20 Most Recent GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC Side by Side Refrigerator Questions & Answers
check defrost element, if good check defrost thermostat, if good change defrot timer/control board depending on your specific model you can look at this link provided its a diff model but none the less quite similar
am searching for Main PBA for fridge freezer model no SRL 629EV The number...
GE GSS22KGMBB /... | Answered on Jan 07, 2015
The main board on the back of the unit has gone bad or in lockout. Try unplugging unit for about 30 seconds. Then plug it back in. If it doesn't start the board is bad. wr55x10942 at about 169.00. Hope this helps. Very common GE problem
GE GSS22KGMBB /... | Answered on Mar 29, 2010
I have replaced quite a few thermistors in similar units. Call him back and have him check the one in the fresh food side.
GE GSS22KGMBB /... | Answered on Mar 12, 2010
if ice bulid up on frezzer? if so replace thr defost heater behind frezzer panal
GE GSS22KGMBB /... | Answered on Feb 18, 2010
First thing is to check see if the condenser is blocked up with dust and gunge, Have a look usually at the back or sometime underneath, and clean out all muck from the fins allowing the hear to dissipate better.
GE GSS22KGMBB /... | Answered on Dec 27, 2009
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10101 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , associated with the fan speed also .
GE GSS22KGMBB /... | Answered on Nov 19, 2009
Hair dryer is the easiest way to thaw. To find cause: Remove lower grill and disconnect the water line going through the freezer2_bing.gif door hinge. Usually it is a push lock fitting, which requires you to push the ring2_bing.gif on the end of the fitting toward the center of the fitting while pulling (not hard) on the plastic tube. Now place a pan under the separated plastic hose and try the water dispenser. If water comes out, your problem is a frozen water line in the freezer door. A warmer freezer temp may help, or you can order and install a WR49X10173 water tube heater2_bing.gif. (the heater may take 24 hours to thaw the line, but I have used it successfully several times. Cost about $50) If no water comes out the separated tube when you try to dispense water, reconnect the tube at the hinge by pushing the plastic line back into the fitting. Now, at the back of the refrig., disconnect the water line going from the water valve to the fresh foods compartment. Try to dispense water. No water at valve outlet = bad valve. Water dispensed from valve now = frozen water filter2_bing.gif or water line at back bottom of fresh foods compartment. (make sure you disconnect the right tube. If in doubt, disconnect them both, just get them back correctly so your icemaker continues to work) Send me additional comments if needed. Don't rate before you try all the steps.
If water filter or water line/ reservoir is frozen, thaw with a hair dryer. If reservoir is frozen, check to make sure there is no frost on back wall of inside freezer, preventing normal air flow, allowing cold air to enter fresh foods compartment through return air vent at lower back of fresh foods compartment, resulting in freezing of water line / reservoir and possibly food in bottom bin.
GE GSS22KGMBB /... | Answered on Nov 18, 2009
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . You can also install pt # WR49X10173 , which is a dispensor heater . This comes with instructions .
GE GSS22KGMBB /... | Answered on Nov 08, 2009
I guess the first thing i would check is to make sure the control board is getting a proper ground. next i would manually put it in defrost (while it is still frosted) and make sure the heater is glowing red hot. other than that i would have to suspect another bad board? let me know how it turns out
GE GSS22KGMBB /... | Answered on Sep 27, 2008
search google for an appliance parts seller and put your model number in
GE Refrigerators | Answered on Jul 20, 2020
the magnet seal arount the door needs to be replace, ypu can purchsase this and simply remove the old and and glue on the new one.
another quick fix method is to use a hax and staple type lock and screw the stape on the frodge and the hax on the door sor sfter you puch in the door simply staple it shut.
GE Refrigerators | Answered on Jun 19, 2020
I had the same problem. The cause is the digital display is not communicating with the motherboard. What had happened in my case is the plug connection between the door's digital display and the motherboard had become unplugged. The wire running from the motherboard runs below the fridge, and connects via plug located along the bottom of the fridge below the freezer door, connecting to the wire running from the display to the bottom of the freezer door. I just reconnected it and that reset the display. Glad for it too, I thought I needed a new $130 motherboard! Hope this helped!
GE Refrigerators | Answered on Jun 18, 2020
It is the job of the refrigeration system to move heat from inside the cabinet to the outside - that is why when it works correctly, the compressor runs and the condenser and some of the pipework becomes quite warm (hand hot in some cases).
If this is happening it proves heat is being moved though if the cabinet doesn't become colder it is possible the heat that is being moved could be coming, in a frost free appliance, from the defrost heating element that must be permanently on due to a timer or thermostat fault. The defrost heater usually is switched on only for a short time at the end of each cooling cycle.
If the condenser isn't warm while the compressor is running, it could be the compressor is broken or the refrigerant has leaked away.
GE Refrigerators | Answered on Jun 16, 2020
GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC Side by Side Refrigerator Logo
21 questions posted
Top Refrigerators Experts
John Tripp
John Tripp
Mike McBirney
Level 1 Expert
gbob59
View Most Popular
GE Refrigerators
  • GE Refrigerators
Most Popular Question
ge fridge freezer but no cold air
  • Refrigerators
