20 Most Recent GE GTS22IBMWW Top Freezer Refrigerator Questions & Answers
Backside of motherboard fried near relay on ge
Good day,
The board could have simply failed. However, the compressor should be checked thoroughly before replacing it since it's pricey.
A service tech, would first test to make sure, none of the windings are grounded. This is done by removing the relay and overload mounted on the compressor, then checking each pin of the compressor to ground (bare copper tubing) with an ohm meter. Each pin should show near infinity.
Then he would connect a start cord designed specifically for compressor running, and run the compressor independent of the rest of the machine.
If it runs O.K. he would then test the overload and relay before calling the compressor O.K.
It has to be your call, as to how you want to proceed.
The price of the board being the big issue.
Thanks for using FixYa.
12/18/2009 3:55:00 PM • GE GTS22IBMWW... • Answered on Dec 18, 2009
2answers
New GE GNE27JYMFS refrigerator revs every 10 seconds or so
Hi, Please ensure that the door is properly closed and that there are no leaks. You can also ensure that the temperatures are no colder than is required to cool or freeze your food as a very low temperature would require more work/energy from the fridge. Lastly, you can power cycle the fridge once and if it continues with the issue, you can return it. Thank you.
12/6/2022 7:41:13 PM • GE Refrigerators • Answered 15 hours ago
2answers
GE refrigerator surging noise on model #GFE26JYMNFFS
ice maker noise
11/20/2022 7:28:20 PM • GE Refrigerators • Answered on Nov 20, 2022
GE Monogram Refrigerator Leaks Water
The defrost drain would be causing the fridge to have water leaking out of it and you will need to also clean the defrosting drain as well or need to replace it.
11/19/2022 4:41:26 PM • GE Refrigerators • Answered on Nov 19, 2022
GE model GSL25JFPD freezer stoope working. Can anyone help?
Hi, please make sure that temperature controls are set to the temperature that you want. Then, you'll want to double check that the power outlets that the freezer is plugged into still give out power by testing other appliances on them. If the outlets don't work, then you would want to check the corresponding fuse in your fusebox because it might have switched off and just needs to be switched back. Thank you.
11/15/2022 6:00:11 PM • GE Refrigerators • Answered on Nov 15, 2022
Hi I have a GE Profile refrigerator. Freezer is cold but fresh food compartment is warm, condenser coils are clean, all fans are running as if normal but no air flow to fresh food? model PNE21KSKAKSS.
That can be caused by two things The air circulation fan has failed. or The cold comes from the freezer and if the defrost isn't working, you have a solid block of ice that doesn't allow cold air to go down to the fridge. This is an unusual unit https://www.partselect.ca/Models/PNE21KSKAKSS/ ..
10/25/2022 12:38:04 AM • GE Refrigerators • Answered on Oct 25, 2022
Why my GE Monogram ziss480drjss is making loud knocking noise in every 4-5 minutes interval?
https://www.youtube.com/watch?v=sLR2vKxgwbM A freezer compressor is what pumps chilled Freon -- or another cooling agent -- through coils that line the freezer compartment. ... The cooling agent inside the compressor is sensitive to being moved around, which can cause knocking noises. Also, loose components can cause knocking sounds.
10/22/2022 7:34:15 PM • GE Refrigerators • Answered on Oct 22, 2022
20answers
GE Fridge will not stop flashing zeros diagnostic
I had the same problem. The cause is the digital display is not communicating with the motherboard. What had happened in my case is the plug connection between the door's digital display and the motherboard had become unplugged. The wire running from the motherboard runs below the fridge, and connects via plug located along the bottom of the fridge below the freezer door, connecting to the wire running from the display to the bottom of the freezer door. I just reconnected it and that reset the display. Glad for it too, I thought I needed a new $130 motherboard! Hope this helped!
10/16/2022 4:18:49 PM • GE Refrigerators • Answered on Oct 16, 2022
Gsl25jfpa GE Refrigerator not turning on /cooling
the capacitor and the thermistor may be both at fault. with too low resistance the capacitor may have overcharged I would replace both,
10/1/2022 4:43:30 AM • GE Refrigerators • Answered on Oct 01, 2022
Evaporator Frozen in GE Monogram ZICS360 bottom freezer fridge.
low on freon
9/15/2022 10:30:36 PM • GE Refrigerators • Answered on Sep 15, 2022
I have a GE monogram wine fridge (ZDB24A RBB). I think the thermostat is bad, but GE has discontinued it and no longer supplies parts. Where can I get a new thermostat?
online search their are 1,000 s of small appliance parts companies that carry ge parts or replacement parts
9/2/2022 3:14:11 PM • GE Refrigerators • Answered on Sep 02, 2022
2answers
My GE built in fridge makes an intermittent woodpecker sound that lasts for a few seconds. Happens several times a day. It stopped for a few months then just restarted.
Check the suspension brackets under the compressor. Do normal servicing cleaning condenser fins of dust.
8/28/2022 5:03:56 AM • GE Refrigerators • Answered on Aug 28, 2022
GE GTS22IBMWW Top Freezer Refrigerator Logo
4 questions posted
Top Refrigerators Experts
RJ H2O
RJ H2O
rhodesworks
Gregg Thomas
Level 1 Expert
View Most Popular
GE Refrigerators
  • GE Refrigerators
Most Popular Question
backside motherboard fried near relay ge
  • Refrigerators
