20 Most Recent Hampton Bay 48 In. Palm Beach in Textured White Fan Questions & Answers
Try calling 1-877-527-0313
Hampton Bay 48... | Answered on Jun 27, 2013
They make a screwdriver that is called an offset screwdriver. They are either standard or phillips. Check to see how much clearance you have between the blades and the fixture, and if it is more than 1 and a half inches, you can probably get the screwdriver in there. If you have enough clearance, take one of the screws to Sears, Home Depot, Lowes or a hardware store to get the correct screwdriver
Hampton Bay 48... | Answered on Jul 20, 2011
In the cealing where the fan is mounted, you have wires in the switch the control the fan speeds, to the motor and wires that control the light. Most likely there is a wire exposed or short that every time you turn light on, it of course blows light out. Als check , open up switch on wall first to make sure no loose wire on wall switch. Please turn of breaker first, make SURE power is off. Please if this advice helped, give me 4 thumbs to help me and others, thanks, Mike
Hampton Bay 48... | Answered on Jun 16, 2011
what is the name of the product that you need its manual. Please give me full details of the product, including its model.
I look forward to your reply.
Bye for now.
Hampton Bay 48... | Answered on Jul 10, 2010
You can try http://www.exava.com/ and in the search box, type the key word fan blades
Hampton Bay 48... | Answered on Jun 06, 2010
Me too. I went back to Home Depot. They gave to me the phone number for Hampton Bay - 1-877-527-0313. I will call them tomorrow after they open to see what the deal is. it looks to me like the JDE11 is a mini-candelabra base. The lady in the fans at Home Depot said that all of the light kits were changing to the smaller based halogen lights. BUT, you'd think that they'd carry the light bulbs that have to go in the light kits they sell!!!
Hampton Bay 48... | Answered on Aug 25, 2009
If it is a dome light then there will be 3 small screws tha screw into the dome at the very top, spaced evenly around it.
The friction from the screws holds the dome in place. Chenge the bulbs and fit the dome back in, screwing all three screws in partially. Then hold it firmily up against the fan base and tighten one til it makes contact. Tighten the other two the same way and when the dome is secure, tighten all 3 screws so it doesn't come loose.
Hampton Bay 48... | Answered on May 31, 2009
Those rubber "washers" get pressed into the holes in the blade itself. It takes a little bit of squeezing and manipulating though. Make sure they are fully in.
Hampton Bay 48... | Answered on Jan 30, 2009
You just need the switch by the sounds of it.
Hampton Bay Customer Support -Troubleshooting & FAQ ' The Home ...
www.homedepot.com/c/SPC_BRD_HamptonBay_Help
  1. Cached
  2. Similar
Find Hampton Bay customer support, replacement parts, warranty information, troubleshooting and ... Ceiling Fans Patio Furniture Lighting Bath Fans Fireplace
Hampton Bay - Ceiling Fan Parts - Ceiling Fans & Accessories - The ...
www.homedepot.com > ... > Ceiling Fans & Accessories > Ceiling Fan Parts
  1. Cached
Shop our selection of Hampton Bay, Ceiling Fan Parts in the Lighting & Ceiling ... Hampton Bay 3-Light Universal Ceiling Fan Light Kit with Shatter Resistant Bowl .... Fan Light is an ideal choice for replacing worn or outdated fan light fixtures.
Hampton Bay Lighting Parts and Accessories ' eBay
www.ebay.com > ... > Hampton Bay Lighting Parts and Accessories
  1. Cached
  2. Similar
Replaces Hampton Bay and many other similar ceiling fan remote controls. Common replacement for model number UC7078T or FAN-HD with a reverse button.
Hampton Bay Replacement Parts
hamptonlightingadvice.com/hampton-bay-replacement-parts/
  1. Cached
If you have a Hampton Bay product such as a lighting fixture or patio furniture or maybe even some solar lights or ceiling fans then you may need to find a ...
Hampton bay fan and lighting company website store
hamptonbayfanandlighting.net/
  1. Cached
Hampton bay fan and lighting online store. Menu. Skip to content. Hampton bay moved to new ... Hampton bay moved to new website >>>> hampton bay ...
Hampton Bay Ceiling Fan Parts
www.ceilingfansbay.com/hampton-bay-ceiling-fan-parts/
  1. Cached
Do you need help to find a Hampton Bay Ceiling Fan Part? ... known and reputable manufacturer of ceiling fans, bath fans, light fixtures, patio furniture, chandeliers and more. ... Easy Way to Finding the correct Hampton Bay replacement part:.
Hampton Bay Ceiling Fans & Lighting
  1. Cached
If you need a Hampton Bay replacement part, we can help you with that. Here are the most common Hampton Bay replacement parts that people search for, and ...
Lighting Replacement Parts For Your Ceiling Fan
www.ceilingfanreplacementparts.com/hampton_bay_lighting_replacement_parts.html
  1. Cached
  2. Similar
Hampton Bay lighting replacement parts are readily available to let you maintain for many years the beauty and function of your ceiling fans, lamps, chandeliers, ...
Hampton Bay Google Search
Hampton Bay... | Answered on Apr 06, 2020
try homedepot
https://www.homedepot.com/b/Lighting-Ceiling-Fan-Parts/Hampton-Bay/N-5yc1vZbvmwZp4
Hampton Bay... | Answered on Mar 30, 2020
Circular compact florescent? Amazon
https://www.amazon.com/TCP-Equivalent-Double-Circle-Non-dimmable/dp/B000CQCRBM/ref=cm_cr_srp_d_product_top?ie=UTF8
https://www.google.com/search?q=light+bulb+for+a+hampton+bay+callaway+fan+%2346056
Hampton Bay... | Answered on Feb 25, 2020
caroll wilson Dec 13, 2019
Slide the motor collar cover up to expose the switch.
Hampton Bay... | Answered on Dec 13, 2019
Presumably you changed the battery in the remote control. In any event, either it or the receiver in the fan housing is defective. A common problem with ceiling fans
Hampton Bay... | Answered on Nov 29, 2019
Go to any appliance store they should have the exact match or the equivalent legs to match or have them take from another that is in stock
Hampton Bay... | Answered on Nov 19, 2019
Hampton Bay 48 In. Palm Beach in Textured White Fan Logo
14 questions posted
Top Hampton Bay Dryers Experts
Ronald Buckner
Level 1 Expert
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
View Most Popular
Hampton Bay Dryers
  • Hampton Bay Dryers
Most Popular Question
replaced 2 4 bulbs
  • Dryers
