20 Most Recent
Endless Summer (GA200209) Stainless Steel Open Flame Patio Heater Questions & Answers
Pilot is lighting, but unit won't light
If the pilot light stays light after you relaease the knob, but your burner will not light then it most likely is the tip switch. Install a jumper wire across the tip switch connections and your burner should light, do not operate with jumper wire as this is bypassing the saftey feature.
I can light pilot but cant get main burner to stay
Clean the gas tube before the pilot light with a small wire. If you don't light these units every month or so you can get all sorts of bugs and critters that will call your gas tube home. Second option - Either the thermocouple is bad or the gas control valve is not opening completely. Try replacing the thermocouple
