20 Most Recent kawasaki 2010 Jet Ski Ultra 260X Questions & Answers
If starts, not electrical except bad/dirty plugs. Then fuel flow problem. You don't provide much info.
kawasaki 2010... | Answered on Jun 26, 2019
the oil injection unit on these skis can fail to test you will need to empty gas tank disconnect oil feed line to inlet manifold
then make a mix of two stroke fuel to the correct ratio say 10 liters. poor in to tank and take ski for a run say 10 minutes let it rest and run again if problem persists
it is possible you have leaking or blown crank case seals you will most likely need a professional to test for
i have provided you a link for free shop manual
kawasaki 2010... | Answered on Mar 10, 2019
how old is gas in tank #2? sounds like lousy oily gas. white white smoke or blueish? white white sounds like heavy moisture. blue is oil
kawasaki 2010... | Answered on Mar 04, 2019
You are extremely lucky... if it won't start close to shore, the last thing you want is to get it started and then go out a long way on the water and have it quit on you!
kawasaki 2010... | Answered on Nov 02, 2017
ONLY of they have the same frame and engine cases.
kawasaki 2010... | Answered on Jun 24, 2017
It is oil injected and if it has been sitting for a long period of time the oil will seep into the intake. This is common on older watercraft. When you get it initially started it will make a huge cloud of smoke and take a few minutes to clear up( burning the excessive amount of oil)
kawasaki 2010... | Answered on Feb 11, 2017
It is fairly easy to change your starter bendix. Just start by disconnecting the battery cables. Then you will remove the bolts on the flywheel cover, which also hold the starter in place, and then just change the old part out with the new one.
kawasaki 2010... | Answered on Sep 27, 2016
50 to 1 that is 2.5 ounces to the gallon for pleasure riding
40 to 1 that is 3.2 ounces to the gallon for racing
kawasaki 2010... | Answered on May 09, 2015
kawasaki 2010 Jet Ski Ultra 260X Logo
42 questions posted
Top kawasaki Boating Experts
wadingriver
wadingriver
ray gallant
johnny bonacci
johnny bonacci
Are you a kawasaki Boating Expert? Answer questions, earn points and help others
View Most Popular
Jet Ski Ultra 260X kawasaki
  • Jet Ski Ultra 260X kawasaki
Most Popular Question
will motor mounts from 1995 kawasaki
  • Boating
