20 Most Recent Zebco 33 Platinum Spincast Reel, 5 Ball Bearing 3.3:1, 10 lb, 130 yd, Questions & Answers
It twist to get it open -
Zebco 33... | Answered on Nov 28, 2016
Your reel has pickup pins on the spool that will guide the line onto the spool when you reel in.
Try holding gentle tension on the slack line just above your reel and start reeling in. If this does not work then remove the top cover of the reel and look to see if the line is tangled up on the inside around the center shaft underneath the pickup pin cover.
if this is the case, simply unscrew the pickup pin cover from the center shaft. It will be on the tight. Remove the tangled line and reassemble.
Zebco 33... | Answered on Dec 19, 2014
Turn the screw a 1/4 turn, then twist the front line cover left to remove it. It may be stuck but this is how you do it. It will move about an 1/8", then pull it straight off.
Zebco 33... | Answered on Oct 31, 2014
Finding reliable reviews can often be difficult, but it is definitely possible. Some things I would recommend include:
  • Checking Fishing Websites
In my time, I've bought a lot of equipment online and I often find blogs and review style posts that help to point me in the right direction. There are a lot of fishing sites out there to choose from. For information about gear and accessories, I often use fishermenspond.com.
  • Checking Amazon Listings
It's also a good idea to check Amazon reviews before purchasing a product. You can filter the reviews by good and bad. This can be a good way to find out what most customers liked and disliked about the products. It's always a good idea to check the bad reviews, as the negatives of the product might not always apply to you.
  • Asking People
Other fishermen can often give the best recommendations. When you got to the lake, or wherever you like to fish, don't be afraid to ask the people there about the products they use.
Fishing | Answered on Jul 23, 2020
Try here, best place for all spares.
Fishing Reel Parts - Mikes Reel Repair
www.mikesreelrepair.com > reel-parts
Fishing reel parts from almost every manufacturer, all available in one place! Be sure to use the Schematics to find the part numbers you require, then search for ...
Mikes Reel Repair - Fishing Reel Parts & Service
Fishing reel parts and service and upgrades. We repair rods, reels, trolling motors, depth sounders, downriggers and Coleman Outdoor products.
Fishing | Answered on Jul 16, 2020
The manufacturer/distributor might be able to supply.
Fishing | Answered on Jul 05, 2020
Yours must be an old model, but you could contact them. That just looks like it is rusted on. Leave upright, squirt with WD40, leave for 10 minutes and wiggle it off.
If your Pinnacle reel is an older model, and a parts diagram is not posted at our site, please submit the model number of your reel and a detailed description of the part(s) desired.
https://www.pinnaclefishing.com/shop/t-partsdiagram.aspx
Probably a seal has broken/worn. Find out which one and get replacement O rings from your local hardware store.
Fishing | Answered on Jun 24, 2020
R2F Fishing Reel Parts‎
www.when.com/R2F+Fishing+Reel+Parts‎
Explore R2F Fishing Reel Parts
Discover More on When.com!
Fishing | Answered on Feb 25, 2020
This may be a known issue. Contact Berkeley and see if they will send you a free replacement. If not, support Mike's Reel Repair. Tell him we sent you :>)
www.mikesreelrepair.com > berkley-fusion-206-revision-00-schematic
Berkley FUSION 206 REVISION 00 Schematic - Mikes Reel ...
Free
Fishing reel parts and service and upgrades. We repair rods, reels, trolling motors, depth sounders, downriggers and Coleman Outdoor products. www.berkley-fishing.com > Berkley-parts
Parts - Berkley Fishing
For reel parts please contact the Berkley Johnson Factory Service Center. To ensure that you identify the correct part, please have the following information ...
Fishing | Answered on Feb 02, 2020
I tried to access this page but couldn't.
https://www.daiwa.com/us/service/manuals/index.html
If you are in the States you might be able to..
This is the place to download a manual.
Regards
Geoff
Fishing | Answered on Jan 08, 2020
ASK GOOGLE WE DO NOT HAVE IT
Fishing | Answered on Jan 04, 2020
Hey Adam,, I hope you have fixed your reel by now.. but,,,
http://www.davesreelservice.com/
https://www.mikesreelrepair.com/
Fishing | Answered on Dec 16, 2019
Zebco 33 Platinum Spincast Reel, 5 Ball Bearing 3.3:1, 10 lb, 130 yd, Logo
6 questions posted
Top Zebco Fishing Experts
Thomas Perkins
Thomas Perkins
ray gallant
Arthur
Are you a Zebco Fishing Expert? Answer questions, earn points and help others
View Most Popular
Zebco Fishing
  • Zebco Fishing
Most Popular Question
get zebco retrieve line
  • Fishing
