20 Most Recent
Navien CH-240-ASME-LP, Combi Condensing Commercial LP Water Heater/Boiler 91 Questions & Answers
No Hot Water
Hard water contains a lot of minerals and depending on how hard the water is also depends on how often you must replace the filters. A much better alternative is to have a water softener installed before your hot water heater and any other sorce of domestic water supplying your home. I have one and it works great. Just be advised that you will need to replace the salt crystals every couple of months depending on the time intervals you set the timer to. If you find that the water still remains soft after two months and your filters are not to badly clogged then you may try adding salt every three or four months and see if that solves your problem. You also have to remember that your also using the water for drinking cooking and bathing so softening your water supply is very important especially if you or anyone in your household ever had any kidney stones or kidney problems.
Good luck,
Marty
Navien...
Answered
on May 13, 2014
I have a protech 1220I THAT IS IN NEED OF REPAIR
Automatic battery chargers have complex circuitry that is difficult to test especially when designed and built in a compact package and repairs are best entrusted to someone geared to such work which is outside the scope of general electronics.
On the plus side, as long as the intelligent circuitry is protected against mains borne surges and spikes the automatic charger is somewhat self-protecting against over stress and will tend not to even attempt to charge a defective battery, a sulphated or overly discharged battery.
I suggest you first check the battery or batteries to ensure they are healthy and have some charge so the charger can "see" them before condemning the charger and also check the connections to the battery that must be virtually perfect...
Water Heaters
Answered
on Oct 05, 2020
Satchwell geyser thermostat
NO HOT WATER
- If the tester indicates there is power to the terminals and the water in the geyser is cold, then the element is faulty. ( ...
- If the tester indicates there is no power to the terminals and the water is cold, then the thermostat is faulty.
https://www.youtube.com/watch?v=qCXmyhEY_k4
Water Heaters
Answered
on May 06, 2020
