20 Most Recent Microsoft Windows? Vista Business Edition Questions & Answers
0answers
Prodcut key
Be the first to answer 5/2/2010 10:53:19 PM • Microsoft... • Posted on May 02, 2010Be the first to answer
Windows vista buisness product key
So buy it
4/14/2010 10:02:22 PM • Microsoft... • Answered on Apr 14, 2010
2answers
Com surrogate error when windows explorer or any
Hello
If you’ve been getting the error COM Surrogate has stopped working whenever you browse folders containing video or media files, you have come to a good place for some possible solutions. This problem is caused because of codecs and other COM components installed by various softwares that aren’t fully Vista-compatible, like some versions of DivX or Nero. Thus, update all incompatible programs to latest version.
You can remove the message by following these following steps:
  1. Click on start . Right Click on Computer and Select Properties
  2. Click Advanced System Settings located at top left corner
  3. Under the Performance field click settings
  1. Go to Data Execution Prevention Tab
  2. Select Turn on DEP for all programs and services except those i select
  1. Click the Add.. button
  2. Browse to c:windowssystem32 and select dllhost.exe . Click ok when done . You will get a windows
  1. Click Apply.
  2. Restart your computer and the problem will be solved .
This should solve your problem.
Kind regards
Andrea
11/22/2009 4:54:19 AM • Microsoft... • Answered on Nov 22, 2009
I keep getting a com surrogate error when using
Here are something suggested by them:
How ever i nice solution is available at Helpero . To solve the error follow the steps
  4. Go to Data Execution Prevention Tab
  5. Select Turn on DEP for all programs and services except those i select
  6. Click the Add.. button
  7. Browse to c:windowssystem32 and select dllhost.exe . Click ok when done . You will get a windows
  8. Click Apply.
  9. Restart your computer and the problem will be solved ...sodeep
10/18/2009 9:17:56 PM • Microsoft... • Answered on Oct 18, 2009
[email protected]
Have you tried navigating past your homepage? I would open your browser and change your homepage. Your browser could have been hijacked and something changed within the browser itself. Start by trying to go to another page, see if anything loads. I will attach a link to download a spyware cleanup software called Malwarebytes, it's free, run that and restart. Scroll down to the bottom of the page, you will see an option to download and an option to buy, click on download that is the free version. Free Anti Malware Malware Removal I’m happy to help further over the phone at https://www.6ya.com/expert/adrienne_b03fb46fc6334991
4/16/2017 1:04:37 PM • Microsoft... • Answered on Apr 16, 2017
Windows 7. How do I remove administrator password?
From the Start Menu, User Accounts: "Remove your password" - is that what you meant?.. If you'd like a more *advanced* version of this, you can right-click on the "Computer" icon (which CAN be present on the Desktop) and select "Manage" from the menu... Then, go to: "Local Users and Groups". You can use the "Windows key" + "R" to open up the Run... box and type in: "lusrmgr.msc" (without the quotes) to access "Local Users and Groups" directly, btw. administrator-pass-word-windows-7-txgyz3ubhmw5e4elalogaufr-4-0.png
4/2/2017 6:43:47 AM • Microsoft... • Answered on Apr 02, 2017
3answers
Product key for windows 8 pro
11/10/2015 7:36:49 AM • Microsoft... • Answered on Nov 10, 2015
tip
How to Convert .DMG to .ISO
Dmg file is the disc image file which is widely used by Mac systems. Most of Mac operating systems and applications are distributed in dmg files. On Windows PC, it is very convenient to manipulate dmg files with PowerISO. You can open dmg file, convert it to iso file, or burn it to a CD / DVD disc. To convert it to iso file, please follow the steps,
  • Run PowerISO.
  • Choose "Tools > Convert" Menu.
  • PowerISO shows Image Converter dialog.
  • Choose the source DMG file you want to convert.
  • Set the output file format to iso file.
  • Choose the output file name.
Convert DMG to ISO
Bought the RegAlive Registration but can't get to place to input key
perfect product KEY activation expreience, everything becomes easy when you search @@@windows 8.1 key sale@@@ from bing.
1/4/2015 5:02:53 AM • Microsoft... • Answered on Jan 04, 2015
Xp solutions
As soon as you start your computer, begin to repeatedly tap the F8 key until the startup menu appears. It may beep at you, ignore that and keep tapping until you have a black screen with several choices. You have a set amount of time to choose safe mode before the computer automatically does a regular startup. Tap your up or down arrow and that will stop the countdown. I recommend you Choose boot into safe mode with networking. You should from there be able to navigate and perhaps figure out why it is failing. If all else fails, restore the computer to factory settings after backing up anything you might have on it. Could be it was for sale because it won't function consistently.
4/7/2014 8:27:35 AM • Microsoft... • Answered on Apr 07, 2014
Help
If you didn't have a backup of the history information in the first place - you can't.
5/8/2013 8:52:28 AM • Microsoft... • Answered on May 08, 2013
5answers
Microsoft office Bootstrapper has stopped
tep1: - Firewall Disable The users should try to temporarily disable Firewall or other security programs on their system. Step2: - Uninstall Old version of Microsoft Office If the users have installed the old version of Microsoft Office, then they need to instant uninstall it. In any case, if the MS office does not uninstall by using the Control Panel, then they have to download Microsoft Fix Tool and then use it to remove the old version of office of their PC. Step3: -Install Microsoft Office in Clean Boot Boot the system in the clean boot and then try to install the Office 2013 program and check that the clean boot is performed to disable all startup programs and the third party services on the machine. Also, check if they are conflicting with the Office installation. Then restart the computer in Windows Clean Boot and then try to install Microsoft Office 2013 program. Step4: - Check the Services Is Running Properly The users need to ensure that the following services are running properly in the services console. Go to "Start" button and then go to "Run" command. In the command prompt, type "Services.msc" cmd and tap on "Enter" key.
  • Check the Print Spooler
  • Check the Task Scheduler & respective dependencies
Step5:- Check Internet Connection The users need to ensure that their Internet Connection to the system is properly working or not. Might require download few Microsoft utilities at distinct stages. Step6:- Repair OSE Service Follow these steps:
  • Go to Office "install disc" option, and then find ose.exe and osetup.dll.
  • Then need to create a folder for OSE: C:\Program Files\Common Files\microsoft shared\Source Engine
  • Now copy the "OSE.exe" file to that folder.
  • Then restart your machine.
  • Now try to install Office again.
3/7/2024 12:32:09 PM • Microsoft... • Answered on Mar 07, 2024
Product key for ms office 2010 -X16-32007
Not all office disks have the same codes, no matter the version you may need a whole new installation disk with the corresponding code
2/15/2024 4:22:18 PM • Microsoft... • Answered on Feb 15, 2024
My microsoft intergrated webcam works good on skpe. It will not open for me to video myself offline. can I download the same type without messing up my computer
all you need is a camera program or app that is compatible with your operating system and the computer hardware also check to see that your drivers are up to date
2/15/2024 4:21:26 PM • Microsoft... • Answered on Feb 15, 2024
I WANT THE CONFIRMATION CODE FOR MICROSOFT OFFICE PROFESSIONAL 2007 7 CHARACTERS A,B,C,D,E,F,G
2/15/2024 4:15:17 PM • Microsoft... • Answered on Feb 15, 2024
3answers
Need information about robots as an introduction?
ROBOTS
One of the least discussed topics in hobby level robotics is software. You can almost always find a hardware description, schematic, drawing, and tons of help on the electro-mechanical side of your project. However, the software, which admittedly is one of the hard parts, eludes many people. In this article, I would like to demonstrate how to structure your software so your robot will function properly.
I would also like to point out a great technique for getting started. Many software engineers make heavy use of something called 'Pseudo Code'. This is a technique where you write your program in half programming language and half human language (English, Spanish, Driud, etc). Pseudo code is very useful for getting the layout of your program ready, to get basic algorithms worked out, and to be able to read your 'code' quickly. I will demonstrate this technique a little later.
As for programming languages, it doesn't matter which language you choose to use. I personally use the 'C' programming language the most. BASIC, Assembler, or FORTH are all fine choices. It turns out that the language is a small part of the structure of your program. The software has a job to do, and the key is to get it done! I am going to write this article in SBASIC, but the techniques are the same no matter which language you choose. SBASIC is available from Karl Lunts website at http://www.seanet.com/~karllunt/tips.htm.
GRAPHICS
Basic Graphic Design Principles Part 1 Lines and Shapes
by Kelly Paal
This is part one of a two part article.....click here to read part 2. As a graphic designer, you need to know the principles of graphic design in order to design at your best. Knowing what the design principles are will help you implement the best layouts and help you become aware of what you have done wrong in your past designs. This article details information regarding graphic design as it pertains to lines and shapes.
PC JOBS
Types of Computing Jobs
  • Data Entry - This is a job just about anyone can get. Basically, you take information from a piece of paper and use it to fill out a form on the computer. Many old hands who started out in this role are now heading up computer departments.
  • Secretarial/Administrative - This position involves some basic office skills. Not only must you understand the basics of using your computer and a few applications, but you'll probably also be expected to take dictation, answer phones, type letters, and keep things organized. In terms of computer skills, you should know how to use word processing, accounting, and spreadsheet programs at the very least. People in this role often move into other computing roles such as Managers, Meeting Organizers and Human Resources. Naturally you can move into mainstream computing areas, particularly QA and Testing.
  • Power User - Not so much a position as a status of being an extremely proficient user of (typically) Microsoft Office or similar tools. Advanced users of these tools become familiar with the basics of computer programming through starting with Excel macros or Access database programming. One can become very valuable to a small business by learning such skills, and even start to consult with other small businesses at rates typically starting around $50 an hour.
  • Customer Service/Telesales - These positions usually place a higher emphasis on phone skills than computer skills, but you should know at least the basics of how to use your computer.
  • Technical Support (Production Support) - Most companies consider technical support to be an entry-level computer job. You are expected to know the operating systems on which the product you'll support will run, and you'll also need to know the basics of any programs that product might interact with. The good news is that the company will teach you what you need to know about their products - you just need to learn everything else. Success in technical support requires good problem-solving skills and a great deal of attention to detail. Technical Support and Problem Management is a rapidly growing area. Users now rely heavily on Help Lines, International Support Centers and the like.
  • Software Quality Assurance (SQA) Engineer - You need to know as much as the best technical support personnel. You need to be a problem solver, a detective, and sometimes even a Customer Service representative. You'll also need some basic programming skills, since more and more companies are beginning to rely on automated testing. The best SQA engineers understand a little (or a lot) about every aspect of computers, from building them to using them to programming them.
  • Software Engineer (Developer or Programmer) - To get a job at a top software shop such as Microsoft or Google, you'll need a degree in computer science and detailed understanding of the field. However getting a developer position in some small company may be easier. What do you need to know is the language in which you'll be programming. It is also important to know database fundamentals and (if programming for Windows) the Windows API. Knowing more than one programming language is very helpful. Understanding many of the basic fundamentals of computer science (e.g. linked lists, arrays, pointers, object oriented programming) will be essential in demonstrating your proficiency.
  • Business Analyst (Analyst or Systems Analyst or Analyst/Programmer or User Analyst) - This is a relatively new title, but the role is as "old as the hills". People can become a BA with any mix of business and computing skills. It is really a matter of looking at what the company is really after. A good BA should know the process from end to end. The BA is primarily the connection between the business and the developers. To get into this job, and into computing, good knowledge of a business is helpful. So, if you gain good knowledge through your job, and maybe do a computer course, you can get your foot in the door.
1/23/2024 8:20:10 AM • Microsoft... • Answered on Jan 23, 2024
2answers
Please i want source code calculator using asp.net
i want the source code for simple calculater in asp.net
1/8/2024 10:28:36 AM • Microsoft... • Answered on Jan 08, 2024
Is Microsoft Office Online similar to Google Docs?
NO, They are diffrent
12/26/2023 7:28:23 AM • Microsoft... • Answered on Dec 26, 2023
3answers
What is product key? nd
Please sent me for spb mobile shell softwares resistration keys
11/5/2023 6:35:23 AM • Microsoft... • Answered on Nov 05, 2023
Microsoft Windows? Vista Business Edition Logo
5 questions posted
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Windows Microsoft
  • Windows Microsoft
Most Popular Question
windows vista buisness product key
  • Computers & Internet
