20 Most Recent
Sony Alpha DSLR-A350 Digital Camera Questions & Answers
When memory card is inserted the camera wont work
You can insert CF memory and some memory stick cards when you use a special adapter. When you use a memory tick, make sure it is compatible, because the memory stick is the most incompatible memory card, if you have not the correct one.
When you use a CF memory card, check all contacts. Not one contuse pinn in the camera should be belt a little. Use a bright light and a loupe to check.
When I turn my A350
The lens gears are stuck. If dust/lint gets into the gears the gears will get stuck and will make a vibrating noise. After a while the camera shuts off and will flash the error code for lens error. Unfortunately there is nothinng you can do about it as it is extremely tough to disassemble these things. May be your local camera tech can help you. I do not recommend that you try it yourself as if any part of the lens assembly gets slightly kinked the next step will be the bin.
My Sony DSLR-A350 was working fine. Took dozens
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Same as owner of a350
Hi.
The live view sensor is gone out of alignment.The problem was common on Alpha models up to 5xx series, when the sensor was replaced with a more reliable one.
The camera must be repaired, the sensor may need replacement.
Here one of the many forums on the topic.The repair is not expensive, you can get a quote calling Sony contact number, or you can get a quote from a third party repair service here:
Repair.
Regards.
Ginko.
I have a DSLR Sony A350. When I turn it on the
Dear Hm2pogi,
It seems that there is a mechanical problem in your Cam. Get is serviced. But before that set your cam to factory defaults....
Are you able to see the photos in LCD? if not then thre is a LCD problem....
My Sony A100. When connected to a computer via the
I just had the same problem tonight, actually. It's because I just started using the Memory Stick Pro Duo Adaptor for compactflash slot. Make sure the camera is not plugged into the usb slot. Go to menu, go to settings tab (the wrench icon on top), down twice to "Transfer Mode" and select PTP. If it doesn't work you can always change it back. I noticed also that in PTP mode, it might not let you delete images after copying. ??
That's all I have at the moment. Good luck.
Can't transfer pictures to computer.
Please let us know what exactly happen when you are trying to transfer pictures to computer... any error message?
Also how you are trying to transfer pictures?
