20 Most Recent Arctic Cat 2006 F6 Firecat EFI Sno Pro Questions & Answers
2answers
I jump started my 96 thundercat with a halford's jump start box and when i take the leads off it starts to run badly why would it do that?
sounds like the jump starter is supplying regulated power to the spark generator/distributor, without this smoothed power the alternator is feeding unregulated to it.... placing a good battery across the terminals after jump starting should prevent this mis-firing fault.
11/29/2017 8:30:14 PM • Arctic Cat 2006... • Answered on Nov 29, 2017
When starting from a dead stop I hear a growling/squealing sound. Seems to be on the belt side and in that area. Once I get going the sound disappears.
Check belt tension tighten then check the belt tensioner if it has one what kind of car?
1/2/2016 10:10:44 PM • Arctic Cat 2006... • Answered on Jan 02, 2016
Boggs at 18-24 mph
Check the inner bushing on the secondary clutch,it may have popped out.
9/29/2014 7:06:20 PM • Arctic Cat 2006... • Answered on Sep 29, 2014
Headlights dont work
if the bulbs are blown the voltage regulator is the problem
2/12/2014 9:07:01 AM • Arctic Cat 2006... • Answered on Feb 12, 2014
600 triple engine bogs
There's a number of things it can be first check throttle switch bypass all switches at the base it it still bog stator
3/3/2015 11:47:50 AM • Arctic Cat... • Answered on Mar 03, 2015
Atv artic cat 1000 gage problem..
Check for burnt wires around the hood hinge.
10/20/2014 4:18:06 PM • Arctic Cat... • Answered on Oct 20, 2014
2012 arctic cat F5 oil lite comes on when oil resevior is full
Sensor is defective.
10/20/2014 4:12:56 PM • Arctic Cat... • Answered on Oct 20, 2014
Wont start when cold
RE adjust the choke.
10/2/2014 5:24:47 PM • Arctic Cat... • Answered on Oct 02, 2014
No electric no lights or spark pull start
Inspect and test your stator plate.
10/2/2014 4:58:55 PM • Arctic Cat... • Answered on Oct 02, 2014
2011 1100 cc Arctic Cat that stalls when coming to a stop. Doesn't do it all the times. Then starts right back up. Also backfires once in a while when you let the gas off.
The back fireing is common,but check the bushings in your drive clutch,when the inner goes bad,the clutch will not totally disingauge causing the sled to stall.
9/29/2014 7:16:11 PM • Arctic Cat... • Answered on Sep 29, 2014
2002 arctic cat 509 track clicking noise near fron sprocket
If the sled is picked,look for any torn ones that may be hitting the tunnel. Or take a look at your drive shaft berrings.
9/29/2014 7:12:19 PM • Arctic Cat... • Answered on Sep 29, 2014
2008 90 atv
If you dont have a fuel problem,change the external coil.
9/29/2014 7:10:34 PM • Arctic Cat... • Answered on Sep 29, 2014
1997 580 ext efi revs to 8000 rpms than drops and stays at 7000 rpms
Take a look at your drive clutch spring,is may be tired or broken.
9/29/2014 7:08:33 PM • Arctic Cat... • Answered on Sep 29, 2014
Charging system problem 1994 pant era
Sounds like you have a short in your wireing harness. Look by the brake caliper.,also make sure the voltage regulator is tight.
9/29/2014 7:01:13 PM • Arctic Cat... • Answered on Sep 29, 2014
Wildcat trail tranny jumping out of gear
You may have a bad drive shaft berring.
9/29/2014 6:57:12 PM • Arctic Cat... • Answered on Sep 29, 2014
94 artic cat zr580,wont move revs up to 4500rpm, idles have bypassed all switches,new primary coil,
If your drive clutch is ingaging take a look at your chain. It may have broke.Common problem!
9/29/2014 6:56:18 PM • Arctic Cat... • Answered on Sep 29, 2014
Arctic cat problems
Sounds like you have one of a few issues: Clogged Main Jets Cut Off on the Throttle restricting your running Compression Test the Engine and see that the PTO Cylinder is at least a 110-120 Compression and the split between is not more than 10 psi
2/13/2014 1:17:41 AM • Arctic Cat... • Answered on Feb 13, 2014
I have a 2006 Polaris 900rmk snowmobile it keeps overfueling at idle I believe it is one of the injectors on pto side not sure which one of the 2 affects your idle any ideas?
they both can repair manual show how to trouble shoot --------https://snowparts.ru/manuals/Polaris%20Trail%20600-900%20RMK%20Switchback%20Service_Manual_2005.pdf
1/10/2023 1:06:51 PM • Winter Sports • Answered on Jan 10, 2023
No spark on 02 ski doo legend
You have a bad coil or wire.
1/3/2023 2:25:15 AM • Winter Sports • Answered on Jan 03, 2023
Arctic Cat 2006 F6 Firecat EFI Sno Pro Logo
4 questions posted
Top Arctic Cat Winter Sports Experts
Kardoc
john h
Arnie Burke
Arnie Burke
Are you an Arctic Cat Winter Sport Expert? Answer questions, earn points and help others
View Most Popular
F6 Firecat EFI Sno Pro Arctic Cat
  • F6 Firecat EFI Sno Pro Arctic Cat
Most Popular Question
jump started 96 thundercat halfords jump
  • Winter Sports
