20 Most Recent Stanley Quick Point Snap-off Blade Knife Questions & Answers
Slide the blade holder all the way out, press on the tab as shown in picture. Pull on blade with other hand. Blade slides right out.
Stanley Cutter... | Answered on Jun 07, 2017
you can use a portable bandsaw to cut rebar, I find it to be the best solution when I can't take the rebar somewhere to cut it. But be careful if the metal is heavy it could fall and dent/damage the floor if you're working indoors of cause injury should it land on you.
Cutter Tools | Answered on Sep 20, 2019
Use a third blade, preferable mounted to your utility handle, to part them. Handle only from the back side and give the utility knife a slight twist as soon as it is between the points of the new blades.
Cutter Tools | Answered on Sep 13, 2019
Manual bolt cutters usually have symmetrical V-edge cutting blades.
With the sharpening angle in the range of 20-30 degrees.
For comparison, the sharpening angle of the kitchen knife is less than 10 degrees.
With such a pretty blunt edge is impossible to cut your finger. But this is the best option for cutting thick metal rods or cables. Like this:
If it is interesting to read more information about bolt cutters, I recommend this review -
https://toolslaboratory.com/best-bolt-cutter-buyers-guide-2019
Cutter Tools | Answered on Jul 10, 2019
https://www.youtube.com/watch?v=26pv9PAyO1I Helpful video to show how it works. Once you get the hang of it becomes easier.
Cutter Tools | Answered on May 31, 2019
Tip
How to Use a Pipe Cutter?
Pipe cutters are really useful tools that can be used in the house to cut pipes that are made from metal or plastic. You could always try using a saw of some kind but pipe cutters will give you a much straighter edge.
Here are some basic instructions to help you successfully use a pipe cutter.
1. Decide exactly where on the pipe you would like to make a cut.
2. Loosen the handle on the pipe cutter and place it around the pipe.
3. Now tighten the cutter until the blade is in contact with the pipe.
4. Turn the pipe cutter a few turns around the pipe and it will score a line into the pipe.
5. Keep turning the pipe cutter around until you've cut the pipe off.
6. In order to create a nice straight edge inside the cut pipe you need to take the bottom blade out of the pipe cutter.
7. Place it into the cut end of the pipe and turn it around a few times until it's nice and smooth.
on May 29, 2019 | Cutter Tools
You can also refer woodfordtooling online site for more information about planer knives Or Refer link https://www.woodfordtooling.com/planer-knives.html
Cutter Tools | Answered on Dec 20, 2018
This utility knife reassemblies similar to the original. The only difference is this model uses two screws and that plastic insert. You will align the two metal halves and bring them together. Use care that the blade does not fall out of its holder and the little black plastic piece stays in place, near the blade. This may take a few tries. after you bring the two halves together you will carefully separate the bottom end (farthest from blade). Separate it just enough to slide the plastic insert into position. Once the three pieces align you will know. With little effort the two metal halves will close together. Install the two set screws and test for proper function. I'm including a Youtube video that shows how to properly change the blade and what it will look like after it is reassembled.
https://www.youtube.com/watch?v=5napTSRSyeQ
Cutter Tools | Answered on Sep 23, 2018
use a separate blade and pry them open o the blade ege. there is a small space to do it.
Cutter Tools | Answered on Aug 16, 2018
use a 3rd blade to separate them. use your head
A good utility knife can change the way you work, while a bad one can make you project more difficult. A utility knife can perform a wide range of activities indeed. You can use it as a box cutter, a pocket knife, even as a camping knife. To be precise, the utility of a utility knife is far more than most people expect. That is why, everybody should have the best utility knife as a companion to their daily Do-It-Yourself activities.
Cutter Tools | Answered on Jun 10, 2018
Stanley Quick Point Snap-off Blade Knife Logo
1 questions posted
Top Stanley Cutter Tools Experts
efs_perpends
efs_perpends
Joe Garcia
Joe Garcia
JOHN LAPIER
Are you a Stanley Cutter Tool Expert? Answer questions, earn points and help others
View Most Popular
  • Stanley Cutter Tools
Most Popular Question
stanley quick utility knife number
  • Cutter Tools
