20 Most Recent Sony KDL32L5000 32 in. LCD HDTV Questions & Answers
If the only thing not reacting is the audio, then the audio board or the main board has gone bad. Enter the model number and tv make on you tube to get more detailed info.
Sony KDL32L5000... | Answered on Dec 15, 2017
Hi
first of all you have to check the power supply To find it working or not. Some times even if mother board have some problem then the tv can show the same symptom. check the video to know how to check the power supply of the lcd tv. if you find the power supply is faulty then change it.
Testing LCD TV Power Supply BoardsSTEP BY STEP
www.electro-medical.blogspot.com
Sony KDL32L5000... | Answered on Sep 16, 2015
Without a remote control; you can't reset it. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Sony KDL32L5000... | Answered on Oct 24, 2014
The same thing happened to me. I went to Menu. Click the bottom item and when it opens, click on ECO. Now turn off both Power Saving and Idle TV Standby. It is mostly caused by the Idle TV Standby, though. Good luck!
I am still working with the loss of the IR capability. I sadly found the Warranty docs when it had ended...
Sony KDL32L5000... | Answered on Jun 28, 2014
To replace the sensor element, you have to open the TV and take out the circuit board that contains the sensor. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Sony KDL32L5000... | Answered on Jan 22, 2013
The tv power supply board it is dead 100% it is dead that board where the tv power a/c plug into it.Sometimes u get a burn or a chart coal marks if the power surge have big enough charges to the board,not it still kills board too because electromagnatic charges of the storm kills every electronic parts in came in contact with.Take the tv aparts.The tv power supply board are alway the one these two boards are the causes alway and the first board to dies .Replaced the tv power supply board first.Tv should work now,if not the main tv Tuner signal board it is also dead too.That the board where the incomming broadcasting signal wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement first and also the main tv Tuner signal board too,if necessary.70-80% changes the power supply board and necessary the main tv Tuner signal boad too tv should work again.20% sometimes the whole tv it fries and a total lost.
Sony KDL32L5000... | Answered on Nov 13, 2012
You have to open your TV to do this work. The remote sensor can be located just behind the infrared window at the front panel of the TV. It is a three solder terminal component, and can be bought from most of the electronic spare part selling shops at your tow. It will have a number printed on its side, which should be noted, when buying a new one. So many types are there in the market and you have to be the sensor you want to buy in you hand when you go to buy one. for your reference, picture of some types are attached here.
Sony KDL32L5000... | Answered on Aug 26, 2012
Look for any loose contacts in power outlet. Try connecting the TV to another power outlet, which you are sure works well. If the TV is still in same condition, switch it off manually, switch off power, remove plug and wait for 48 hours and retry.
Sony KDL32L5000... | Answered on Aug 24, 2012
Try changing the input device to something you are sure, works such as a DVD player. Look for any magnetic materials in that area. Look for any loose contacts on RC Jack, connectors or cables.
Sony KDL32L5000... | Answered on Aug 03, 2012
Click here to download the user manual to your TV. If you find any difficulty in downloading the same, send your email address to me by Fixya comment, and get back a copy of it by return mail.
Sony KDL32L5000... | Answered on Jul 12, 2012
Sony KDL32L5000 32 in. LCD HDTV Logo
77 questions posted
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
KDL Sony
  • KDL Sony
Most Popular Question
bought tv sony lcd 32
  • Televison & Video
