20 Most Recent Zanussi ZWF10070W Front Load Washer Questions & Answers
There is no electrical supply
Sorry but with such a fault it is virtually impossible for anybody on this FixYa forum to guess remotely what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB, water inlet control valves, door solenoid, main motor, drain motor etc..
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
9/12/2011 3:17:00 PM • Zanussi... • Answered on Sep 12, 2011
Zanussi fx 1465 w program fills with water then
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
2/22/2011 8:37:41 PM • Zanussi... • Answered on Feb 22, 2011
I have en error message
E62: Overheating during washing
E12 means a problem filling on dry cycle.
Unplug the appliance, take the top off and check that the plastic condenser below the fan is clear and clean.
If this is ok, the most likely fault is the triple valve isn't opening properly to feed water into the condenser.
It may be that a power off and on is all that is required to make the valve work.
The worst case would be that it's a fault with the main control board.
If you have access to and can use a multimeter you could test and make sure that 240 volts was being supplied to the valve when it goes wrong. This would narrow the fault down.
Ive had it many times when during use the valve fails. So at first it works ok and during use thats when it fails.
What you can do is set it going and say after 20 mins or so unplug it and meter out the dryer coil on the fill valve. Its the green coil. What you will proberbly find is the coil is open circuit.
If so the valve will need to be replaced and it should be back to normal then.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL are appreciated for answering your FREE question.
10/3/2010 2:34:50 PM • Zanussi... • Answered on Oct 03, 2010
Installation question: We have just received
normally you should remove these parts also, they often drop inside the machine. this will not harm the machine.
9/15/2010 9:06:15 PM • Zanussi... • Answered on Sep 15, 2010
My Zanussi washing machine is smelling
I have this problem with my Siemens machine, it is due to mainly running low temp washes and bateria building up in the hoses etc. (more prevalent if the machine is connected directly to the sink and not on a stand pipe). I run a 90 degree cycle every 4 weeks with the machine empty except for two capfuls of baby sterilisng fluid (approx half a mug) I buy stores own as it is cheaper than miltons. The first time I did mine I ran the cycle twice to be sure it was cleared out. My machine is six years old and the first smelly signs were when it was about a year old, I run the maintenance wash religiously ever 4 weeks and run a machine descaler such as oust thru every 4-6 months. Hope this helps. Roni. (ps don't be tempted to use bleach as it foams up and can cause more problems!!)
7/6/2010 10:29:31 AM • Zanussi... • Answered on Jul 06, 2010
Machine stopping mid cycle
Count the number of green flashes(1st number of error code). count number of red flashes(2nd number of error code).
Common codes are:
E10 or 11 water pressure faults.
E20 filter/pump faults.
E30 pressure switch/heater faults.
E40 door switch faults.
E50 motor faults.
E60 Heater faults.
These are some of the error codes but there are many variations on some codes depending on the model.Hpoe this has been some help.
5/5/2010 11:15:49 PM • Zanussi... • Answered on May 05, 2010
ZWH 7149 P won't agitate.
Either one of these. Control board has failed. Control knob has failed. Motor has failed. Motor controller has failed. If you can hear the motor turning, the coupler has failed. You need a service call to get correct diagnostics and warranty on the repair. The video _may_ help? https://www.google.com/search?q=Zanussi+ZWH+7149+drum+not+turning ..
10/29/2022 6:08:43 PM • Zanussi Washing... • Answered on Oct 29, 2022
Zanussi drains after pre wash but does not drain next cycle
This is a logic board issue. Call for service for the correct diagnosis and warranty on the new part.
10/13/2022 3:36:19 PM • Zanussi Washing... • Answered on Oct 13, 2022
Zanussi Aquacycle 1100 XC - when trying to start the machine the door clicks 3 times and then I get a error / beeping sound.
Hi, Please clean out the interior of your machines and clean any filters as necessary, then attempt to run again. If this continues, please call Zanussi at 03445 610 645 to help overcome the issue. Thank you.
9/30/2022 7:51:29 PM • Zanussi Washing... • Answered on Sep 30, 2022
0answers
Zanussi FJS1197W washing machine periodically wont drain at end of wash phase
It is very unusual for a front loader, it does have both a recirculation pump and a drain pump! I don't see any diverter valves. Exploded parts diagram. https://www.ransomspares.co.uk/parts/brands/zanussi/washing-machines/fjs1197w%20%2891478851400%29/ ..
7/24/2022 10:30:56 PM • Zanussi Washing... • Answered on Jul 24, 2022
Zanussi Lindo 300 tumble dryer buttons not responding!
The machine has a Diagnostics Mode if you can get to it. It also has a Reset https://www.google.com/search?q=Zanussi+lindo+300+reset ...
6/18/2022 3:55:34 PM • Zanussi Washing... • Answered on Jun 18, 2022
How to remove control panel on zanussi ZCM700X
video in the link. Manual if you need it, but no service manual. https://www.google.com/search?q=remove+control+panel+on+zanussi+ZCM700X ..
5/26/2022 4:12:48 PM • Zanussi Washing... • Answered on May 26, 2022
Zanussi washing machine zwnb6140 spin problem
4/20/2022 3:09:39 PM • Zanussi Washing... • Answered on Apr 20, 2022
My zanussi dish washer keeps cutting out mid cycle it's a zdv 1200
Strange, I just replied to a question for a ZDF1200 WASHER. https://www.google.com/search?q=Zanussi+ZDV+1200%2C+stops+mid+cycle ..
3/14/2022 6:11:41 PM • Zanussi Washing... • Answered on Mar 14, 2022
I have a Zanussi ZWF16070W1 washing machine which keeps on stopping shortley after it has filled with water. The flash/error code is 5red and 4 green. Does anybody know what this means, please
What you need to do is check the filter in the bottom right hand corner. You need to clear this and in the back were the filter goes you will see the pump impeller X shape. Make sure theres nothing jammed up in there stopping it from turning
2/24/2022 11:00:00 AM • Zanussi Washing... • Answered on Feb 24, 2022
Zanussi Lindo 100 dryer - stops after 10 seconds, pauses 1min, runs 10secs.......
This is what happens during wrinkle guard. During the end of the cycle a dryer will go into wrinkle guard to protect clothes from being wrinkled. Either the timer is stuck in this position or it is set in this position. Wrinkle guard can be called different names depending on manufacture.
2/23/2022 9:13:37 AM • Zanussi Washing... • Answered on Feb 23, 2022
Zanussi ZWF10070W Front Load Washer Logo
Popular Tags
22 questions posted
Top Zanussi Washing Machines Experts
Marvin
Marvin
sheakhly
Level 1 Expert
mark warfield
mark warfield
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Zanussi Washing Machines
Most Popular Question
  • Washing Machines
