20 Most Recent
Tag Heuer Link Calibre 6 Automatic Bracelet Mens Watch WAT2111BA0950 Questions & Answers
Scratch on my tag heuer sunglasses lens
Hi Karen,
there are a number of places that specialize in replacing scratched or broken sunglass lenses.
www.thesunglassfix.com is probably the largest out there and known for good quality at a great price. However, there are others like fuse.com and your local optomentrist that may have the lenses.
Most offer the option of having the lenses sent out to you or you sending in the frames to get new lenses.
Have tried many of the "buffing out scenarios above" and my personal opinion is they don't work and only make matters worse. Getting new lenses can cost as little as 10% of the purchase price and complete resolves the issue for years.
Good luck Craig
Sunglass Replacement Lenses for all Sunglass Brands
11/19/2015 7:28:54 PM •
Tag Heuer...
Answered
on Nov 19, 2015
Missing screw on 5502
Take them to a sun glasses dealer. Usually they will fix the screws free of charge.
8/1/2013 4:49:14 AM •
Tag Heuer...
Answered
on Aug 01, 2013
I have a pair of
go to the official Tag Heuer website, www.tagheuer.com, look for the retailers in your country chose the one nearest to you and contact him
The name of the model is TH 6008 102
5/23/2011 5:08:02 PM •
Tag Heuer...
Answered
on May 23, 2011
Replace rubber on nose pieces
go to an opticians and it will only cost a few pence and they will replace them and fit them so they sit snug for you
hope this helps
3/3/2011 1:26:14 AM •
Tag Heuer...
Answered
on Mar 03, 2011
I bought a pair of
I would take them back to the shop you bought them and they will either take them and replace them or give you an address or phone number for who they should go to
hope this helps
3/3/2011 1:24:50 AM •
Tag Heuer...
Answered
on Mar 03, 2011
Need to know where I
hi
i dont think it will be a problem ,did you try approaching the dealer who deals with your brand if you have warranty it will be done free of cost . if your brand dealer cant help please try approaching any one dealing with sunglasses i am sure they will solve your problem it wil be done cheap.
thank you
12/30/2010 8:55:38 AM •
Tag Heuer...
Answered
on Dec 30, 2010
Oakley screw fell out
Here are a few steps you can take to address this issue:
Tighten Existing Screws: First, try tightening the hinge screws. Use a small, flat-head screwdriver to remove the rubber screw cover located on the hinge area. Then gently tighten the screws that hold the hinge in place. Be careful not to over-tighten them, as this can strip the screws.
Check for Replacement Screws: You can search for replacement screws specifically designed for Oakley Tie Breaker sunglasses. Some online retailers offer Oakley replacement screws that can help fix the problem. Look for screws that match the original ones in terms of size and design.
Sunglass Repair Kits: Consider using a sunglass repair kit. These kits often include various sizes of screws and tools for repairing sunglasses. You might find a suitable replacement screw in one of these kits.
Remember to handle the screws carefully and avoid overtightening. If you're unable to find a replacement screw, reaching out to Oakley customer service.
4/20/2024 10:49:19 PM •
Clothing...
Answered
on Apr 20, 2024
What do you pack in your purse?
Here are list of things you can carry in your purse:
A makeup bag. I do my makeup on the go a lot, so a makeup bag is necessary for me.
A pair of earrings / jewelry.
Hair ties and bobby pins.
A hair brush.
A notebook / sketchbook.
A pen and a pencil.
Pack of tissues.
4/17/2024 7:09:47 AM •
Clothing...
Answered
on Apr 17, 2024
How to clean white shoes properly?
Cleaning white shoes can help maintain their appearance and keep them looking fresh. Here's a step-by-step guide on how to clean white shoes properly:Materials you'll need:1. Mild soap or detergent2. Soft brush or toothbrush3. White vinegar or baking soda (optional)4. Water5. Clean cloth or sponge6. Old newspapers or paper towels Steps:1. Remove Loose Dirt: Knock your shoes together or use a brush to remove loose dirt and debris. You can also use a soft cloth to wipe away any surface dirt.2. Remove Laces: Take off the shoelaces. You can either clean them separately or replace them if they are too dirty or worn.3. Pre-treat Stains:If there are stubborn stains, pre-treat them with a mixture of water and a small amount of mild soap or detergent. You can also use a paste made from baking soda and water for tougher stains.4. Soak Laces:If you removed the laces, soak them in a mixture of warm water and mild soap. You can also add a bit of baking soda or white vinegar to help with stains. After soaking, scrub them with a brush or toothbrush, rinse, and let them air dry.5. Wash Shoes: Mix warm water with a small amount of mild soap or detergent. Use a soft brush or toothbrush to scrub the shoes gently. Pay extra attention to stained or dirty areas. Be careful not to use a brush with stiff bristles, as it may damage the shoe material.6. Rinse Thoroughly:Wipe off any soap or detergent with a clean, damp cloth or sponge. Make sure to remove all residue.7. Dry Properly:Stuff your shoes with crumpled newspaper or paper towels to help them retain their shape and absorb moisture. Let them air dry in a well-ventilated area. Avoid direct heat sources like radiators or sunlight, as this can cause the shoes to yellow.8. Clean Soles:Clean the soles of your shoes separately. You can use an old toothbrush or a small brush to scrub away dirt and grime. A mixture of water and mild soap or a specialized sole cleaner can be effective.9. Protect and Maintain: Consider applying a stain and water repellent spray to protect your white shoes from future stains. Regularly clean your shoes to prevent dirt buildup.10. Polish (for Leather Shoes):If your white shoes are made of leather, you can use a white shoe polish to restore their shine. Make sure to follow the instructions on the polish container.Remember, prevention is key. Try to avoid wearing your white shoes in muddy or extremely dirty conditions, and clean them regularly to keep them looking their best.
4/17/2024 7:05:52 AM •
Clothing...
Answered
on Apr 17, 2024
How much would getting a wedding dress made cost?
The cost of getting a wedding dress made can vary greatly depending on factors like the design complexity, quality of materials, and the expertise of the designer. On average, it can range from a few hundred to several thousand dollars. It's important to consider your budget and discuss pricing with the designer to find the best option for you. For best designer lehengas, saree and ethnic wear you can check Mirraw Luxe online. Visit now: https://www.mirrawluxe.com/trends/wedding
3/8/2024 1:22:32 PM •
Clothing...
Answered
on Mar 08, 2024
