20 Most Recent
Kaspersky Labs Kaspersky Internet Security 2009 for PC Questions & Answers
I bought the Kaspersky Internet
You know this is Fixya dot com and we are not Kaspersky? We just have the category for handy filing.Take it back to Calcutta and get your money back. Buy the software in the country where you reside. The software reads the IP Address of your country of origin.
I down loaded anti virus and i cant running it coz
Defragement your local disc.
Right click to your local disc drive and select security and settings.
Select check for errors,by selecting this item it will checking your disc.
Then run your anti virus which you have.
When virus will being installed then scan your hard drive to found malicious program.
I just down loaded kaspersky 2010 the trial
If you are not on internet or not connected it will not to allow to run such a anti virus.
Get connected to internet and then re download the item.
Get updated version of kaspersky.
I didnt got any antivirus trail any problem with
you can get trial version for only one month if you already used that then you can't get it again.you cant get key even you reinstall your antivirus again untill you reinstall your OS.i mean system formatting.
Kasper 2009 wont allow me to go on the internet
More than likely what has happened is that kaspersky found and removed a piece to spyware or a virus and that broke the IP stack. Get on another computer with internet access and search for a program called winsockxpfix download this to a usb drive and run it on the computer with the internet problems. This program will reset the tcp/ip settings in the computer and then when you restart the pc you should be back online again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Serial number
If you lost your serial you should be able to retrive it by this steps:
1. Go to the manufactor's website.
2. If you register your product you should be a to log in to the website.
3. If you forgot your username and password click on forgot link.
4. Answer some security question they requested of you.
5. They will email your username and password or some sites will
e-mail you a temperary password to renew your password.
6. Click on that link in the email, tha you receive.
7, Your serial number should be in your account profile.
Cannot activate kaspersky internet security 2010
This either seems to be a problem with a firewall or a virus itself. Here are the steps
1) Try to see if your firewall is blocking this. Go into Kaspersky and disable the firewall. Also go to Control Panel and check if Windows Firewall is still active. If it is, disable that too ... try again to activate.
2) Download the MalwareBytes anti-malware program on your computer and run a standard scan. If anythig is found, delete it and try again.
what is your operating system (xp/vista) start your pc as Administrator then open
hosts file from
C:WindowsSystem32driversetc open that as notepad...delete the line showing boxed in the image below....
remove that line from
hosts file...then save it and try...wish it will help you...thanks for being with fixya...
Antivirus again
Antivirus programs are useless these day's they can only protect you from viruses allready know not new ones created and released.Your best bet is to check out a program called deep freeze, a virus comes in new or not and you simply turn off and on your computer and your right back to your original state. you can even delete important registry information and simply turn off and on your computer and all is replaced. save your money antivirus programs simply add more complication's to your life than you need. have a great day.
I need to block an application.. how do i do it?..
Sir firstly you have to open the settings of your kaspersky antivirus , then
You have to go to Category -> Trusted and find the application You want to move to untrusted.
it will be blocked in future.
Regards.
