20 Most Recent Samsung LN40B530 40 in. LCD HDTV Questions & Answers
how to rotate my samsung flat screen monitor turning up side down
Samsung LN40B530... | Answered on Feb 22, 2019
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/
Try a reset too. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Service mode entry, adjust and exit procedure to many popular brand TVs are given.
Samsung LN40B530... | Answered on Nov 21, 2016
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Samsung LN40B530... | Answered on Oct 01, 2016
Fault to the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Samsung LN40B530... | Answered on Aug 19, 2015
T'Con board fault. Replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Samsung LN40B530... | Answered on Jul 18, 2015
i dont see but i think you heave problem vith t-con board
Samsung LN40B530... | Answered on Sep 28, 2014
1. Check the cables are plugged in correctly.
2. Try a different cable
3. check the terms in your warranty
Samsung LN40B530... | Answered on May 14, 2014
Most likely a bad smps
Samsung LN40B530... | Answered on Apr 18, 2014
You could try an lvds cable
Samsung LN40B530... | Answered on Apr 17, 2014
sounds like you have a bad function board
Hi...its more likely to be dry joints on the PSU,mainly around transistors and diodes on heatsinks.
Samsung LN40B530... | Answered on Feb 27, 2014
Samsung LN40B530 40 in. LCD HDTV Logo
88 questions posted
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
View Most Popular
LN Samsung
  • LN Samsung
Most Popular Question
samsung ln40b530 40 1080p lcd hdtv
  • Televison & Video
