20 Most Recent Doro HandleEasy 330 gsm schwarz Cell Phone Questions & Answers
The SOS calls only happens under specific situations on mobile phones. If you haven't paid your bill or are out of minutes on your plan, then the message will always show up. If you use pre-paid cell minutes, check your balance.
Similarly, if your phone isn't within range of a cellular tower for your network but does have signal from other networks, the phone will allow emergency calls to go on the other network. Talk to your provider about the coverage area and check if you were in a covered area.
A damaged SIM card could also give the problem. This is due to looking like a "not on plan" phone. Talk to your provider about the SIM card if this could be the problem.
I hope this helps.
Doro HandleEasy... | Answered on Oct 09, 2013
did you get a solution to this please?
Doro HandleEasy... | Answered on Oct 30, 2011
AW 1951 Hi Basiclly you need to go to the settings and look for the language settings. Look for a icon that looks like ahammer and a screw driver in the form of a x . then scroll down to number 6hit ok and the go to number 3 that shoulkd be your lamguage hit the ok button and then you should ingles and espanol. AFTER that it should go back to english when you hit it.
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
Doro HandleEasy... | Answered on Nov 26, 2010
Turned off phone, turned on again, looked for settings(now there), flipped thru contact/message/etc screens, and it now works! Wonky fix, but now works.(I HATE this phone)
Doro Cell Phones | Answered on Sep 24, 2020
There is most probably an issue with the keypad connector or cable that connects to the main board of the phone. You can try opening the phone yourself (But I must warn you that doing this is totally at your own risk, as firstly if the phone is still under warranty and you open the phone the warranty will become void. Secondly if you aren't very careful when opening the phone you can possibly cause unnecessary damage) but this being said if you have the necessary tools EG the small screwdriver set and you open the phone up first check the connector pin that clips to the phones main board and make sure it's properly clipped in and check for any damage to the cable. If the pin is properly secured and there is no visible damage to the cable and the keypad is still not working you will unfortunately have to replace the keypad and this is best left up to a qualified repair technician. I hope this isof some help and best of luck I hope you resolve the problem.
Doro Cell Phones | Answered on Aug 16, 2020
You might have to reset your phone or and delete all of the apps
Follow the below steps to resolve the issue,
1. Choose Menu on the main screen.
2. Scroll to Weather and choose OK.
3. Choose OK.
4. Enter a city of choice and choose Select.
5. This screen will display, and you will hear a beep. The beep denotes that the certificate on the handset is incorrect. Choose Cancel.
6. Choose Yes to cancel. Note that this screen may or may not appear. If it doesn't, it just means that it's been automatically processed, so you can move ahead to step 7.
7. Choose Options.
8. Choose Install using the OK button.
9. Please choose any 4 keys, such as 1234, then choose Options.
10. This screen will be displayed to confirm the certificate has imported and updated.
11. It will then continue to search for the city that was entered in step 4.
12. It will then display the list of cities based on the one you entered in step 4. Choose OK to select the city you would like.
13. The weather for the desired city will then be displayed.
Hope this might help you.
Doro Cell Phones | Answered on Jul 24, 2020
You are losing signal and cannot connect to the network. Signal strength may be affected by weather or other conditions. You might find the X disappears when you change location, for example. So, the problem may be in the environment, in the network, or in the SIM card. If it is a bad SIM card, such has to be replaced. If it is a network problem, you would have to contact your service provider. And you can't do much about the weather other than try the phone is a different location. Generally, a red X means a function is not available and you have to go into setup to enable the function. But in this case, you are having network connection problems where the phone cannot detect the signal.
Doro Cell Phones | Answered on Jul 23, 2020
Instructions for a different model suggest besides turing off and on, to try removing the battery and inserting it again.
Last resort step is to wipe it out and restore it which will erase all information on it unfortunately.
https://phones.brain-start.tech/black-screen/how-to-fix-a-black-screen-on-your-doro-8035/
Doro Cell Phones | Answered on Jun 28, 2020
It didn't appear in the online manual.
https://www.consumercellular.com/Assets/documents/Manuals/Doro%207050%20Manual.pdf
After searching the internet using https://www.google.com, I saw the following suggestion on the web site below.
To disable airplane mode, from the home screen, please press the up arrow (on the navigation ring). There, scroll right to {Airplane Mode), then select OK to toggle it off.
https://www.facebook.com/consumercellular/posts/hi-my-mom-is-visiting-she-has-a-doro-7050-and-someone-on-the-plane-helped-get-th/10155657890377015/
Please comment or acknowledge if this works for you or not.
Doro Cell Phones | Answered on May 26, 2020
Hello, you can try "phone to phone transfer" tool, then you can transfer your photos between two doro phones.
This method is very easy and effecient, so you don't to waste a lot time to do this thing, you can finish this thing in a fast time.
Click the following words to know more details about this way:
Samsung Data Transfer
One Click to Transfer Files from Android to Android
Doro Cell Phones | Answered on Dec 25, 2019
GT Recovery Download: http://www.gtrecovery.net
Can you retrieve deleted text messages on Android? Yeah, this video will show you the full guide for Android text message recovery.
Don't hesitate and recover deleted text messages from Android 4.0, 4.1, 4.2, 4.4, 5.0, 5.1 and more versions right now!
Not only can you recover SMS messages from Android backup but also can recover Android SMS messages without backup. This video is showing you how to recover deleted sms messages from Android.
Some common situations that lost text messages you can recover from:
1). accidentally deleted texts on your android phone
2). lost text messages after Android 5.0 updated or other Android upgrade.
3). save text messages from water damaged, crashed, broken or smashed Android phone
4). Android deleted text messages randomly by itself
5). Factory restore Android phone.
Doro Cell Phones | Answered on Dec 17, 2019
Turn it off at the settings>display>notifications>
Doro Cell Phones | Answered on Dec 02, 2019
Doro HandleEasy 330 gsm schwarz Cell Phone Logo
Popular Tags
11 questions posted
Top Doro Cell Phones Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Doro Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Doro Cell Phones
  • Doro Cell Phones
Most Popular Question
doro phone says sos call only get
  • Cell Phones
