20 Most Recent
Lakewood HV-30PB Stand (Pedestal) Fan Questions & Answers
Need to find the pull chain switch to replace.
mcdevito75 here, You may be able to match up the factory switch with a switch from a large hardware store, home depot, etc. or you could try to contact your fans maker plus.com nline.
Lakewood mini tower fan model mtf-15. The oscillating fan stopped oscillating. How do you repair it?
Whether the fan has a dedicated oscillation motor or is driven by an extended shaft from the main motor, there is usually a button or switch to disengage the oscillating function. If this no longer has any effect the only cure is to dismantle the machine until the fault is discovered and then if a repair is possible - repair it...
Most domestic fans have no spare part support, mechanisms have a limited life and if "handyman" repairs aren't possible it is considered a throw-away item.
