCT371BKA... | Answered on Nov 12, 2013
It sounds that the software loaded has been corrupted by anyway. If so, a software update might be necessary. If you wish to get more details, check this link. It has details about software upgrade. Go through it, and if you're confident, do a software update. If not, contact any service technician. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sabre LCT371BKA... | Answered on Sep 29, 2013
Probable power supply failure
Sabre LCT371BKA... | Answered on Aug 18, 2013
Sabre LCT371BKA LCD TV Logo
72 questions posted
Top Sabre Televison & Video Experts
Tom Chichester
Are you a Sabre Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sabre Televison & Video
Most Popular Question
sabre lcd tv
  • Televison & Video
