20 Most Recent AOC L26W861 26 in. LCD TV Questions & Answers
Where can I get the firmware for my AOC l26w861 TV
As a engineer I have been trying for a couple of years and have had no feedback from them
1/4/2017 5:28:07 PM • AOC L26W861 26... • Answered on Jan 04, 2017
AOC L26W861 LCD TV : 1. When TV is turned on using
Try a factory reset: 1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote) 2. Using the other hand, press the Power button. 3. A small screen should appear in the top left part of the screen. 4. Using the remote, select "Memory Recall" and Enter. 5. Power off and reboot the TV and Computer. 6. Run channel auto-scan to regain the picture.
6/26/2016 12:38:18 AM • AOC L26W861 26... • Answered on Jun 26, 2016
My screen is just grey, no picture and when i push
Hi there , maybe to late by now but sounds like the panel lock is on you can only remove it by using the remote and going into the menu and turning the panel lock off .
8/7/2013 1:42:47 PM • AOC L26W861 26... • Answered on Aug 07, 2013
The monitor does not come
The power supply board is the causes and the problems.That board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
12/27/2010 11:54:54 PM • AOC L26W861 26... • Answered on Dec 27, 2010
Tv is aoc l26w861 when
Ck power supply board for open fuse or Bad Capacitors they will be Domed,swollen,vented on Top, 2200uf 10v 3300uf 10v 1000uf 16v
9/21/2010 1:13:46 PM • AOC L26W861 26... • Answered on Sep 21, 2010
AOC 24G2U all buttons only control the input since this week, can't access the settings menu and the screen will start to switch input by itself?
If the buttons on your AOC 24G2U monitor are no longer functioning as expected, and you can only control the input/source selection, it indicates a possible issue with the monitor's control panel or the firmware. Here are some steps you can try to troubleshoot the problem:
  1. Power Cycle: Turn off the monitor and unplug it from the power source. Wait for about 1-2 minutes, then plug it back in and power it on again. This can help reset the monitor's internal settings and may restore the functionality of the buttons.
  2. Button Combination Reset: Some monitors have a button combination or sequence that can reset the settings to their factory defaults. Consult the user manual for your AOC 24G2U monitor or visit the manufacturer's website to find the specific button combination for resetting the monitor's settings. Follow the instructions carefully to perform the reset.
  3. Firmware Update: Check if there is a firmware update available for your monitor model. Visit the AOC website or contact their customer support to inquire about firmware updates. Updating the monitor's firmware can sometimes resolve issues with the control panel and restore full functionality to the buttons.
  4. Physical Inspection: Inspect the buttons on the control panel for any signs of physical damage or debris. Sometimes, dirt or debris can interfere with the proper functioning of the buttons. Use a soft, lint-free cloth to gently clean the buttons and the surrounding area.
  5. Contact AOC Support: If the issue persists after attempting the above steps, it's recommended to contact AOC customer support for further assistance. They can provide specific troubleshooting steps or arrange for repair or replacement if necessary.
Please note that the steps provided are general guidelines and the exact steps or options may vary depending on your specific AOC 24G2U monitor model. Always refer to the user manual or contact the manufacturer's customer support for model-specific instructions.
7/15/2023 5:51:30 PM • AOC Televison &... • Answered on Jul 15, 2023
Aoc envision 32" LCD tv/ power button stopped working
Hi there , sound like it may need output caps
5/23/2023 1:02:21 AM • AOC Televison &... • Answered on May 23, 2023
AOC LE32A1330/61 when I TURN ON the TV, THE screen SHOWS UP aoc logo for A few second and it goes to standby and again it comes on and off. REPEATS OVER, again & again.
This sounds like a boot log issue, if a new EEPROM can be purchased that should fix the issue, other option is replace the main board
5/3/2022 8:20:20 PM • AOC Televison &... • Answered on May 03, 2022
Hi I have 19in aoc L19w961 w/o the remote, what channel do I select in order for the cable box to work ?
use the input button on the TV to get to HDMI 1 then hook the box into that on the back of the TV
8/22/2021 12:59:19 PM • AOC Televison &... • Answered on Aug 22, 2021
My aoc tv has no sound
A pc tv 32w063 no sound
6/15/2021 8:30:49 PM • AOC Televison &... • Answered on Jun 15, 2021
My AOC tv won’t find channels when I do auto channel search. I have the antenna in the exact same spot and can do a search on different tv and it finds plenty. Is this a tv issue?
Make sure that your search is set to include both analog and digital channels. If it still does not find any channels, then it could be a problem with the tuner assembly.
11/7/2020 7:15:12 PM • AOC Televison &... • Answered on Nov 07, 2020
My AOC 22 inch envisions series does not respond to the remote or the buttons on front the screen is black led light below the logo is blue what is wrong?
Check the remote control for its infra-red emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
5/27/2020 3:19:05 AM • AOC Televison &... • Answered on May 27, 2020
What are the remote codes for the AOC television model # L328W861
When ubuy a remote it comes w codes..just keep xperimenting
4/19/2020 3:53:38 PM • AOC Televison &... • Answered on Apr 19, 2020
All 3 hdmi ports on my aoc tv don't appear to work
Try unplugging for a bit. Plug in hdmi cord b4 plugging back in.
10/10/2019 2:38:53 AM • AOC Televison &... • Answered on Oct 10, 2019
AOC L26W861 26 in. LCD TV Logo
8 questions posted
Top AOC Televison & Video Experts
Arnie Burke
Arnie Burke
Are you an AOC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • AOC Televison & Video
Most Popular Question
get firmware aoc l26w861 tv
  • Televison & Video
