The drive database cdrw32.bdb cannot be found
The following is installation instructions for CD-Maker Professional. For Backup Now, the instructions are the same, however, you will install it in the NTI Backup Now directory, rather than the NTI CD-Maker directory.
To install, please copy the "cdrw32.bdb" file use Windows Explorer or My Computer to copy the database file into the main folder for CD-Maker 2000 Professional. If you installed our software in a different directory then you will need to copy the file into your alternate location.
Example where database file is located:
C:\Program Files\NewTech Infosystems\NTI CD-Maker 2000 Professional
You can also use the find feature in Windows to find the exact location of the database file. Click "Start", the "Search", then "for Files and Folder", then type in cdrw32.bdb and click "Search Now". After it finds the file then you can read under the "In Folder" heading for the correct path where the database file is located. Use Windows Explorer or My computer to copy the database file into this location.
NOTE:
(1) It works only on full retail versions of NTI software
(2) For CD-Maker, it works for Version 5.1.1 or later.
(3) For NTI Backup Now, it works for Version 2.2.33 or later.
(4) For supported DVD burner models, CD-Maker V5.1.XX and Backup NOW! (and DriveBackup!) V2.X will support only the CD burning function of these models, not DVD burning. DVD burning is supported starting from Version 6.0 of CD&DVD-Maker, and Version 3.0 of Backup NOW! and DriveBackup!, respectively.
Thanks for using Fixya
