20 Most Recent
GE GTS22KCM Top Freezer Refrigerator Questions & Answers
COMPRESSOR NOT TURNING ON
Hello Mattpatoska,
I have no idea what your refrigerator really is...
as I attempt to research I get
longer
model numbers... (USA)
Were I you... and ready to put it (frig) out of my misery..
I'd first at least try to look at the compressor...!!
Is it getting AC...??
(really nice No contact volt tester on Amazon
((see below
Should I try to ...
Open the AC (??)
(so as not to smoke the defrost/compressor
control board)
and apply AC directly to PROVE/DISPROVE
your OWN hypothesis.
I would (and have the scars (experience) to
Prove it...
My big piece of advice:
Take notes & pictures of what wires go WHERE...!!
Klein Tools NCVT 3 Non Contact Voltage Tester with Flashlight Amazon com
Carnac the Magnificent
Why internal lights not working yet panel lights do?
There could be several reasons why the internal lights in a vehicle may not be working while the panel lights are functioning. Here are a few possible explanations:
1. Blown fuse: Check the fuse box to see if the fuse for the interior lights has blown. If it has, replace it with a new one of the same rating.
2. Faulty light switch: The switch that controls the interior lights may be faulty or worn out. Try toggling the switch on and off to see if it makes any difference. If not, consider replacing the switch.
3. Loose or corroded wiring: Inspect the wiring connections for the interior lights. Loose or corroded connections can disrupt the electrical flow and prevent the lights from working. Tighten any loose connections or clean off any corrosion.
4. Burnt-out bulbs: If all the interior lights are not working, it's possible that multiple bulbs have burnt out at the same time. Check the bulbs and replace any that are no longer functional.
5. Dimmer switch settings: Some vehicles have a dimmer switch that controls the brightness of the interior lights. Make sure the dimmer switch is not turned all the way down or set to a very low level.
If none of these solutions resolve the issue, it may be best to consult a professional mechanic or electrician to diagnose and repair the problem.
