20 Most Recent
Clymer Mercury/Mariner 4-90 HP Four Stroke Outboards 1995-2000 Questions & Answers
Why do you get total loss of all electrics
Its possible, but if trim stopped first, then you lost everything else, I would doubt it's the fuse. Unless they're on separate circuits. First check your battery connections and voltage. Next check for power at your fuses. If they're good, check if you have a main power solenoid. If you do, its possible the coil has gotten weak or the contacts are worn. Hopefully this helps. Electrical issues can be a variety of things but are usually simple.
7/24/2014 12:45:49 AM •
Clymer...
Answered
on Jul 24, 2014
55973 A EVINRUDE Wiring Diagram IN COLOR FOR Free
Red battery positive
Red purple, switched positive
Yellow red startermotor connect to positive to start )
Purple white choke (connect to positive to choke)
Black yellow stop circuit ( connect to negative to stop engine )
Black battery negative ( for stop circuit )
Yamaha 25 nmo
The power supply is common for all the coils.
Have you switched the coils (wires marked 1 and 2)? If still the same coil non sparking, replace that coil.
If the same output non sparking, check the pulser coil for that cylinder. Invert both pulser coil connections (white red and white black). If the miss is on the same cilinder, replace the cdi. If the miss is on the other cylinder: replace that pulser coil.
I just bought a new boat and need to buy a boat
Never buy a trailer with the same capacity as the weight of your boat! This can be very dangerous! Instead, make sure the trailer's capacity is at least twice that of the weight of the boat, all your gear, and the boat's motor.
12/5/2023 6:58:35 AM •
Boating
Answered
on Dec 05, 2023
What is the size of a small yacht?
Small yachts, also known as Silboats or Cabin
Cruisers are 20-40 feet. There are of course larger Yachts that can get to over
100 feet, also known as Mega Yachts.
11/15/2023 8:08:55 AM •
Boating
Answered
on Nov 15, 2023
